Old 03-28-2013, 08:52 PM   #57001
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by Sycklemotor View Post
I recently purchased a 2007 XRL that I plan to tear down to the frame and build a new bike my way.I have purchased the Emig triple clamps and a set of 2003 CRF450R forks. What I'm wondering is if anyone on the forum has advice for fork set up. My intention was to rebuild the fork but I am unsure about spring rates etc.
Any help/advice would be greatly appreciated.
I will also be selling off the stock front end,wheels, bodywork,tank,speedo- just about everything but the frame and motor. If anyone has interest you can call me at 314-277-8744. I will be listing those in the classifieds soon.
Oh, I have a feeling that this is going to be a lot of fun. Sycklemotor, please document your build along the way with pictures. BTW: What is "my way" when it comes to a build?
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 03-28-2013, 09:18 PM   #57002
Mero
Oddometer: 301
supermoto wheels
I want to be able to just switch rims real fast if I want to go for a good street ride. I remember the one guy guy cbe wheels but that's to much hassle. im looking for a near bolt on easy swap back and forth from street wheels and tires to dirt.
Whats my best option?
Mero is offline   Reply With Quote
Old 03-28-2013, 09:41 PM   #57003
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,278
Another set of stock wheels with 90/10 tires is the cheapest way to go.
Any conversion will require some amount of costly machine work and material to make spacers and such.
If you want to buy a set of SM wheels, new and ready to install, you are looking at about $1100. That includes 320MM disc, caliper bracket, and tires. Complete sets are available. You can whittle that number down to about $700 by finding a set of hubs and having them laced to new rims or lace your self and knock off another $200 or so. A used set of SM wheels for the XRL sell in the $700 range.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 03-28-2013, 09:46 PM   #57004
RZRob
RZRob's Avatar
Oddometer: 1,749
It's Alive
Hey, wanted to give props to Brian (Techforlife) for the awesome CDI repair service.
Normally I like to do all my own repairs, and he even tells you how he does it (with pictures), but while I can solder etc., this task was a bit over my head due to too many solder joints (points of failure).
Brian turned it around in a couple days and the whole process was ridiculously cheap. Please, overpay him.
Really, you can judge the quality from the outside. Even the surgical scars are barely perceptible.
RZ Rob
RZRob is offline   Reply With Quote
Old 03-28-2013, 09:51 PM   #57005
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,278
Originally Posted by Ray Paul View Post
Fritz, what kind of ds riding you have around there ? Ya'll ever get up any rides in your area ?
Well sir, dirt roads to the NE and NW of houston are a fav. The Sam Houston Forest has many miles of single track trails. There are three MX tracks in the Houston area and they all have trails. The group I ride with just got back from the Big Bend and that is a stellar place to ride. i missed that due to a health issue. The endless trails of Colorado are a once a year event usually around late Sept. New Mex. around Silverton is looking like a place to go as well. I am wierd, no shocket there aye, and like to ride on the beach. Plenty of that here. How bout yall?
Regards
Fritzcoinc
Old 03-28-2013, 09:54 PM   #57006
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,278
Att. Marlinjames
Regards
Fritzcoinc
Old 03-28-2013, 09:57 PM   #57007
RZRob
RZRob's Avatar
Oddometer: 1,749
Originally Posted by Barron View Post
Make sure the wires are intact from the pulse generator coming out of the right crankcase cover. Then check the resistance on it. I don't have my manual with me or I'd give you the spec for it. There is probably a really easy way to test whether or not that thing is starting the spark chain of events... but again I don't have my manual with me. Hopefully one of the fine gentlemen here will post up what you need...You might want to make sure your wires and connectors are securely attached (the ground under the seat and the negative from the battery to the engine (next to the starter) are a couple important ones)
FWIW, I would go with Guinness instead of tea, after all, Guinness is good for you!
-Barron
I can vouch for everything he said about the ground wires (just go tighten them), then check the wires/switches (key/run). Stupid things are most likely the culprit - well from my experience.
RZ Rob
Old 03-28-2013, 10:00 PM   #57008
Mero
Oddometer: 301
Thanks, I like the idea of the SM wheels so I can get some wider tires on there for dipping into the corners. How hard is it to spoke a wheel?
If I wanted to go supermoto wheels what would I be looking for as far as size to fit the axle and everything
Old 03-28-2013, 10:11 PM   #57009
RZRob
RZRob's Avatar
Oddometer: 1,749
I drove to the Houston area (Katy) to visit a good friend, ride the back roads and pick up an RZ. While Texas is flatter than Paris Hilton, the back roads were a blast to terrorize. I can imagine the dirt trails back there are just as rewarding.
You can drive towards San Antonio and scoop up the "Hill Country." I drove through and kick myself for not unloading my Ape here. Outside the world famous AF1 in New Braunfels (Hill Country).
RZ Rob
Old 03-28-2013, 10:16 PM   #57010
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 384
Originally Posted by RZRob View Post
mmmm... pacifico......... daddy like
2008 Honda CRF450X - plated
2007 KTM 450 XCW - a little sip of the kool-aid (gone)
2011 Beta 450 RR - plated (gone. had my sexy italian fling)
2008 Honda XR650L - (gone)
3girlsdad is offline   Reply With Quote
Old 03-28-2013, 10:33 PM   #57011
RZRob
RZRob's Avatar
Oddometer: 1,749
One of my favorites. I've been known to down a few...
RZ Rob
Old 03-28-2013, 11:11 PM   #57012
XR650L
XR650L's Avatar
Oddometer: 225
Is this the CDI.?
http://www.xrsonly.com/02-honda-xr65...nition-control
Busy creating a Monster XR
XR650L is offline   Reply With Quote
Old 03-28-2013, 11:18 PM   #57013
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by XR650L View Post
Yes, that's the CDI unit for the Honda XR650L. However, that price is too high. This price is more competitive.
http://www.ronayers.com/ProductDetails/N/687/SKU/446310
Spud
Old 03-28-2013, 11:21 PM   #57014
XR650L
XR650L's Avatar
Oddometer: 225
Spud
Thanks Spud
Old 03-29-2013, 04:44 AM   #57015
mcma111
mcma111's Avatar
Oddometer: 12,880
Cdi
Or here:
http://www.partzilla.com/parts/searc...ERY/parts.html
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 09:52 AM.
