Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 08-04-2013, 03:49 PM   #3916
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,628
Ron, just ride it. I'm one of the few that had a problem. I figured since I bought it new, it was worth it to me to replace the crank. I estimate I put in under $1000 into the engine to get it to where it is. Nearly 10K miles later, still running fine. Does the Ulysses have teething problems? Sure, but most of mine were fixed under warranty at the time or by preventative maintenance. It's still a lot of fun for me to ride it and would not go back to the Weestrom. I also don't see one every block.
As for tires, just bought a set of Continental Motions for $172 delivered from ebay. I think I'm on my 5th or 6th set of tires, so it does add up quickly.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 08-04-2013, 03:50 PM   #3917
vtwin
vtwin's Avatar
Oddometer: 7,628
Originally Posted by GhostRiderFC View Post
Congratulations!! I also have a 2009 XT. I was loving it until today when it pooped out on me in New Hope, PA. Weirdest thing. Turned on the key, all normal, hit the starter button, and it all went kaput. No display, no start, no dial sweep, no nothing. Checked battery terminals, checked fuses, checked ECM. Nothing appears to be wrong. Got it towed to the shop for analysis.
Check the grounds, known for loosening up.
Monroe.
unknown
Old 08-04-2013, 08:04 PM   #3918
Hughlysses
Hughlysses's Avatar
Oddometer: 3,401
A failed battery (internal short) will also do that.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 08-04-2013, 11:51 PM   #3919
jonathan.vtec
Oddometer: 53
I had the esame problem when my chinese xenon ballast was broken
Inviato dal mio Vodafone 875 con Tapatalk 2
jonathan.vtec is online now   Reply With Quote
Old 08-05-2013, 04:54 AM   #3920
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,215
My KLR did that. Did some head scratching before I figured it out.
Old 08-05-2013, 05:03 AM   #3921
jonathan.vtec
Oddometer: 53
hello boys anything of u can send to me the link to install the original windscreen i want to take out the palmer kit
regards
Old 08-05-2013, 09:52 AM   #3922
dean-o
Dabs often
Oddometer: 872
Wanna sell the Palmer brackets?
Dean in Tennessee
615 5451111 texts ok
dean@learntoride.org
dean-o is offline   Reply With Quote
Old 08-05-2013, 03:14 PM   #3923
SkiFastBadly
A beer? Yes, please
SkiFastBadly's Avatar
Oddometer: 1,542
regards
You need the rubber grommets that go in the holes in the flyscreen. That's really all there is to it, pop 'em in (wet 'em first).
The crows seemed to be calling his name, thought Caw.
2008 Buell Ulysses
2008 Triumph Scrambler
2004 HD Heritage Softail
SkiFastBadly is offline   Reply With Quote
Old 08-10-2013, 08:10 PM   #3924
thesurvivalist
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 08-11-2013, 08:27 PM   #3925
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,459
Got out this weekend !
A fellow inmate got a new to him, Yamaha FZ1 and we went went for a little ride.
It was not without a few setbacks, like packing up camp in pouring rain.
But it all got better
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
http://carlstwowheeledadventures.blogspot.com
2006 Buell Ulysses, Current Rally Mount
1984 HD Electra Glide Classic
1977 BMW R 100/7 Cafe'
1982 Honda CBX Super Sport, Work in progress
Hog Rider screwed with this post 08-11-2013 at 08:32 PM Reason: Was not done
Hog Rider is offline   Reply With Quote
Old 08-13-2013, 09:45 AM   #3926
ERD
Custom Rider
Oddometer: 384
OT: Hog Rider,
I really like your windshield. DO you have closeup picture and more information on it? THanks!!!!
ERD is offline   Reply With Quote
Old 08-13-2013, 11:38 PM   #3927
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 492
Originally Posted by ERD View Post
OT: Hog Rider,
Ditto
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 08-14-2013, 03:28 AM   #3928
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,459
OT: Hog Rider,
The windshield is a Slipstreamer Hellfire SS-24V
http://www.slipstreamer.com/Product/Sport/sport.html
I have modified it to work with a set of Palmer Brackets, It needed just a little trimming in a few places to fit properly
To get the correct angle on the shield I needed to put the lower mounting points behind the Palmer Bracket and the top screws are on the outside of the Palmer Bracket
I made some bushings out of rubber and used that to allow the Hellfire mounts to attach to the crossbar. This eliminates most of the low RPM vibration.
One mistake I made was to cut the side tabs down in length, i should have left them long, You can see in this picture the part that needs the clearance
It works great and I have no buffeting, very smooth air behind the screen
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
Old 08-14-2013, 03:53 PM   #3929
GhostRiderFC
Just a guy who rides
GhostRiderFC's Avatar
Oddometer: 369
And we have a winner!! My two month old battery was bad. Warrantied by the shop. Of course, I did get hit with and hour of diagnostic and a half hour to r/i battery.
"Be Safe Out There."
IBA #: 48128
My First Ride Report - Summer 2012
My Spotwalla
GhostRiderFC is offline   Reply With Quote
Old 08-15-2013, 07:27 PM   #3930
ERD
Custom Rider
Oddometer: 384
Hog Rider,
I also noticed your windshield cracking around on the lower mounting hole of the palmer brackets. My windshiled also cracked around the same place.
Times are GMT -7.   It's 01:35 AM.
