Old 06-15-2009, 10:17 PM   #6796
lasercustoms
lasercustoms's Avatar
Oddometer: 596
This has the makings of a really stupid question but here it goes.
I pulled off the valve stem while taking off my rear tire. The tube is a super duty moose racing tube. The way the stem came out it looks like you could just rubber cement it back in place and go. Has anyone done that before?
I know it's just a tube but that joker is thick. It maybe a 20 dollar tube or something.
I love Jesus. Even if I don't act like it all the time.
lasercustoms is offline   Reply With Quote
Old 06-15-2009, 10:32 PM   #6797
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,462
Originally Posted by XR650L_Dave
Am I the only guy that keeps last season's oil around so I cab do 3 oil changes with old oil (to get the water out) before doing a change with good oil?
Actually, it took me 4 or 5 changes.
Dave
Excellent idea... Hadn't thought of that.
"I intend to live forever. So far, so good" Steven Wright
"If you choose not to decide, you still have made a choice" Rush
2004 XR650L & 2003 ST1300
mchester is offline   Reply With Quote
Old 06-15-2009, 10:34 PM   #6798
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,462
Originally Posted by honda lou
Pardon me but but don't you go LEANER at altitude? As in a SMALLER jet?
BTW... Lou, cool it on the ALL CAP's please. We can hear you...
yes you are right about the elevation. i got it mixed up. you do go leaner. about 1 size every 1700-2000 feet diference. i got rid of the caps this time.[/quote]
And, in my experience, most folks that announce their "expertise" in a given area usually are not so much so... Just an observation...
Old 06-15-2009, 10:46 PM   #6799
Ben99r1
Ben99r1's Avatar
Oddometer: 3,044
Lasrecustoms. If you ride any kind of street I would not use a super duty tube. The stem go bad also they are hard to install out in the field. I been having luck with a med duty tube. Leave that tube to a full time dirt bike. No you can't rubber cement it back it wont hold. The tube will flex in the tire sometimes when you remove a tire you will even see twist makes on tubes to. Ben
Ben99r1 screwed with this post 06-16-2009 at 03:55 PM
Ben99r1 is offline   Reply With Quote
Old 06-15-2009, 10:51 PM   #6800
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,462
I run an HSR42 Mikuni as well. Which needle are you running? I use a j8-8ddy01-97 (center clip), on advice from XRs Only, but I'm still not convinced I'm quite "there" yet. Next step is some dyno tuning time I think. I currently have a 20 pilot, 150 main, & 45 leak.
Laser, you must have the most creative spelling of anyone I've ever read. According to Mark Twain, you have a very interesting mind indeed.
"It's a damn poor mind that can think of only one way to spell a word!" Mark Twain
Originally Posted by Wattner
Hey Lou,
I have the 42 mm. Mikuni pumper carb.
The pilot is a 22.5, and the main is a 150
The needle is in the center.
I would be real curious to get the carb all perfectly dialed in... I'll be happy to send it to you to play with and see if you like it... I was told by a guy at Sudco that it is the way to go over the Keihin, but I don't really know for sure???? I had an FCR pumper as well as the Flat slide in the past. I really have not had this carb all dialed in to see if I really like it or not. I have several rides but wanted to drive the FOKKER off a cliff until I discovered the cracked boot. I have used RTV and sealed the crack, Hopefully I can get some saddle time soon and see if I have the problem solved. I would like to have a Keihin pumper to swap back and forth to play with. I need to port the new boot and play... I may pick up a Keihin from Sudco and compare, then sell the one that places second in my liking....
I was thinking it was the Keihin I had, but after review it was the Mikuni... I had them reversed mentally.... I seem to do that more and more and more???
Old 06-16-2009, 05:56 AM   #6801
zcooney
Ask about my red wings
zcooney's Avatar
Oddometer: 146
I have my head off to correct some oil burning issues. What should I inspect on the valves to make sure they are good to go when I reassemble?
The valves are not suspected to be the culprit, no smoke at start up, just when revved. I'm guessing I can use some seafoam to remove the carbon deposits on the valves?
zcooney is offline   Reply With Quote
Old 06-16-2009, 06:00 AM   #6802
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
NO wont work. Try it if you have time to put a tube in later.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-16-2009, 06:05 AM   #6803
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
The manual gives a method to check the valves.
The side to side movement is checked.
A wire wheel is usually used to remove carbon from the valves.
You may wish to have the seats re-ground.
But I gota ask, how much oil was it using?
Did you check all the breather stuff first?
Mine uses 4 OZ per 200 miles and there is no smoke at all.
Regards
Fritzcoinc
Old 06-16-2009, 06:25 AM   #6804
zcooney
zcooney's Avatar
Oddometer: 146
I did check the breather from the case to the airbox, disconnected it even, still, lots of smoke. The bike is de-smogged and uncorked. As for oil usage, I have no idea how much it used, I never checked, after leaving a smoke screen everywhere I went, I just topped it off and tore it down.
Old 06-16-2009, 07:43 AM   #6805
seantx
seantx's Avatar
Oddometer: 628
Originally Posted by Ben99r1
Lasrecustoms. If you ride any kind of street I would not use a super duty tube. The stem go bad also they are hard to install out in the field. I been having luck with a med duty tube. Leave that tube to a full time dirt bike. No you can rubber cement it back it wont hold. The tube will flex in the tire sometimes when you remove a tire you will even see twist makes on tubes to. Ben
Agreed. HD tubes are the debbil.
Replace that tube laser.
seantx is offline   Reply With Quote
Old 06-16-2009, 07:48 AM   #6806
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,144
I use HD tubes in both my XR and TE. Never had a problem - including a recent 500 mile day on the XR that included a fair bit of tar.
YMMV and all that...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 06-16-2009, 10:45 AM   #6807
Natnewt
Natnewt's Avatar
Oddometer: 485
For any of you that have done the Jagg oil cooler install, if you have pics of your line setup, could you show them to me so I don't run into any issues when I do my installation. Thanks alot!
Natnewt is offline   Reply With Quote
Old 06-16-2009, 03:19 PM   #6808
seantx
seantx's Avatar
Oddometer: 628
I'm sure they work fine but they are a PITA to install. At least for my admittedly limited tire changing fu.
Old 06-16-2009, 03:31 PM   #6809
Mercury264
Mercury264's Avatar
Oddometer: 22,144
Never had an issue. Partially inflate them to give them some shape - at home I also coat them in baby powder which also helps.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 06-16-2009, 04:02 PM   #6810
Ben99r1
Ben99r1's Avatar
Oddometer: 3,044
Do you carry them as spares too? I would think they would take up to much space. I always carry a front and rear spare. Ben
Times are GMT -7.   It's 05:32 PM.
