Old 07-16-2009, 06:44 PM   #7531
Wattner
Wattner's Avatar
Oddometer: 5,308
H TJ, Go by the Honda shop and ask for a handful of extra bolts and crate bolts. Usually they have tons of bolts from accessories that people buy and all of the fasteners aren't used. I have had a couple of boxes over the years and am ready to go look again. I like the chrome bolts... they look pimp on a dirty old XR... The crates have many, many bolts that are just set aside or thrown out.
Wattner is offline   Reply With Quote
Old 07-16-2009, 06:55 PM   #7532
JoelSchmenge
JoelSchmenge's Avatar
Oddometer: 240
Alert Alert Alert!!!
Hey everybody,
Go check this dude out! all I can say is YEE-EFFING-HAH!!! But then again I live in Jawja (Georgia for the rest of ya) THAT FRICKIN THING IS BITCHIN".... give that man an "atta-boy!"
later all...
Dave Morgan
http://www.4strokes.com/guests/image...asp?ImgID=4182
"Every tool is a hammer, except screwdrivers, those are chisels."
JoelSchmenge is offline   Reply With Quote
Old 07-16-2009, 06:58 PM   #7533
banshee8989
AKA: Fartman
banshee8989's Avatar
Oddometer: 839
Originally Posted by Deltakus
Ok, I cleaned, checked and looked it over. And the clutch is still stiff, and I can't stand it. So has anyone used one of these?
http://www.mooseracing.com/showImage...lsize&rank=100
Or is there a way to make it hydraulic?
Any Ideas?
I used to used one on my Banshee (gasp.. yes an ATV) back in my ATV racing days. My problem was I was using different controls with cr80 levers and that worked good for me but your clutch should pull easy. Somthing is wrong.
One thing to watch out for if you use that is that you will not have as much throw on the clutch. Meaning the clutch will pull easier but the arm will not move as much. Thats the price you pay for gaining the mechanical advantage.
We have the best congress money can buy
banshee8989 is offline   Reply With Quote
Old 07-16-2009, 07:14 PM   #7534
Wattner
Wattner's Avatar
Oddometer: 5,308
True that, but with careful setup and monitoring it is a great mod... I have had it on my bike since 1997....
Old 07-16-2009, 07:52 PM   #7535
truck6driver
The Fireman
Oddometer: 7,455
Any Ideas?
Replace the clutch cable. The have a history of getting very hard to pull and sometimes, in my case, release completely and cook a clutch. Mine was lubed off and on it's whole life and still did it. Installed a new one and the pull was amazingly easy.
RH
When the system fails you, what then?? Do you fight it or just surrender and give up? If all seems doomed what is left to fight for? Is it just me or does the world seem to close in on you when you seem to be making ground? Options are dwindling down, what comes next? And in the words of Pink Floyd "Is there anybody out there". All I know is I WILL SURVIVE.
truck6driver is offline   Reply With Quote
Old 07-16-2009, 08:01 PM   #7536
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
So I'm having a minor problem with the install of my Acerbis tank.
The "Y" connector. Where do folks usually bring it together where the hoses won't melt from any heat? Any pics would be great.
Other than that, install wasn't too hard. Because of the 100+ temps here, I just put the tank out on the back porch in the morning and when I came home it spread over the frame real easy. I was actually surprised at how soft the plastic was.
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 07-16-2009, 08:35 PM   #7537
McLeod
Oddometer: 429
I put my Y on the left side about two inches from the left petcock. I loop the fuel line from the right side up over the carburetor then down to the Y
I'll try to get a pic for you tomorrow.
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 07-16-2009, 08:38 PM   #7538
jscompto
jscompto's Avatar
Oddometer: 597
Mine is in just about the same place as mcLeod's. I have had my tank for over a year and i have not had any issues whatsoever with the Y getting hot or anything. My only suggestion would be to use gas line from AutoZone or somewhere similar and do not use the gas line that comes with the tank. that stuff is JUNK! Good Luck!
'96 XR 650L ~ 103mm piston, NX650 2nd gear, high flow header, WebCam, Vapor, FCR 41 pumper, 5.8 Acerbis
'99 CR 250R ~ gnarly pipe, turbine core 2 silencer, 54 tooth sprocket. BEAST
http://www.advrider.com/forums/showthread.php?t=491159
Joel Compton
jscompto is offline   Reply With Quote
Old 07-16-2009, 09:13 PM   #7539
kubiak
Oddometer: 4,829
Originally Posted by Nasty Rider
Hey Kubiak you anywhere around Louisville, Ky
im out in central ca.it sure is hot out here,107 today!
Old 07-16-2009, 09:14 PM   #7540
kubiak
Oddometer: 4,829
Originally Posted by Natnewt
did you see the pics of my bike after the winter project? After our email convo and deciding on the crf shrouds instead of the 97 cr shrouds you went with...it turned out pretty good.
yea i saw it was great! love to see stuff like that!
Old 07-16-2009, 09:15 PM   #7541
kubiak
Oddometer: 4,829
Originally Posted by XR650L_Dave
You need to develop a modular seat/tank/sideplate system where all come off together and can be swapped quickly...
Dave
thats a great idea! maybe it could hold gas too.10 gallon tank here we come!
Old 07-16-2009, 09:45 PM   #7542
seantx
seantx's Avatar
Oddometer: 628
Ditto. I even built a brass T connector out of plumbing parts from home depot. The hoses and Y connector that ship with the tank looked really weak.
seantx is offline   Reply With Quote
Old 07-16-2009, 11:09 PM   #7543
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
I used all the fuel parts that came with the tank... (tonight)
I don't see a problem with it, yet.
Bbasso is offline   Reply With Quote
Old 07-16-2009, 11:26 PM   #7544
Deltakus
Oddometer: 103
I have done all the cable cleaning and all That I can do on the beast. And is still tight! And, I have cleaned the clutch out in the case.
I would like to extend the arm. But, I don't know who can do that around? Looks cheeper to do Moose easy pull. Who has used it?
Originally Posted by Wattner
Is your cable straight and not binding? Sometimes it looks straight but where the cable goes into the housing, there is a bind. Also, I take a pair of channel locks and bend the bottom bracket to have the cable perfectly in the center of the housing. Little things that make the difference! I use one of these:http://www.motionpro.com/motorcycle/...ategory/cable/
clean the cable with:http://www.motosport.com/dirtbike/pr...talogId=110517
Then lube with:http://www.motosport.com/dirtbike/pr...segment=badger
Also, I extended the arm at the case by 3/8" and I have really easy, smooth action with even heavy springs... I would look at the cable binding and lube it up at least. Truly makes a difference.
Braaaap
Deltakus is offline   Reply With Quote
Old 07-16-2009, 11:33 PM   #7545
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
Carburetors...
2001 XR650R. Stock
VS
2002 XR650L. With Dave's mods.
Which is better and explain please, I don't know.
thanks.
Times are GMT -7.   It's 04:46 PM.
