Old 12-25-2009, 12:53 PM   #11041
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
Merry Christmas everyone!!!!!!!!!!!!!!!!!!
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 12-25-2009, 03:52 PM   #11042
tombaisley
tombaisley's Avatar
Oddometer: 163
Originally Posted by the come back kid
P.P.S. still hope to ride with the baisley boys someday(got shorted at 7 mountains)
I've been building a "franken" xr650L the past couple of months, We took it for it's first spin around the patch today. It needs alittle more work and some fine tuining, I'm going to be itching to get it out on a real trail ride as soon as we're done with the scrambles in Feb, I'll be sure to let you know if we're going to be riding somewhere.
Dan working on the carb
tombaisley screwed with this post 12-26-2009 at 03:56 AM
tombaisley is offline   Reply With Quote
Old 12-25-2009, 06:38 PM   #11043
AST236
AST236's Avatar
Oddometer: 2,200
Merry Christmas from south Alabama!
AST236 is offline   Reply With Quote
Old 12-26-2009, 06:22 AM   #11044
omatza
omatza's Avatar
Oddometer: 112
Originally Posted by Kenzo
the easiest way i found to remove the shock is to remove the chain, remove the swingarm bolt and lower the swingarm...u should be able to reach the lower shock bolt then...
...just dont force it and pay attention to your grease zerks because they're easy to break off.
Originally Posted by ravenranger
Go to this LINK and it will pull up a pdf of the service manual. Rear suspension is chapter 12.
You can use "save as" to save a copy to your computer.
Originally Posted by omatza
Thanks a lot guys.
Actually, I have this manual (I think it is ravenranger who direct me to this link before) and I looked at chapter 12 pictures before I tryed to remove the shock obsorber.
It is just that I didn't understand from all the bolts and connections and link, what is the minimim to disassembly.
I finally assembled evrything back (cause I didn't put the bike on stable serface) and decided to do it in another day.
I think now I know what to open.
It is part number 23 in this link. (hope the link will work)
Hi guys
I put the bile on a firm stand toay and remove the rear wheel.
Then tried again to take of the shock obsorber. No success :-(
I open the upper bolt.
The remove the what I thought you meant "swingarm bolt".
Then lower the swing arm and tried to open the lower bolt of the shock.
Still can't take it out.
I will put pictures of what I opened.
Any hints ?
Looking at the manul, I think it say to remove the air box !!! before.
Am I right ?
Thanks alot
(BTW: I wanted also to replace the rear sprocket, but can't open the nuts.
It is 17'. Do I need spcial tool ?)
BTW: I see that the link is opposite.
The wording should be in the left side.
Am I right ?
The link seems to be simetrical.
Why there is a direction for it ?
omatza is offline   Reply With Quote
Old 12-26-2009, 07:44 AM   #11045
mcma111
mcma111's Avatar
Oddometer: 12,928
Bolts 'n Stuff
Hi guys
This nut and bolt in the picture needs to be removed to gain access to the lower shock bolt
Thanks alot
To remove the sprocket nuts you need a box wrench to loosen the nuts. The nuts must be loosened first before the bolts will come free.
Am I right ?
Just leave the link alone. It does not matter where the writing is.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-26-2009, 11:17 AM   #11046
omatza
omatza's Avatar
Oddometer: 112
Trabels :-(
Few weeks ago I wrote a post.
I wrote that I wanted to replace the front sprocket and ordered OEM sprocket.
When I got it and tried to instal it, I saw tha there is "distance" between the chain and the sprocket.
The response was that I have to put a picture and maybe there is a need to replace the whole set.
I bought DID 520VM and new rear sprocket and went to install the set.
First I installed the new front sprocket.
I immidiatly saw that there is a problem, but was still optimistic.
took off the chain and put the new rear sprocket.
The situation stayed the same.
here is a picture of the old and new sprockets - side by side
here is a picture of the old and new sprockets - one on top of the other
here is a picture of the old sprocket with the new chain - OK
here is a picture of the new sprocket with the new chain - not OK :-(
Any idea ?
Old 12-26-2009, 12:15 PM   #11047
mcma111
mcma111's Avatar
Oddometer: 12,928
Sprocket
Trabels :-(
Any idea ?
Looks like the sprocket is the wrong pitch.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-26-2009, 12:28 PM   #11048
omatza
omatza's Avatar
Oddometer: 112
Do you think there is a pitch there ?
(meaning there is one cog "correct" and one not ?)
Old 12-26-2009, 12:29 PM   #11049
omatza
omatza's Avatar
Oddometer: 112
even with the sprocket off the bike, and put the chain arround it, it doesn't fit :-(
Old 12-26-2009, 01:22 PM   #11050
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,874
Must be a 40 series sprocket and you need a 50, 520 actually, check the table 1/3 way down the page...
http://oldmanhonda.com/MC/Rchain.html
katbeanz is offline   Reply With Quote
Old 12-26-2009, 02:21 PM   #11051
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
Hi guys
Any hints ?
Am I right ?
Thanks alot
Am I right ?
In this picture that the way my service book says to have them. Ben
Ben99r1 is offline   Reply With Quote
Old 12-26-2009, 03:22 PM   #11052
O Captain My Captain
Modern Day Walter Mitty
O Captain My Captain's Avatar
Oddometer: 506
Originally Posted by tjrockit
Can't say enough about the windshield. I've been at high speeds (75 mph) in high side and front wind and have always found that it helps stabilize the bike. No issues.
I did a full write up. If you have an Acerbis tank, make sure you get the brackets for the larger tank. See the below thread for details.
http://www.advrider.com/forums/showthread.php?t=506238
Thanks. I do have the Acerbis 5.8 tank so this helps as well.
Merry belated Christmas to all.
O Captain My Captain is offline   Reply With Quote
Old 12-26-2009, 04:41 PM   #11053
jeepkevin
Oddometer: 76
I'm transfering a Vapor from my TW to my XR. The temp sensor was under the plug on the TW and is not in the best of shape. Can I remove or change that eyelet? I currently have the dipstick thermometer, where would be a good place to pull temp for the vapor? Oil temp in another location? Head temp? EGT? Thanks. I tried searching but too many other things pulled up, not the specific info I'm after.
jeepkevin is offline   Reply With Quote
Old 12-26-2009, 05:23 PM   #11054
mcma111
mcma111's Avatar
Oddometer: 12,928
Temp Sender
At the oil feed line at the right rear of the rocker cover.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-26-2009, 06:31 PM   #11055
jeepkevin
Oddometer: 76
It looks like the eye hook ring thing is all chewed up and isn't going to seal properly there until I replace. The ring has a substantial joint where it connects to the wire lead, don't know if I can just source another brass ring terminal and replace, solder back on. For tonight I just hooked it to the lowest bolt of the top engine mount where it bolts to the head. I want to ride in the morning so I'll watch what numbers I see. I went to Home Depot and bought a black rubber crutch foot/table leg thing. I slide a couple of thick o-rings onto the frame oil fill, and pushed the rubber foot down onto it. The thermometer pushes right thru the center and seals it's self really well. I painted stripes around the thermometer to match the low/high markings on the dipstick. Seems to work great. Used a digital meat thermometer -20 to 309. Uses lots of info from this thread for my ideas, thanks guys!!!
Times are GMT -7.   It's 03:21 AM.
