Old 02-14-2013, 07:38 PM   #53926
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,822
add a usb charger port
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 02-14-2013, 07:46 PM   #53927
mendoteach
mendoteach's Avatar
Oddometer: 1,666
The dash is looking good. Keep it up! Maybe you'll make one to fit the Voyager. Hopefully, Trailtech comes out with a fully map, color version one of these days. The market is ready!
Spud, D-Ray is legit! I just watched the oil changing one. SWEET!
mendoteach is offline   Reply With Quote
Old 02-14-2013, 07:57 PM   #53928
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
hmmmm... Is that version 4 that I see on the horizon?
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 02-14-2013, 07:58 PM   #53929
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by Cjsgptx View Post
Any of you guys ever had your XR run like it is missing? When I start mine it just seems like it takes forever for it to warm up and even when i put it on no choke, it sounds like it is missing and sometimes dies. Any ideas? Air filter is good. Has gasoline, lights and horn works. Only thing is, i cant seem to get my spark plug socket down in there to get it out. I am using a 5/8" sparkplug socket. Is thier a special size i dont know about? I am a noob with this bike so take it easy on me!
Chris
You need a thin-wall spark plug socket, such as the one Honda "used" to supply in the tool kit. You can get the "official" spark plug socket from Honda. It's part #2 in the following diagram.
The spark plug socket is Honda part #89216-MJ1-000, and it sells for $14.45. I'm sure you can get an aftermarket socket which will also work.
Spud
Old 02-14-2013, 08:01 PM   #53930
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
X2 on the dashboard, Red!
D-Ray is a good ol' boy; I would love to go riding with him!
Spud
Old 02-14-2013, 08:04 PM   #53931
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Definitely add a USB port, and anything else you can think of! I'm designing a mount for a Trail Tech Vapor I plan to install on my "new to me," CRF250X. Do you plan to secure the mount to the handlebars bolts?
Spud
Old 02-14-2013, 08:06 PM   #53932
GPrairie_Rider
Dirt Junkie
Oddometer: 931
Spud
Thanks Spud! Any way to help me about my bike running like shit?
Current Bike: 2013 Triumph Tiger 800XC
I deserve the best, anything less is unacceptable.
GPrairie_Rider is offline   Reply With Quote
Old 02-14-2013, 08:20 PM   #53933
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
A poorly running engine can be caused by problems in one of the four, following areas.
1) Spark
2) Fuel
3) Air
4) Compression
It's hard to tell what is causing the problem until you do some testing. I would start with the spark plug, but you need a new socket before you can remove it.
Are the jets clean in your carburetor? Have you cleaned the air filter? Does the bike have good compression?
Spud
Old 02-14-2013, 08:20 PM   #53934
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,309
Chris
You need either the spark plug wrench that came in the stock tool kit, or something like this special socket from Motion Pro.
The spark plug is 18mm, but because of how deep it is in the head, and some other obstructions on the head you can't get a standard 18mm spark plug socket down to it. You need a thin wall design. The tool kit spark plug socket can be ordered from your favorite Honda dealer, or you can buy the one pictured and linked above. My parts book lists part # 89216-MJ1-000 for the Honda tool. There may be other options but I don't know what they are. I would also note that about 2007 or 2008 Honda quit including the tool kit on the bike when new. You now have to buy it separately if you want it.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 02-14-2013, 08:45 PM   #53935
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 7,107
Originally Posted by ADV BUM View Post
If there was anytime you could afford Giantloop stuff, now is the time. They are improving/ changing models so some stores have the old stock on clearance. I just picked up the older mojavi. I already had the coyote. Mojavi is great for everyday stuff, but if your really camping or traveling off the bike the coyote holds much more.
And the Great Basin holds even more!
What's the best place to buy this stuff on sale?
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 02-14-2013, 08:46 PM   #53936
Sierra Thumper
Oddometer: 641
Question Is a Sudco FCR41 flatside pumper carb worth the upgrade on an internally stock motor?
A friend has a Sudco FCR41 flatslide pumper carb for sale.....I was thinking of picking it up, but I wanted to know from you guys what performance gains I would get on an internally stock motor. I have a Uni filter, desnorkeled and cut air box, full exhaust and the stock carb with Daves Mods. Will the FCR give me any more overall power than the stock carb?
I'm not sure I want to go through the carb swapping effort unless I can get more power......I'm happy enough with the throttle response of the stock carb that I don't want the hassle of changing over just for that.
C'mon pumper guys, lead me down the right path
Also, would I need to get a different throttle or cables? And I'm assuming I'd need an adapter or 2 of some kind to mount the carb up?
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-14-2013, 08:47 PM   #53937
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 7,107
Originally Posted by elsalvadorklr View Post
... something we forget entirely is that all of us ADD weight, be it skidplate, bar risers, barkbusters, bigger pegs, racks etc...
Not watching out diet...
OOPS Red beat me to it again
Old 02-14-2013, 08:49 PM   #53938
joexr
Oddometer: 3,773
Not more power , just more instant power thru better throttle response.
Old 02-14-2013, 08:52 PM   #53939
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 7,107
Originally Posted by Sierra Thumper View Post
I guess I'm the exception the only weight added to my bike is the skidplate.......but the stock rockguard had to come off for it. Besides that my bike is minus some stock parts, and other parts have been replaced with lighter aftermarket stuff. My bikes ALL dirt bike......well as close as a street legal dualsport can get
Just me, my machine and my backpack
That makes two of us, so I guess you're not THE exception.
Old 02-14-2013, 08:53 PM   #53940
Mossy-Back
Brown Falcon
Mossy-Back's Avatar
Oddometer: 1,657
Chris
For mine I use a deep 18mm socket, a 3/8 u-joint, and a long extension. Works for me.
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Times are GMT -7.   It's 06:53 AM.
