06-21-2006, 07:32 PM
#781 | |
one man wolfpack
Oddometer: 4,308
14/48 gearing is not what you want for holding 70mph for a long time. If your doing that, you should stay stock or just drop the CS sprocket 1 tooth. I've always bought X ring chains, dunno if they are any better but they work. This last time I bought Primary Drive brand Chain and Sprockets ( Gold X-ring chain and 14/48's and it only cost around $85, that was from rockymountainatv.com I used Sunstar before that and they are also very good, Got 8000 miles of mud, sand, gravel and some highway out of them. The key is STEEL. Get steel sprockets.
Check out the Blog! MotoGraphic MotoGraphic Tumblr Chad Berger KTM950ADV, DR650 Lone Wolf Expeditions |
#782 | |
Huge carbon footprint
Oddometer: 612
You're talking XR650L right? I have smog junk removed and did the carb mod thing and UNI air filter. Stock exhaust etc. I am running 15/48 final gearing and altho I have ridden it at 70mph a few times for appx. 15 mile stints, I thought the engine was working a little too hard (rpms too high). I wouldn't want to ride it for extended periods at 70mph with my 15/48 gearing. But that's just me. Maybe others will chime in? Get an O-ring chain. X or O. Sunstar steel sprockets are good. I like steel sprockets on my 650 because they wear better than aluminum. I know alloy is lighter, but who cares?! The bike already weighs well over 300 lbs! Now if you are anal about un-sprung weight, alloy sprockets might be important to you. Cheers, Dorian |
06-22-2006, 04:28 AM
#783 |
Oddometer: 609
According to "Mr. know it all" in the June issue of Dirt Bike magazine, X ring chains have it all over o-ring chains.
"The name X-ring is a DID trademark for that company's premium product. An X-ring is sealed better, is made of better material and is much much more expensive (about $150 versus $95). Dont get confused by tensile strength ratings. They mean nothing. DID offers a "wear index" rating that is much more useful. Their standard O-ring has an index of 2300, whereas the X-ring is rated at 4000. That means it will last almost twice as long. If you insist on lubing am o-ring chain, be sure to use very light lube that is designed specifically for the chain. The main function is to prevent corrosion." He must be right, after all his name implies that he "knows it all".
Forum motto - Buy a bike like mine Gravity - It's not just a good idea, It's the law. 1998 Honda Valkyrie 1946 Chevy pickup |
06-22-2006, 10:00 AM
#784 | |
Oddometer: 3,161
I know it wasn't the lube, I wonder of I did something else to it? Dave |
06-22-2006, 11:05 AM
#785 |
Daily Adventurer
My XR650L should be all put back together by the weekend. So far my bill includes
Changed all fluids Adjusted valves lubed chain New neutral switch new clutch plates new clutch cable new grips New set of Avon Gripsters New fork seals heavier fork oil set of Cortech bags I'll try to get some shots this weekend. I'm hoping to take a trip to the North Georgia mountains on Sunday. bbz |
06-23-2006, 11:46 AM
#786 |
Oddometer: 184
[quote=Shair_Khan]Hi all,
Since we have so many people with different views / experiences with XRl50L oil issue. Some go by the book with 2.06qt and others are using even more than 3qt.... We all know that low oil level can hurt the engine! Does anyone know if you have too much oil.... would that hurt the engine / transmission or anything els You don't want to over fill it....when the oil heats up it expands and you need room for that to happen
" Lets Roll "! Todd Beamer 9/11 |
06-25-2006, 09:47 AM
#787 |
Getting back in the game!
Oddometer: 41
Hi All,
I have few questions regarding smog block off kit for the folks who have installled it on their XRLs... 1. Is it worth it? Does it make any significant difference? 2. Do you have to rejet the carb, if you install the smog block off kit? 3. Cost? and where to buy? 4. What is the installation difficulty level? 5. Any other words of wisdom for someone who has never messed with the smog system on cars or motorcycle? 6. Does that create any problem when time for inspection sticker? Thank you, in advance, for your response. -- Sincerely, Shair A. Khan |
06-25-2006, 09:59 AM
#788 | |
one man wolfpack
Oddometer: 4,308
The smog kit requires no mods to the carb, I dunno about the inspection thing.
06-26-2006, 05:58 AM
#789 |
World's Best Dog
Oddometer: 5,708
New-for-me 2002 XR650L with 3,500k miles, looks like new. Can't wait to join the party. Pick up the bike at PO's house sometime this week. Will need advice on tires as the rear is shot. Oddly, the handguards are gone, which is the only "mod" done to the bike. Other than that, it is showroom-new...kind of scary, I'm sure I'll manage to add some "character" to it in no time.
Chris Looks like the dingbat army is behaving exactly as expected. tkpinsc |
06-26-2006, 10:31 AM
#790 |
Oddometer: 184
revisit smog kit from above thread
Does removing the smog crap improve permormance?
06-26-2006, 10:38 AM
#791 | |
Oddometer: 3,161
Gets rid of that annoying popping (how un-stealthy that is!) and a few pounds- that's all. Looks better, too. Maybe the airflow around the cyl. improves a skosh also? Dave |
06-26-2006, 02:18 PM
#792 | |
SILENCE.....i kill you
Oddometer: 812
[quote=thumperron]
Rule of thumb should be to put in the 2 qts and run the engine good. Not just idle. I've noticed on mine that idling it checked low after I stoped it, but once I reved it up it check ok. I just add till it's completely full though, which is ALWAYS more than 2.06 qts. |
06-26-2006, 04:27 PM
#793 | |
one man wolfpack
Oddometer: 4,308
![]() after: ![]() The motor looks alot better without all that crap ( it would look ALOT better if I cleaned the damned thing ) and doesn't pop anymore ( usually )
06-26-2006, 06:15 PM
#794 |
one man wolfpack
Oddometer: 4,308
Suspension
Oh wise suspension Guru's
I never got the owners manual for my bike and even if I did, I doubt I'd understand it. I'd like to set up the suspension on my XRL to suit me. My bikes suspension is totally wrong right now, too stiff and tall in the back end. I realize that I could release some tension on the spring, but its already within 1/2" from the top or so. What I'd like to know is what do the adjustments do? The slot on the shock reservior, and the adjuster on the bottom. I realize they are probably compression and rebound, but I really don't understand how that will affect the bike. Also, what do the adjusters on the bottoms of the forks do?
06-27-2006, 03:56 AM
#795 |
Oddometer: 184
smog again
Do you think bike will pass NJ inspection without it?
Rokklym It does look better without.
