Old 03-20-2013, 12:47 PM   #56566
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
Originally Posted by joexr View Post
Is that a flying mile or does that include stopping area?
Standing start to one mile finish line. Half mile run out. They have it at an airport runway.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 03-20-2013, 12:49 PM   #56567
joexr
Oddometer: 3,773
Ive heard of it and I think saw it on the tube before.
Old 03-20-2013, 12:51 PM   #56568
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
I cut a strip the width of the core of my FMF Titanium4 and a couple of inches longer. I gave it a full twist and put it thru the core. Then I cut a disc of it and put it under the end cap. The can has different tips to change backpressure. The big tip , its better on the bottom and the medium its better on top , but louder. I found a happy medium with the big tip and the perforated metal behind it.
ah for the exhaust. gotcha.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 03-20-2013, 12:57 PM   #56569
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
Originally Posted by taco250 View Post
Maybe not. .049 steel slotted (or drilled) and welded to the tube would work fine I think. The fins could also be positioned horizontally along the length of the tube which would allow air flow over the engine and provide more surface area for cooling.
If you went with a bolt-on AL type it would only have to be 3/16 to be durable enough.
I have also though of making a hollow handle to attach to the down tube on one or two sides of the down tube. This could be bent tubing. More oil and some cooling. I have seen coolers made like this for Hydraulic tanks.
And i have been wanting to install this somewhere. I removed it from a Sicon radiator. It's for power steering cooling. It's two brass tubes brazed together. A lot of surface area there. Oil flows in the side at the hose barbs. It could go in the return line. Position so air from the "lips" blows through.
Regards
Fritzcoinc
Old 03-20-2013, 01:06 PM   #56570
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
It's a " run what ya brung" deal.
144 MPH, 65 GTO
Chevy HHR, 136 MPH
501 Cadie. More show than go.
This went nowwhere. Turbo Bagger Harley.
The old SoCal. drop tank with turbo flathead Ford. A replicia. Just a show run.
Regards
Fritzcoinc
Old 03-20-2013, 01:11 PM   #56571
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
Which of the two XR's Only XR650R Skid Plates works the best, or fits, or is cooler?
http://www.xrsonly.com/xrs-only-skid-plate-honda-xr650r
http://www.xrsonly.com/xrs-only-skid...xr650r-bolt-on
Old 03-20-2013, 01:17 PM   #56572
bwalsh
bwalsh's Avatar
Oddometer: 11,146
Originally Posted by techforlife View Post
I haveta agree.....it`ll hold the heat in at all times,,and only benefit when sitting idling for long periods.which should be avoided on an air cooled bike for the most part...if someone could make alloy fins that clamped on, that might help,,until mud caked on and made them useless..
Oil cooler....or leave it alone..
Maybe Fritzcoinc.com can start sellin oil coolers...shaped like texas or sumpin
B
What I have always though about doing was to machine a finned square tube and weld it in place of the smooth OEM down tube.
To keep heat from the header affecting the oil in the down tube what about making heat shields that bolt on with the header, like what goes around a catalytic converter? Should be fairly easy to make with an old auto shield, some tin snips and a drill for the mounting holes.
The Horizontal fins welded to the down tube that taco mentioned sounds interesting as does the finned oil line(s) OnO mentioned.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 03-20-2013, 01:30 PM   #56573
bwalsh
bwalsh's Avatar
Oddometer: 11,146
Originally Posted by nic579 View Post
You could cut some 2-3 inch strips of that, how ever long you wanted, make a bend at about 1/2 inch of the 2-3 inches, with the rest sticking away from the tube as the heat sink, and attach it to the tube with a few hose clamps.
Typical ford, on the end of a tow strap.
2004 XR650L
Old 03-20-2013, 01:41 PM   #56574
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
A little something like this:
Hardest part of all that would be the welding.
Old 03-20-2013, 01:56 PM   #56575
joexr
Oddometer: 3,773
was thinking vertical fins. Less dirt or mud catching.
Old 03-20-2013, 02:09 PM   #56576
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
Even better idea.
Old 03-20-2013, 02:11 PM   #56577
jub jub
frumiousbandersnatch
jub jub's Avatar
Oddometer: 14,031
That's actually a 64 LeMans.
jub jub is offline   Reply With Quote
Old 03-20-2013, 02:18 PM   #56578
joexr
Oddometer: 3,773
Originally Posted by beechum1 View Post
Even better idea.
Hopefully someone will see this and come up with something possibly flat that could either be broke at 90 degrees or cut into strips. Aluminum would be the HOT ticket. Or maybe some type of corrugated aluminum for surface area.
Old 03-20-2013, 02:20 PM   #56579
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,280
Well the first one is cooler....whether it fits or not i`m not sure,,i think the old design that did fit is no longer being made.........
To make it really cool you gotta have lots of holes in it,,or it`ll just suck
B
techforlife is online now   Reply With Quote
Old 03-20-2013, 02:22 PM   #56580
techforlife
CDI REPAIR
Oddometer: 4,280
Another good idea...heat shields kinda like they put on 2 stroke pipes to prevent dents in the pipe.just need to space them off the pipe alittle..
B
Times are GMT -7.   It's 06:20 PM.
