Old 08-25-2009, 08:19 PM   #8341
xrldtg
Deep sand softness tester
Oddometer: 31
Originally Posted by Jeff@TheQuadShop
Umm....it's not a photo chop!
Next to stock tank...
Holy crap!!!!! You'd have to go up another fork spring size to accomodate for that thing. SO, what bike was it originally made for? the rear mount has two holes instead of one, like the "L" has.
xrldtg is offline   Reply With Quote
Old 08-25-2009, 08:31 PM   #8342
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,658
It was made for the 600 and 650L, it has a special bracket for the two holes.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 08-25-2009, 08:32 PM   #8343
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,658
Originally Posted by Bbasso
rubb it in more with this photo
Or make it with two bikes
You Photo Choped those!!!
Old 08-25-2009, 08:57 PM   #8344
lasercustoms
lasercustoms's Avatar
Oddometer: 596
I like the Acerbis 5.8 for the long hauls and the IMS 4.7 for trail rides.
Acerbis...
Where did you get your super cool hedlight?
I love Jesus. Even if I don't act like it all the time.
lasercustoms is offline   Reply With Quote
Old 08-25-2009, 10:24 PM   #8345
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,859
Originally Posted by seantx
What tire is that bomber?
it was a.......
Dunlop D773 Soft Terrain Rear Tire 110-100-18
.......completely my fault for overheating/loading it.
Hurricane Bob is online now   Reply With Quote
Old 08-25-2009, 10:34 PM   #8346
seantx
seantx's Avatar
Oddometer: 626
Originally Posted by bomber1965
it was a.......
Ouch. Tires aint cheap. Really expensive when they only last a day.
seantx is online now   Reply With Quote
Old 08-25-2009, 11:06 PM   #8347
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
Interesting ride just a few minuets ago on the way to/from the store.
Outside temps in the low 70s with little humdity.
The bike felt amazing! More power then I've felt in, well ever.
It was able to lift the front wheel off the ground with out any effort and caught me by surprise too. Top end was signifcantly stronger too, like 5th gear pull was silly strong up to 85mph but I didn't go past.
Temp oil temp never went over 220.
SO..
Could the meen I'm running to lean for the warmer weather?
Running the standard Dave's mod & jets, twinair and fmf exhaust.
Bbasso is offline   Reply With Quote
Old 08-25-2009, 11:42 PM   #8348
xrldtg
Oddometer: 31
SO..
If you like that, try going up to a 160 Main with that FMF. Mid range+ you will feel a difference.
Old 08-26-2009, 12:12 AM   #8349
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
I like, But! will it do any harm? (other then mpg)
Old 08-26-2009, 05:19 AM   #8350
xrldtg
Oddometer: 31
No harm, with the can, you lean out the mix from stock, thus needing the bigger main jet. It will richen up the mix.
Here is a guide to all that is jetting, disregard the air mixture screw bits, the L's carb only has fuel mix screw:
It is important to remember that adjusting carburetion should only be attempted on an engine in good running condition that is thoroughly up to operating temperature. Do not make adjustments all at once. Find the affected throttle position (circuit) and work on that area only. Doing one step
at a time will ensure optimum performance and smooth efficient operation.
Pilot Jet - Up to 1/4 throttle - Controls fuel flow through the idle circuit - Mixture is adjusted by means of the mixture screw -
There are two types of mixture screws - Fuel Screws and Air Screws ]
- A Fuel Screw, as the name implies, meters fuel - A Fuel Screw will be located on the engine side of the throttle valve, usually
on the bottom of the carb - Turn in to lean mixture - Turn out to richen mixture - The engine should have a smooth, steady
idle with the screw between 1/4 and 3-1/2 turns out from fully bottomed (gently!) - If the engine requires more than three
turns out, the pilot jet may be too lean - If it requires less than 1/4 turn, it may be too rich.
- An Air Screw meters air - An Air Screw will be located on the air cleaner side of the throttle valve, usually on the right or left
side - Turn in to richen mixture - Turn out to lean mixture - The engine should have a smooth, steady idle with the screw
between 1/2 and 2-1/2 turns out from fully bottomed - If the engine requires more than 2-1/2 turns out, the pilot jet may be
too rich - If it requires less than 1/2 turn, it may be too lean.
