Old 07-16-2009, 07:29 AM   #7516
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by Mercury264
WOW that sounds just like the XRR
What is going on with the XRR? does anyone know if they are going to be bringing it back??
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 07-16-2009, 07:39 AM   #7517
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,078
Cumbacheech
No idea.
I've said it many times before....why the heck didn't Honda put the magic button on the XRR, de-tune the motor a tad and call it their new DS bike
As much as I love my XRL....I'd buy one of those.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-16-2009, 07:57 AM   #7518
Cumbacheech
XRated
Oddometer: 823
No idea.
I know... I would be on that like a Fat kid on a Twinky!!
Old 07-16-2009, 08:07 AM   #7519
McLeod
Oddometer: 429
Cumbacheech
XR650R is dead, the last year for production was 07.
The 450x is the new desert racer for Honda.
Honda closed the plant here in the US that the XRR was being built in.
I am torn between staying oil cooled and the simplicity that goes with it, Or water cooled and the weight loss that goes with it.
A water cooled engine can be built to tighter tolerances, and tighter timing so it can produce higher horse power. Don't increase the compression, The L can run on horrible gas that is a benefit.
6 speed transmission Would be a huge gain.
At least change second gear back to the second the NX used. Get rid of the huge gear jump between first and second.
Suspension update would be nice. Keep the ground clearance.
Change the frame so the foot pegs can be lowered or raised for the height of a person.
Fuel injection would be a bonus, but the thing about a carb they suck but you can normally make one work even if its is badly; you can limp home.
You loose your fuel pump. I hope you really enjoy that walk in you mx boots while pushing your bike.
Possibly move the battery in to the center of the bike.
loose 50 lbs? Awesome.
I saw a XR650R frame the other day. It got me thinking. They have the oil in the frame just like a L dose. Wonder if you could squeeze the L engine in a R frame, Ktm swing arm, crf forks, add a oil cooler where the radiators go? Hmmm..
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 07-16-2009, 10:00 AM   #7520
XR650L_Dave
Oddometer: 3,726
I'm an airhead lover, but I really don't see a significant (meaningful) reliability decrease due to water cooling, for most people.
Personaly, I crash through the brush, push down dead trees, go through close, tight pine stands where the dead branches are stabbing the hell outta me and the bike (one broke my chest protector shoulder guard sunday), so I surmise I might puncture a radiator or rip off a hose, but short of stuff like that I think it's hard to break anything.
Dave
XR650L_Dave is offline   Reply With Quote
Old 07-16-2009, 10:03 AM   #7521
XR650L_Dave
Oddometer: 3,726
Originally Posted by kubiak
im poor so i have to modify and switch one bike.i get it all done then i get tired of it after awhile so i change it up so i think i have a new bike!
You need to develop a modular seat/tank/sideplate system where all come off together and can be swapped quickly...
Dave
Old 07-16-2009, 11:01 AM   #7522
jscompto
jscompto's Avatar
Oddometer: 597
Originally Posted by Nasty Rider
Hey Kubiak you anywhere around Louisville, Ky
Nah, he lives in California.
'96 XR 650L ~ 103mm piston, NX650 2nd gear, high flow header, WebCam, Vapor, FCR 41 pumper, 5.8 Acerbis
'99 CR 250R ~ gnarly pipe, turbine core 2 silencer, 54 tooth sprocket. BEAST
http://www.advrider.com/forums/showthread.php?t=491159
Joel Compton
jscompto is offline   Reply With Quote
Old 07-16-2009, 12:08 PM   #7523
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Bolt Head Sizes
I went to a local bolt specialty store today to get a replacement bolt for the one that fell off my exhaust. I told him I wanted the head to be either 12 or 14 mm. He said what you're describing is an automotive bolt. We only sell construction bolts. Go figure why Lowes has bolt heads that are in the odd numbers.
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 07-16-2009, 12:16 PM   #7524
watchmen
watchmen's Avatar
Oddometer: 242
What bolt fell out? I noticed that mine was missing where it attaches to the fram near the rear brake reservoir.
2000 R1150GS
1994 DR350R
1978 XL125
watchmen is offline   Reply With Quote
Old 07-16-2009, 01:46 PM   #7525
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Bluhduh
#14 in the diagram
2007 Honda XR650L
tjrockit screwed with this post 07-16-2009 at 01:58 PM
Old 07-16-2009, 03:25 PM   #7526
Cumbacheech
XRated
Oddometer: 823
#14 in the diagram
That is fairly common. I lost mine twice. Make sure when you replace it you use the correct bolt (right material) otherwise you will strip the threads...
Good luck
Old 07-16-2009, 03:33 PM   #7527
Mercury264
Mercury264's Avatar
Oddometer: 22,078
I find the best selection of bolts at Ace Hardware.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 07-16-2009, 03:55 PM   #7528
mcma111
mcma111's Avatar
Oddometer: 11,901
Bolt
That bolt is an 8x44mm. Most 8mm fasteners you find will have a 13mm head instead of the 12mm that comes on the bike.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-16-2009, 05:57 PM   #7529
Deltakus
Oddometer: 103
Clutch?
Ok, I cleaned, checked and looked it over. And the clutch is still stiff, and I can't stand it. So has anyone used one of these?
http://www.mooseracing.com/showImage...lsize&rank=100
Or is there a way to make it hydraulic?
Any Ideas?
Deltakus is offline   Reply With Quote
Old 07-16-2009, 07:17 PM   #7530
Wattner
Wattner's Avatar
Oddometer: 5,272
Is your cable straight and not binding? Sometimes it looks straight but where the cable goes into the housing, there is a bind. Also, I take a pair of channel locks and bend the bottom bracket to have the cable perfectly in the center of the housing. Little things that make the difference! I use one of these:http://www.motionpro.com/motorcycle/...ategory/cable/
clean the cable with:http://www.motosport.com/dirtbike/pr...talogId=110517
Then lube with:http://www.motosport.com/dirtbike/pr...segment=badger
Also, I extended the arm at the case by 3/8" and I have really easy, smooth action with even heavy springs... I would look at the cable binding and lube it up at least. Truly makes a difference.
Braaaap
Wattner is online now   Reply With Quote
Times are GMT -7.   It's 03:12 AM.
