Old 10-05-2007, 12:53 PM   #1441
garrett
garrett's Avatar
Oddometer: 458
Thanks Valvecrusher. I'll check it out.
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 10-05-2007, 04:51 PM   #1442
Chief Gunner
Chief Gunner's Avatar
Oddometer: 740
Thumb
Originally Posted by McLeod
Cheif here is what I found after a web search.
"If you want to keep the same gearing as you had with the stock wheels, you'll need to get new front and/or rear sprockets. Changing from an 18" rim with a tall dirt tire to a 17" rim with a low profile sportbike tire will change your gearing 10-15%, so you need to adjust accordingly with the proper sprockets."
source here > http://londonbikers.com/forums/shwme...essageID=39094
The stock XRL set up is 15 - 45 = 3.0 gear ratio
10% reduction would be 2.7, 15 - 41 will acheive 2.7 gear ratio so will a 14 - 38.
15% reduction would be about 2.55, 15 - 38 front rear.
I would try the 38 rear sprocket and then toss on the 14 tooth you probably currently have in your kit that you use for the trees. The thing I am not sure about if your going to be able to run the same chain as your off road setup.
Gear ratio source
http://shop.wemoto.com/info.dyn?titl...et_Gear_Ratios
Thanks I'll give it a try, It should be nice having two sets of wheels.
I run my pig 19 miles on the freeway Mon-Friday for work and usually hit the trails & desert on the weekends when I can. I'll post up once the goods show up and I experiment with sprockets.
I'll try to stick with the RK "X" ring 520 chains, the've been really good to me....9K so far on the last one I bought.
I've gone Orange
2013 990 Adventure
2010 KTM 530 EXC
Chief Gunner is offline   Reply With Quote
Old 10-05-2007, 06:13 PM   #1443
McLeod
Oddometer: 429
I have a 120 mile ride back and forth to work. After a few sets of knobbies its worth it to spend a little on a diffrent set of rims. Road tires will be much easier on the hands. I am building up a second set of rims, I am increasing the tooth count on the dirt set to 48 and I am going to reduce the tooth count on my street set to about 43.
I just switched to a DID chain. I hope they last better than the RK I just took off. The OEM chain lasted 10k, the RK only lasted 8k.
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 10-07-2007, 09:28 AM   #1444
THE BEAST
THE BEAST's Avatar
Oddometer: 66
engineer part
hi ever one can you all help me where to get xr650l engineer part in usa i going to rebulid my poor bike
THE BEAST is offline   Reply With Quote
Old 10-07-2007, 10:01 AM   #1445
husky123
Oddometer: 1,454
Uhhh, ummm, what?
husky123 is offline   Reply With Quote
Old 10-07-2007, 10:17 AM   #1446
THE BEAST
THE BEAST's Avatar
Oddometer: 66
xr650L
I Mean Where To Get The Block And Piston And Piston Ring In Usa
Old 10-09-2007, 07:38 PM   #1447
99' xr650L
dual sport guy
99' xr650L's Avatar
Oddometer: 86
Just sold my xrl. Loved the bike, the thing was bullet proof, but I had to sell it due to it being too much bike for my size. I'll always remember it!
[IMG][/IMG]
99' xr650L screwed with this post 10-09-2007 at 07:45 PM
99' xr650L is offline   Reply With Quote
Old 10-11-2007, 06:49 PM   #1448
ptwohig
Oddometer: 75
Originally Posted by coppertop
I'd have thought that when they went bad, it would be all at once. Mine was crapping out intermittently. Some days it would be hard to start, some days it would start fine and then suddenly lose power and run hot...
A friend with a Honda EX400 4-wheeler was doing some hop-up stuff that involved an after-market CDI box, so he gave me his stock CDI box. It is not the same part number, but the engine is very similar and the electrical connectors fit, so I gave it a try. I have had no problems from that substitution (8,000 miles so far).
Well guys, I finally tried to see if the hopped up ex400 CDI I got would work. The plug in were the same, but when I turned the key it blew the main fuse. Tomorrow I will try to get ahold of the manufacture and see if they can help. If any body knows where I can find a wiring diagram for the EX that sure would help!
ptwohig is offline   Reply With Quote
Old 10-12-2007, 01:57 PM   #1449
BeeDub
Havagoowan
BeeDub's Avatar
Oddometer: 2,022
Here's mine, got it brand new last Sunday. Finally started riding it to work. Wondering if this setup is DOT legal, and whether it is bright enough???
https://www.bajadesigns.com/NET/main....aspx?content==
BeeDub is offline   Reply With Quote
Old 10-12-2007, 05:26 PM   #1450
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,243
Man, your garage looks so clean and comfy like the inside of my house!
Nice bike!
I meant the red one...
AtomicGeo is offline   Reply With Quote
Old 10-14-2007, 09:39 AM   #1451
garrett
garrett's Avatar
Oddometer: 458
Mikuni Carb from XRsonly
I'd appreciate feedback from those that have purchased the Mikuni from XrsOnly. I'm looking at upgrading to it, but would like your thoughts on the setup and operation of the carb.
Regards,
Garrett
I like bikes...
Old 10-14-2007, 09:14 PM   #1452
D-man
SHUT UP & RIDE!
D-man's Avatar
Oddometer: 752
2002 rigged for adventure riding.
4 gal tank, FMF pipe, daves mods, stainless rack, fender mods, Moose rock pan, de-smogged, opened air box and Unifilter. Corbain seat (a must have for long trips) side guards, (pay for themselves first dump) Lowered.
D-man is offline   Reply With Quote
Old 10-15-2007, 06:51 AM   #1453
Ghoti
Sooper Brane
Ghoti's Avatar
Oddometer: 15,293
I'll bet that is an adventure at night!
Everyone is entitled to my opinion.
Ghoti is offline   Reply With Quote
Old 10-15-2007, 12:15 PM   #1454
BeeDub
Havagoowan
BeeDub's Avatar
Oddometer: 2,022
Nice bike!
Yeah, I was keeping it in the living room until my insurance came through, haha! The other bike is pretty nice too, for having fun and shedding pounds!
Ordered the Baja Designs drop down taillight/license holder, Maier MX rear fender, and IMS smog block off kit, all should get here this week!
Old 10-15-2007, 01:49 PM   #1455
D-man
SHUT UP & RIDE!
D-man's Avatar
Oddometer: 752
That trip was all day time and when I emptied the flat pack into the tank I strapped it on the back. was just trying to get some weight on the front, with my fat butt and 10 lbs of gear on the rack its a bit light in front and tends to wash out easy.
Times are GMT -7.   It's 02:36 PM.