Symptoms and/or adjustment - With the idle at approximately 1000 rpm, turn the air screw mixture in slowly until the idle
slows or becomes erratic, then begin turning the screw back out until it again becomes erratic. Count the number of turns in
between the two positions. Set the position of the air screw between these two conditions, which should also be your smoothest
idle . Finally, adjust the idle screw if necessary to approximately 1000 rpm again.
Jet Needle - from 1/8th to 3/4 throttle - Controls fuel flow through needle jet - Raising or lowering the clip location on the
grooves, richens or leans fuel flow, as well as determines at what throttle position the tapered part of the needle is to be raised
out of the needle jet - Raising the needle (lowering the clip) richens the mixture - Lowering the needle (raising the clip) leans
the mixture.
Symptoms and/or adjustment - Accelerate to 1/2 to 3/4 throttle, preferably in top gear. If acceleration seems weak, soft or
flat, or the engine responds slow when the throttle is quickly
opened, the mixture is too lean. Lower the needle clip one position
to raise the needle. Conversely, if acceleration is crisp and strong,
but hesitates or shutters as the throttle is closed from 3/4 to 1/2, the
mixture is too rich. Raise the clip one position to lower the needle.
The optimum setting will be crisp acceleration, with no load up
(rich) as the throttle is backed off.
Main Jet - from 3/4 to full throttle - Controls fuel flow as the jet
needle is lifted far enough out of the needle jet. Until this point
(throttle position), the main jet has no effect on mixture strength. A
larger # jet richens the mixture - A smaller # jet leans the mixture.
Symptoms and/or adjustment - The main jet is the last jet you
deal with and by far the easiest to diagnose. You will only change the
main jet if a problem exists at 3/4 to full throttle. Any other problems
in the carburetion are not affected by the main jet. The two easiest
ways to find the optimum setting are:
1) Set-up an area approximately 50 to 100 yards long. Have
someone time you through this area. As you pass the entry, open the
throttle fully (on the main jet circuit) and motor through this area.
Essentially, the jet size that provides the least amount of time to run
through this, is the correct main jet.
2) Starting with a fresh set of spark plugs that have been run for
at least a few miles to gain some color to them, run the engine
(under a load) for approximately a minute or so at 3/4 to full throttle.
Then, in a safe area, pull in the clutch, hit the kill switch, and
leave the throttle in its wide open position; all at the same time and
coast to a stop. Then remove the spark plug and inspect its condition/
color. The porcelain should be a reasonably clean color/condition,
light gray to brown is good. If the plug is black and/or sooty,
the main jet is too rich (big) and you should go down in size to a
smaller number. If the plug is white, with no apparent change in
color from brand new, and the engine appears to be running hotter
than normal, it may be lean (small). You need to go up in size to a
larger number.
Old 08-26-2009, 06:26 AM   #8351
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
thanks, I haven't read/seen that before.
Looks like I'll try the 160 today :)
Old 08-26-2009, 07:40 AM   #8352
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,658
I picked it up in Germany, it's stock on the European model XL600LM
Old 08-26-2009, 08:14 AM   #8353
xrldtg
Oddometer: 31
Is that one of Cabelas water proof bags they give out with Scent Lok clothes on the back? That's what I use to keep things dry on the trail.
Old 08-26-2009, 09:22 AM   #8354
debaisley
debaisley's Avatar
Oddometer: 1,424
So I've decided to just get another XRL , instead of fixing mine (there are a lot more problems than just the clutch , and the thing that bothers me the most about the clutch issues , is that I cant find a single broken part , so if i get it unjammed , whats gonna stop it from doing it again in the future). Im gonna pick up a nice lookin 03 near by , and now i will also have a rolling parts bin to go with it.
debaisley is offline   Reply With Quote
Old 08-26-2009, 09:37 AM   #8355
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,658
It's an LL Bean bag that my parents had from year ago.
Times are GMT -7.   It's 10:10 AM.
