Old 11-01-2009, 06:59 PM   #9856
ravenranger
rave
ravenranger's Avatar
Oddometer: 1,530
Okay, I'm grabbing a shower and a bourbon and coke but will be back in a few to see how things are progressing.....
1989 NX250
2006 ST1300A
2006 Aprilia Caponord
ravenranger is offline   Reply With Quote
Old 11-01-2009, 07:00 PM   #9857
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,655
Originally Posted by ravenranger
oh, don't click on this link - went to spam central!
too late .. baaaa! (nice thought though)
yours is good . makes Clymer look like a brochure for a repair manual.
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX is offline   Reply With Quote
Old 11-01-2009, 07:00 PM   #9858
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
Originally Posted by father9
thanks
THANKS,,,,,,,,,,,,,,,,,THANKs,,,,,,,,,,,,,
THATS ALL YOU CAN SAY????????
How about I think OLE PELT just got robbed of a set of wheels, can you say speedo cable???????????
now get up and go fix that bikee, till the wife you got to do this and go........ ,,
08 XR650L
Billet Aluminum Xr Oil Cooler http://advrider.com/forums/showthread.php?t=578914
If your ever caught traveling back in time,,,and meet someone traveling forward in time,,, it's best not to make eye contact,,,, just saying...
vanpelt999 is offline   Reply With Quote
Old 11-01-2009, 07:03 PM   #9859
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,655
time will tell
I still don't know what you were rambling on about in #9856
Old 11-01-2009, 07:07 PM   #9860
flatfender
flatfender's Avatar
Oddometer: 776
Originally Posted by Walterxr650l
No it won't.
Alternator output is 188W
The headlight is 55W low, 60W high.
Taillight is 8.3W, brake light is 26.9W.
Turn signals are 26.9 watt each.
Instrument light is 3.4W.
High beam indicator is 1.7W
So 55W + 8.3W + 3.4W + 90W + 48W = 204.7W = nothing left to charge the battery and run the ignition.
I think a 90 watt jacket by itself might be pushing the limit. i do know that I can run my 77 watt jacket liner continuously at full power.
Walter
Thanks Walter, that was the info I was looking for. The 65 watt liner will have to suffice.
flatfender is offline   Reply With Quote
Old 11-01-2009, 07:12 PM   #9861
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
time will tell
I was concerned that you ajusted with cam lobes up, even with the fly wheel T showing up
this can be done, buddy of mine did it, rolled over one full turn there so loose you need to check them with the end of wrench, anyway you got book so you got it now, good luck
08 XR650L
Old 11-01-2009, 07:40 PM   #9862
Red-Lead-Sled
XR675L
Red-Lead-Sled's Avatar
Oddometer: 33
Not an epiphany, just a picture:
father9 - I'm in the process of installing a Web Cam, so I have the top end apart. Here's a picture of the rockers. Hope this helps.
in3 + in3 + in3 = e
Red-Lead-Sled screwed with this post 11-01-2009 at 08:41 PM
Red-Lead-Sled is offline   Reply With Quote
Old 11-01-2009, 08:39 PM   #9863
sassage
Wanderer
sassage's Avatar
Oddometer: 156
Originally Posted by cypert2
My stock cable works fine.
do any rerouting of the cable?
A witty saying proves nothing.
1994 Honda XR650L
2002 Honda VTX1800C/R/F
2000 Honda VTR1000F Superhawk
2000 Ducati 996
sassage is offline   Reply With Quote
Old 11-02-2009, 04:07 AM   #9864
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,655
looks familiar.
i definitely have the rockers on top of the subs.
pretty sure the locations are correct.
The things concerning me are:
NO decompression TICK
and
Screws sticking way up.
I think they are the same problem.
Probably an 180 indexing error on the the cam install???
Looks like I'm going back in
Old 11-02-2009, 03:04 PM   #9865
mcma111
mcma111's Avatar
Oddometer: 11,864
Cam Position
Easy to tell if the cam is in right. Look in the inspection covers with the engine at TDC and see if the lobes are UP or Down...
BTW... It takes 2 complete revolutions (720') to cycle a 4 stroke engine valve train
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-02-2009, 03:16 PM   #9866
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,655
Your input is appreciated
I'm solo with the troops tonight so I probably won't make it out to the barn to check .
Old 11-02-2009, 04:36 PM   #9867
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
What about the spark part, is there an easy way for pop to tell without pulling side cover????????
08 XR650L
Old 11-02-2009, 07:34 PM   #9868
mchester
Honda Cult Member
mchester's Avatar
Oddometer: 1,461
If you pull the plug boot and stick a screwdriver up inside where the plug connects, then, while holding the metal screwdrvier shaft, crank the engine.
If your eyeballs pop out and roll across the floor, then you've got plenty of spark. If it only hurts like hell, then you may have a weak spark issue. If you feel nothing, then you've found your problem.
"I intend to live forever. So far, so good" Steven Wright
"If you choose not to decide, you still have made a choice" Rush
2004 XR650L & 2003 ST1300
mchester is offline   Reply With Quote
Old 11-02-2009, 07:47 PM   #9869
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
I like that advice
Bbasso is offline   Reply With Quote
Old 11-02-2009, 08:29 PM   #9870
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 407
my 2 cents and a question
Hey father9,
I am knee deep in my XRL right now as well. The top end is apart while I wait for my piston to arrive. I am with Screamin Injin... I think the only way your rockers could stick up that far is for the rockers or sub-rockers to have been installed incorrectly. There is no way the rotation of the cam can cause them to poke out like that if installed correctly. Now they might be 180 out of synch, but that wouldn't cause your problem. The schematics from the manual show some specific stampings on the rockers and sub-rockers that have to be put in 'just so.' I can scan it for you if you don't have it.
On another note, are there any gurus out there that can answer this question: Does the pulse generator in the right crank case fire a spark at every TDC, regardless of whether it is at the top of the compression stroke or the exhaust stroke? I ask because the manual only states that the crankshaft must be spun to TDC when you place the cam (lobes down in the compression position) and install the cam chain. It does not specify setting the 'correct' TDC. If the pulse generator only fires every other TDC, then you would have to verify that it is at the top of the proper TDC when installing the cam, would you not?
Sorry for the novel... never been this deep in a motor before.
Cheers,
Grayjet
'93 Honda XR650L
'09 KTM 990 Adventure
Putting miles on the tires!
Grayjet is online now   Reply With Quote
Times are GMT -7.   It's 08:24 AM.
