01-06-2013, 06:48 AM
#51196 |
Oddometer: 2,436
01-06-2013, 07:55 AM
#51197 | ||
Pig Wrangler
Oddometer: 1,607
01-06-2013, 07:58 AM
#51198 |
two in the last few months, on dirt. One while in a turn and lost the bike. Apparently in my buddy's mirror it was a spectacular yard sale. |
01-06-2013, 07:59 AM
#51199 | |
pistolero
Oddometer: 1,212
84 Honda Goldwing (GL1200) 03 XR650L |
#51200 |
yeah they did. Marko had one....
01-06-2013, 08:16 AM
#51201 |
Just...one...more...
Oddometer: 335
Had another thought as I was firing up the grill for dinner - what if I cut off the broken bolts, take the muffler apart and remove the broken parts, then drill out all the holes and use rivet nuts or similar? Thoughts?
01-06-2013, 08:26 AM
#51202 | |
Oddometer: 3,000
Some mufflers are manufactured with rivets only. With those mufflers it is standard procedure to drill out the rivets to disassemble the muffler, and install new rivets upon re-assembly.Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-06-2013, 08:30 AM
#51203 | |
Oddometer: 86
Kurt
Def. of man: We spend 9 months trying to get out, and the rest of our lives trying to get back in. http://s1085.photobucket.com/albums/...900%20elefant/ |
01-06-2013, 08:38 AM
#51204 | |
Oddometer: 335
01-06-2013, 08:42 AM
#51205 | |
Oddometer: 3,000
![]() Quote:
![]() I'm keeping my tire pressure at 26 psi, but I'm going to install rim locks this riding season. I'm getting too old to crash on pavement, and I still get the chills remembering how I dodged the bullet last time. ![]() ![]() Spud
01-06-2013, 08:44 AM
#51206 |
Oddometer: 1,083
01-06-2013, 08:47 AM
#51207 |
Oddometer: 86
Carb to exhaust tuning.
I bought my 95 XR650L with only 7900 miles on her. The bike is bone stock. Needless to say I have been doing quite a few mods that have read here on this thread.
I ride most of the time just under 4000 feet and venture to 9000 feet every so often. Most of the rides consist of hard or soft dirt tree line riding. I do live at sea level. I have done research here in the threads about the carb mod and jetting for the exhaust. I have a FMF Q4 coming and a set of 55-155 jets coming for the bike. I plan on drilling the slider holes out to 5/32 holes. Question: Do I need to shim the needle with the larger jets or try it with out.?? Thanks Kurt
01-06-2013, 08:48 AM
#51208 |
Oddometer: 83
clutch cover
the clutch casing from the xr and xl 600 will not fit on my rfvc 650
(im doing the kickstart upgrade) as its a 1997ish model with the large oil pump. has anybody solved this problem rather than swapping in the smaller pump? i would like to keep the high output pump as the motor will be big bored and fat cam etc. its a 1997 slr 650 bottom end with twin carb head. |
#51209 | |
Oddometer: 1,083
I think I've always been too old for crashing on pavement. I looped out my NX250 and RD 200 in college. You would think I could wheelie better by now, but I'm still a wuss. CW power definitely helps lengthen the power wheelies. |
01-06-2013, 08:52 AM
#51210 |
Oddometer: 1,083
