05-02-2006, 07:33 PM
#586 | |
Yea buddy!
Oddometer: 340
my IMS 4.0 gal get only about 15 miles on reserve, but I can lay the bike on it's left side, like you mentioned, and extend that another 10 miles or so....of course, my bike has a 41mm flat slide and a 680 big bore kit and aggressive gearing, so the mileage is my least concern.... |
05-02-2006, 07:38 PM
#587 |
Yea buddy!
Oddometer: 340
here's my "big pig"pic was taken at coyote cal's in Baja last weekend
05-02-2006, 07:41 PM
#588 |
Getting back in the game!
Oddometer: 41
Disappointed!
Well,
I finally took my bike for some dirt riding. The first experience was quite disappointing... May be I was expecting too much from the bike and myself. Admittedly, I am out of practice... My biggest complaint is the gearing is way too tall for any kind of good dirt riding other than the gravel roads. This bike should have SIX gears with the 1st being much lower than what it is... Then it will make a true dual sports bike. I thought about changing the sprockets, but am concerned about highway riding will be compromised. What is your expert opinion on this? How many teeth do the current sprockets have? What do you recommend I swap it with? Where to buy? Would I need a new chain too? It takes some serious muscle to maneuver this bike. It is way too big and heavy. The suspension is very soft too (It still have the factory settings). I stalled it while crossing a stream (about knee deep with lots of slippery stone) ![]() I now have 500 miles on it. When can I start riding it hardJ? Full throttle operation? When can I wheelie? A local Honda shop told me that I should wait till I get my first service (600 miles)…. Someone was saying after 1000 miles. Any advise, please? Speaking of the first service… Do you suggest taking it to a Honda dealer? Is it worth the money… or should I do it myself? Sorry for the long post. Thanks in advance for all your expert opinions. -- Sincerely, Shair A. Khan |
05-02-2006, 07:53 PM
#589 | |
one man wolfpack
Oddometer: 4,301
If it were my bike I'd be riding the heck out of it already. change the oil & filter, check the valves and then ride it like you stole it!!
Check out the Blog! MotoGraphic MotoGraphic Tumblr Chad Berger KTM950ADV, DR650 Lone Wolf Expeditions |
05-02-2006, 07:54 PM
#590 | |
Oddometer: 41
Thanks. -- Sincerely, Shair A. Khan |
05-02-2006, 07:55 PM
#591 | |
one man wolfpack
Oddometer: 4,301
you rode in Baja with Gripsters? Did ya stay mostly to the roads or were you on trails? I like the header wrap! Hows that working out for ya?
05-02-2006, 07:59 PM
#592 | |
one man wolfpack
Oddometer: 4,301
This is what you need! http://www.rockymountainatv.com/prod...0&navType=type you can get them at most motorcycle dealers. auto parts places may have them too.
05-02-2006, 08:13 PM
#593 | |
Oddometer: 41
-- S. A. Khan |
05-02-2006, 09:16 PM
#594 | |
Yea buddy!
Oddometer: 340
we did some trails, but mostly on road......I've often found that the rider makes more of a difference than the tires, but of course, for the knarly stuff, you must have knobs....I had no problems on the lite trails we did, which were kinda rocky and maybe Gripsters are better on rocks than knobs anyway? the header wrap was put on by the previous owner and he did all the motor work,........41 FCR, big bore kit, hot cams, White Bros full exhaust, de-smogged, all unecessary shite removed and aggressive gearing....needless to say, this bike is not slow ,it's light (for an XR-L) and it'll power wheelie easliy in the first two gears...but the header wrap seems to work fine for keeping leg from getting burned....the only precaution I take is that if I get it wet, I let the bike idle for 5 mins after getting it wet to evaporate all the water in and under the wrap...... |
05-03-2006, 01:28 PM
#595 |
Druid
Oddometer: 2,075
Any of you guys gonna make this?
http://www.advrider.com/forums/showthread.php?t=131244 I know there are a few of you in VA and Ohio. I am going to hook up with AndyB from here and ride up. Let me know and well try to ride up together.
Klaatu barada nikto |
05-03-2006, 10:17 PM
#596 | |
Oddometer: 37
fuel filter
05-04-2006, 10:10 AM
#597 | |
Oddometer: 3,070
BTW, if you ever suspect water in the gas, that little bowl is a great place to look for it. Dave |
05-04-2006, 02:37 PM
#598 |
Ribs....for her pleasure
Oddometer: 3,057
I concur, doctor.
When you preflight an airplane, you drain a sample out of each tank, and if there's water in it, it will show up there...in the lowest part of the fuel system.
Chris Schreckendgust Field Florence, MT |
05-06-2006, 11:29 AM
#599 |
Oddometer: 41
Hi all,
1. What are the valve clearances for 2006 XR650L? 2. Is there any particular procedure / advise from your experience & knowledge that I should pay special attention to, while doing the valve adjustment myself? One question though... How do you make sure that the piston is EXACTLY at TDC of the compression stroke? If I recall correctly from my motorcycling days :) there used to be a mark on the magnet to align with the mark on magnet housing.... Please advice. 3. What are the symptoms if the valves are not properly adjusted.... i.e. symptoms of too little or too much clearance. 4. Thank you all for helping with the fuel filter question. I went to a local Auto parts shop and bought 2 filters.... don't know which one of them I will install today. One is a small car fuel filter made of metal, so I can't really tell what the actual filter element is. The other one is from the lawnmower section and is made out of plastic. Does it make any difference which one I use.... I was thinking the one for cars would probably be a better quality? What is your take? I am not sure how to attach a picture... please see if the following link works! http://www.advrider.com/forums/attac...1&d=1146939885 I appreciate y’alls help. Thank you. -- Sincerely, Shair A. Khan |
05-07-2006, 10:27 AM
#600 | |
Oddometer: 41
Does 14/45 provide lower final drive ratio as compared to 15/48? Which sproket is easier to change? I did the first oil/filter change about 2 months ago at 300miles/7 months. Should I change again at the first service 600miles.... I was hoping I would do the next at 1000 miles. -- Sincerely, Shair A. Khan |
