Old 04-26-2013, 07:41 AM   #57976
RZRob
RZRob's Avatar
Oddometer: 1,522
Originally Posted by fritzcoinc View Post
I know that I am an outstanding individual but why am I so blessed to have a XRL that does not vibrate?
I agree with Fritz, these bikes don't vibrate that bad at all. My rubber mounts were just for the electronics - mimicking the way the speedo is mounted.
Now, I had an RZ500 once with a separate balancer that was 180 degrees off. That vibrated.
RZ Rob
RZRob is offline   Reply With Quote
Old 04-26-2013, 07:55 AM   #57977
mendoteach
mendoteach's Avatar
Oddometer: 1,550
Originally Posted by my6 View Post
Some guy told me that because his brother said so. He had one. I suspected it was bullshit. Now I know
mendoteach is offline   Reply With Quote
Old 04-26-2013, 07:57 AM   #57978
mendoteach
mendoteach's Avatar
Oddometer: 1,550
My bike vibrates less than any big single I've ridden, and even less now that it's a 750. It really has no right to be so smooth.
Old 04-26-2013, 09:21 AM   #57979
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Originally Posted by wbedient View Post
My XR650L vibrates horribly on the highway... and my last bike was a BUELL
Can you give more details about these rubber mounts?
Where?
What did you use?
etc.
Make sure all your mounts are tight and none are missing. Dont ask...
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-26-2013, 11:36 AM   #57980
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
So before I order just rockers for my 09 Piggy for my hotcam, what other parts should be replaced? Sub rockers? Everything? Or just the cam chain and rockers? I'm trying to put together a list of what I need to make the hotcam as good as it can get (prevent any faultiness).
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 04-26-2013, 12:23 PM   #57981
chipbl
chipbl's Avatar
Oddometer: 285
Originally Posted by Brown Falcon View Post
You need to quit turning left...
I noticed that too...I must be wired wrong.
2008 XR650L, tons of goodies.
chipbl is offline   Reply With Quote
Old 04-26-2013, 01:24 PM   #57982
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,513
Your stock rockers should be fine with the Hotcam. Are your OE rockers ground up? If not, leave 'em alone.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 04-26-2013, 02:05 PM   #57983
Ben99r1
Ben99r1's Avatar
Oddometer: 3,030
Originally Posted by camperdad View Post
I am prepping two XR650ls for the TAT. I have seen several pictures of gussets reinforcing the rear sub-frame and was wondering how many actually have done it? What type of welding? Arc, Tig, Mig? It is one a small tube so I'm assuming you could cause more harm than good if you burn through it. My frames are fine but just looking to prevent any catastrophic failure. It looks like I will need to remove the batt box, fender and airbox.
I just tig welded some flat stock to my frame. It was the second time that I have welded anything. I am sure it would look better if some else did it.
You might also want to consider some side racks like these. I got mine on ebay when I bought some.
Ben99r1 is offline   Reply With Quote
Old 04-26-2013, 03:31 PM   #57984
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,282
No offense to ThumpNRED at all........but,,i would put new rockers in anytime a cam is changed,it will definately wear better,last longer.......
You can reuse the OE rockers if they are perfect,but replacing them is best..
Make damn sure you have good oil flow to the head,use REDLINE assembly lube on the cam/rockers is best.........
Make sure you follow HotCams clearance specs,not Hondas......
B
techforlife is offline   Reply With Quote
Old 04-26-2013, 03:54 PM   #57985
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,816
B
+1, it is always a recommendation, a strong recommendation, when installing a new cam to also install new rockers or lifters from the same manufacturer. Doing this you know the parts have been tested and proven to be compatible. Check the cam bearing clearance in the head as well.
If not mentioned elsewhere, new valve springs that are rated for the lift of your new cam are very important. If the wire size of the spring is too big the spring coils will " stack up" or " bind under the increased lift of the new cam. New springs may require new spring retainers. New valves and guides should be used as the original valves stems have a wear pattern as a result of the lift of the original cam. More lift will force an unworn portion of the valve stem into the valve guide causing the valve guide to wear into a funnel shape. This will allow the valve stem to move side to side and accelerate guide and seat wear. If your engine is very low hour, only the correct springs are a concern along with a close dimensional inspection of all parts.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 04-26-2013, 04:03 PM   #57986
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,816
Originally Posted by mendoteach View Post
The only down side is that chicks dig guys who ride KLRs.
Wrong:
Regards
Fritzcoinc
Old 04-26-2013, 05:22 PM   #57987
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,513
I cant argue your logic. When I installed my cam, my OE rockers were like new.
B
Old 04-26-2013, 08:40 PM   #57988
mendoteach
mendoteach's Avatar
Oddometer: 1,550
Wrong:
Sarcasm people! KLRS riders are so cheap I don't think any chicks would date them.
Old 04-26-2013, 08:43 PM   #57989
mendoteach
mendoteach's Avatar
Oddometer: 1,550
Did I just say that? Kidding KLRS riders and trolls
Old 04-26-2013, 09:02 PM   #57990
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,578
Any us XRL riders aren't cheap?
We probably spend more on beer, judging by the conversation on this thread...
I'm enjoying a Lagunitas Little Sumpin' Sumpin' Ale right now! Delicious!
Evan
2013 Husqvarna Strada
'93 XR650L (Gone, but missed)
Ooh-Rah! Once a Marine, always a Marine!
Originally Posted by kenny61 View Post
figures...my stud was rusty I played with my nuts a little and it cranked right over
Mossy-Back is offline   Reply With Quote
Times are GMT -7.   It's 05:56 PM.
