Old 07-13-2009, 09:35 PM   #7441
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
I was thinking about getting this: http://www.jcwhitney.com/Fuel-Filter...4694_10111.jcw
Bbasso is offline   Reply With Quote
Old 07-13-2009, 09:37 PM   #7442
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
Does anyone have something like this on their bike XRL?
Old 07-13-2009, 09:43 PM   #7443
Nasty Rider
Nasty Rider's Avatar
Oddometer: 173
Finally some pics of my bike it's this is before any mods.
This is the Big Red Pig that will tear the hell out of Lost Riders
Husky
Nasty Rider is offline   Reply With Quote
Old 07-13-2009, 10:42 PM   #7444
LostRider
Motorcycle Addict
LostRider's Avatar
Oddometer: 237
Husky
Ahhh little bro... maybe some day your pig will turn into a Husky! Probably not but you can always dream.
All kidding aside the XRL is one bad ass bike!
Some things are just to much fun to stop doing.
LostRider screwed with this post 07-14-2009 at 04:40 AM
LostRider is offline   Reply With Quote
Old 07-13-2009, 11:06 PM   #7445
Spicy McHaggis
Darth Peach's cracker...
Spicy McHaggis's Avatar
Oddometer: 3,789
Suppose it's my turn for some pictures...
2006 DR650
Spicy McHaggis is offline   Reply With Quote
Old 07-13-2009, 11:12 PM   #7446
SenorPeligro
Proper Naughty
SenorPeligro's Avatar
Oddometer: 1,962
Originally Posted by debaisley
what is the usual cause for oil consumption ? I have already disconnected the crankcase breather hose from the airbox and gave it its own filter. I have to add about a quart every 250 miles , I think thats a little excessive. But it runs perfect, and i never see smoke , what do you guys think could be going on? by the way , it doesnt matter what type of riding im doing , trails or highway.
Out of curiosity you don't have an 08 do you?
It's just good clean dirt.
Video Antics
Where am I Riding?
Baja Blitz Yard Sale
SenorPeligro is offline   Reply With Quote
Old 07-14-2009, 03:46 AM   #7447
debaisley
debaisley's Avatar
Oddometer: 1,424
nope , its a 93
debaisley is offline   Reply With Quote
Old 07-14-2009, 05:01 AM   #7448
Nasty Rider
Oddometer: 173
What is that the pic you took after you ran out of gas You are right though the XRL is a bad ass bike
Old 07-14-2009, 05:04 AM   #7449
Nasty Rider
Oddometer: 173
Oh nice bike but you need desmog and uncork it let that Pig breathe.
Old 07-14-2009, 05:06 AM   #7450
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Originally Posted by Bbasso
I am also interested in getting a recommendation for a fuel filter before I install my Acerbis tank. The fuel lines that came with the Acerbis are 1/4".
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 07-14-2009, 06:42 AM   #7451
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Scrap that shitty fuel line from Acerbis. I use these with good results on my Acerbis Tank:
http://www.rockymountainatv.com/prod...dFamilyId=3769
LaOutbackTrail is offline   Reply With Quote
Old 07-14-2009, 08:03 AM   #7452
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
Originally Posted by fritzcoinc
The valve adjustment can affect the idel. I notice a slight need to increase the carb. idel screw as the adjustment time approaches. But not like your talking. Are you sure you got the right side exhaust valve set correctly? This is the one with the auto de-compress cam.
As you rotate the engine and get to TDC you should hear the auto de-comp. cam fall out. Also you can set this valve just past TDC. I use 15 deg ATDC.
PS: also if the engine is high milage, leave a feeler gauge in one valve as you adjust the other. This takes the slack out of the rocker shaft. I noticed that when I set one valve, then set the other, then re-checked the first it was off. Using two gauges and leaving one in the adjusted valve stopped this.
Additionally, try draining the carb. float bowl. There is a screw on the bottom side of the left side of the carb. When you back out the screw it will drain the fuel bowl completely. Drain it then open the petcock and flush some more fuel through.
Thanks Fitz - I'll check the valves again. I did think it was too much of a coincedence - I check the valves every time I change the oil at 3K and this is the first time I have had to adjust the valves for about 9K miles.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-14-2009, 08:04 AM   #7453
Mercury264
Mercury264's Avatar
Oddometer: 22,168
Originally Posted by abrasive
Just had the same problem with my '00 XRL. Idle would be super fast or normal, seemingly at random. Eventually (30 seconds or longer) the idle would drop to normal.
Pulled the carb, cleaned the hell out of it, put it back together. Fired right up and the problem seems to be gone. Sticky slide maybe (didn't seem to be) or some crud in there somewhere?
Before I pulled the carb, I scoured the boards for hints on what the problem might be. It's not unheard-of, but nobody has the sure-fire fix. One guy did say that adjusting his valves cured it, but that's a little wonky to me.
Dave
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-14-2009, 08:06 AM   #7454
Mercury264
Mercury264's Avatar
Oddometer: 22,168
Originally Posted by arkansawyer
A tight valve will ruin idle and starting. Air leaks between carb and head also.
Interesting - I adjusted the valves since they were all loose which I figured was OK since things start to wear and they get looser and not tighter. I will check the valves again.
It starts just fine, it's just the idle. I'll also check for air leaks.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-14-2009, 12:19 PM   #7455
Jager06
Jager06's Avatar
Oddometer: 46
Wipeout!
Went for a ride into South Cow Mountain last weekend! Took the kids, all the fun you can shake a stick at. Found a cool trail, nicely raise bermed corner, with a "Waadddya know!" waterbar on the far side that said....LAUNCH HERE!
So I did!
I made the pig FLYYYYY!!! I hit it about 35 mph off the berm and woke up about 30 feet up the hill, half under my bike.
My kids were standing around asking each other if they had ever heard anyone make that noise before. I finally got some air and tried to piece together what went wrong. Here is what I came up with:
1. Pigs weren't meant to fly that high, that far.
2. Suspension bottoming and skid plate catching is not a good last thing to remember.
3. Missing paint and cracks in the helmet combined with a cherried cheekbone and bloody nose means its time for a new helmet.
4. Pre scoring your brake and clutch lever where you want to break them will save you heartache when trying to get out.
5. Your kids wont back your campfire story.
6. Carry kid repellent.
7. Without armor I would have had to have some stitches on my forearm, elbow and shoulder. The holes in my $200 gear are cheaper than the $3000 emergency room bill that it would have been. Not counting the damage the helmet absorbed.
I have started saving for the elusive suspension upgrades. I am also drinking a lot and taking aspirin. It helps with the pain and swelling, but a paper cut will bleed me out right now.
I hope all of you have nothing in common with this story!
'08 XR 650L
~Daves Mods
~EPA crap ditched
~Exhaust uncorked
~vanpelt model 999 Oil Cooler
Jager06 is offline   Reply With Quote
Times are GMT -7.   It's 05:24 AM.
