Old 10-10-2014, 06:02 AM   #1
777 OP
Oddometer: 92
690 injector removal help
Is their a thread showing ,how to remove the injector,mine needs cleaning?
777 is online now   Reply With Quote
Old 10-11-2014, 05:45 AM   #2
777 OP
Oddometer: 92
No links, no info??
Old 10-11-2014, 06:24 AM   #3
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,413
Simple thing to do so probably no one's ever done a how to. Pull off the airbox and you'll see the injector. One bolt holding it in.
Old 10-11-2014, 06:35 AM   #4
777 OP
Oddometer: 92
Thanks,not sure how to take air box out,have a safari tank,will that make any diffrance?
Old 10-11-2014, 06:40 AM   #5
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,413
Well, GETTING to the airbox will be a tad more difficult. Once you get the tank off, there are 4 bolts holding the airbox in. Just remove those, loosen the clamp holding the boot to the throttle body, disconnect the attached SAS hoses, and the sensor wire on the bottom of the box then you can pull the box off.
Old 10-11-2014, 06:43 AM   #6
777 OP
Oddometer: 92
That's the issue getting that tank off,thanks for info
Times are GMT -7.   It's 11:20 AM.
