01-07-2013, 07:16 PM
#51301 | |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,390
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
01-07-2013, 07:20 PM
#51302 |
x
Oddometer: 128
01-07-2013, 07:22 PM
#51303 | |
Oddometer: 4,390
01-07-2013, 07:41 PM
#51304 |
Crazy Diamond
Oddometer: 726
I bought another set of Easton EXP bars Woods Hi/Freestyle bend and 7/8" to 1 3/8" adapter mounts. The bars will be here tomorrow.
Test fit my the KTM/Suzuki bend Easton EXP bars. Everything will work great togeather I set the bars at 0 degrees and everything bolted up perfectly. This is what your seeing: CR250 USD billet upper triple, Acerbis Supermoto handguards, Cryra front triple handguard mounts, Easton EXP KTM/Suzuki bend bars and XR650L turnsignal mounts. The Cryra front triple handguard mounts are nice and have two handguard mounting holes instead of one like the pictured on the website. ![]() ![]() ![]() ![]() My Woods Hi/Freestyle bars will be here tomorrow. I'll post up pictures of the 3 bends and the 7/8" adapter mounts too.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
01-07-2013, 07:52 PM
#51305 |
Mossy-Back
Oddometer: 706
So, getting away from gearing...
Is anyone running a "low" front fender? Or does anyone have a link to one that would work with a fork brace? Has anyone tried mounting a regular fender to the fork brace to allow more air flow to the head (and deflect water/dirt better)? Pictures???
Evan Ooh-Rah! Once a Marine, always a Marine! '93 XR650L (Xena) |
01-07-2013, 08:12 PM
#51306 | |
Recovering Lurker
Oddometer: 80
, I think allot for the off-roaders frown on the low mount fenders due to the fact they pack mud relay easily and possibly causing drag or lockup on the front tire due to the close proximity of the fender. That being said I have seen a few photos of DR 650s with low mount setups but were bastardized sport bike fenders or a older acerbis low mount front fenders that seem to no longer be manufactured. If your dead set on getting one I think the BMW GS 650 front fender would require the least modification to fit the XRs stock forks with a brace but have not seen it done nor have I mocked one up.
lots of dismantled parts to a 2007 XR650L |
01-07-2013, 08:15 PM
#51307 | |
Oddometer: 86
Just find the one you like and go for it. When you mod a item for a bike it is all just trail and error. But most of the time someone comes up with away to get it done. Kurt
Def. of man: We spend 9 months trying to get out, and the rest of our lives trying to get back in. http://s1085.photobucket.com/albums/...900%20elefant/ |
01-07-2013, 08:19 PM
#51308 | |
Mossy-Back
Oddometer: 706
01-07-2013, 08:49 PM
#51309 |
Bumpy Backroader
Oddometer: 2,415
Ran!
My XRL with an Acerbis Low Fast Front Fender for years without the mud problem. Does 2 things really well. Keeps the Head cooler(more air) and keeps the bike a lot cleaner. Looks a little funny but hey, the Dakar guys do it.
01-07-2013, 08:52 PM
#51310 | |
aka FiddyK
Oddometer: 246
2011 Beta 450 RR - plated ![]() 2008 Honda XR650L - gone but not forgotten ![]() |
01-07-2013, 10:53 PM
#51311 |
Oddometer: 2,944
Recent discussions of the NX650 second gear, and the FMX650 fifth gear exchanges reminded me of an interesting video. This video demonstrates how a six-speed, constant mesh, un-synchronized transmission works in a motorcycle.
Before viewing the video, you can visit the following website which clearly explains how the XR650L transmission operates. http://www.justxr.com/jaw/gearbox.html Here is the operation of 1st gear. Here is the operation of 2nd gear. Here is the operation of 3rd gear. Here is the operation of 4th gear. Here is the operation of 5th gear. The five-speed transmission in the XR650L works exactly as shown in the following video. However, since the video demonstrates a six-speed transmission, merely disregard 4th gear in the video. Gears 1-3 work exactly as shown, and the last two gears demonstrate how 4th gear and 5th gear work for the XR650L transmission. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-07-2013, 11:45 PM
#51312 |
Oddometer: 2,944
The NX650 was imported into the United States in 1988-1989. Replacing the stock second gear on the main shaft with the NX650 second gear, part #23421-MN9-010 will close the gap between 1st and 2nd gear in the stock transmission. The NX650 second gear is part #5 in the following diagram.
![]() The NX650 second gear replaces the top gear on the main shaft. You retain the stock second gear on the countershaft. The NX650 second gear costs $36, and is readily available for sale in the United States. ![]() The FMX650 was never imported into the United States. Therefore, you can only obtain the FMX650 fifth gear from either Europe or Japan. Replacing the stock fifth gear on the countershaft with the FMX650 fifth gear, part #23491-MW2-780, will increase the gap between 4th and 5th gear in the stock transmission, allowing lower engine rpms in fifth gear. The FMX650 fifth gear is part #16 in the following diagram. ![]() The FMX650 fifth gear replaces the bottom gear on the countershaft. You retain the stock fifth gear on the main shaft. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 01-07-2013 at 11:58 PM |
01-08-2013, 05:29 AM
#51313 |
Enjoying my last V8
Oddometer: 5,306
All this talk of changing second gear to close the gap ect., I like the high second. In sand or mud you can hit second and spread out the power pluses from the engine thus keep the wheel from spinning.
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
01-08-2013, 05:41 AM
#51314 | |
Crazy Diamond
Oddometer: 726
Good throttle control has the same effect... ![]()
01-08-2013, 06:10 AM
#51315 | |
Pig Wrangler
Oddometer: 1,566
The tall 2nd is a pain in the rear when working on tight trails (or in a rocky creek bed). 1st is too low, so you jump to 2 and it is too high. So.... you stay in 2nd and abuse the sheeeeit outta your clutch.
