Old 03-05-2006, 07:23 PM   #1
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,318
Harbor Freight Trailer
A few months ago I added a DRZ400 to the stable. Soon thereafter, I realized this was the perfect excuse to finally get a trailer.
Since I live in the usual HOA controlled suburbs, I needed something I could store in my garage. I decided to go with the collapsable trailer from Harbor Freight as I felt it was the best value for the money (as compared to trailer in a bag, etc).
For $229 I got the 12" wheels and chassis for a trailer rated at 1400 lbs. It comes in a box, and took sometime to assemble. It was well constructed, the instructions were excellent and there were no parts missing. The instructions include specs for the plywood planking and building your own railings.
Because i was brand new to trailers, it took me a little longer to assemble than someone who has experience. I had to figure out that receivers had different levels of drop, and that I would have to buy my own ball, hitch pin etc. All said, I invested probably just over another $100 in the trailer. That includes rails, plywood, paint, ramp materials and associated HW.
I had a trailer hitch installed on my Element by UHaul. Sure enough,the electrical connector from Harbor Freight did not match the UHaul connector. I was able to cut the outside rubber of the Harbor Freight connector completely off and make it fit.
Once assembled, it is a total of 4 x 8 feet (true dimensions) and looks like this:
I used a locking hitch pin and safety pin on the tongue:
It sure felt like a big trailer when i was assembling it in my garage. It felt even larger as I awkwardly pulled it behind the car the first time.
But add a motorcycle on it and suddenly it seems pretty small:
I used 2x10's for the ramps and kept them from sliding off by attaching a strap to the bottom and the using a temporary bolt to hold it to the trailer floor. This is working really well, but I'm now using the two planks side by side in order to have a wider platform.
When not in use, the ramps are bolted to the floor of the trailer:
Note above that I added the chock block using bolts secured with wing nuts for easy removal (Rather than spend the $50 for a removable chock).
THe rails come off in sections. I attach the rails to each other at the corners using a hinge - with one side secured permanently, and the other with a bolt/wingnut combo.
Finally at the end of the day, it gets put away in the garage. It folds in the middle, so the rear half of the trailer folds over onto the front. Keep this in mind when selecting the placement of your eye bolts for the straps.
Once folded, find a friend and lift from the front. At this point i think the thing weighs about 300lbs. The whole trailer then stands upright on a set of caster wheels so you can roll it around the garage. The caster wheels are not terribley sturdy - OK for the garage, but not for moving it around on uneven surfaces (like gravel paths).
Overall I'm very happy with this purchase - it seems like a good solution for anyone that needs a lightweight trailer and has limited storage space.
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is offline   Reply With Quote
Old 03-05-2006, 07:29 PM   #2
Sevoman
Ever Vigilant
Sevoman's Avatar
Oddometer: 902
Send a message via ICQ to Sevoman Send a message via AIM to Sevoman
Nice Job
Strong work on the trailer. How stable is it at highway speeds with the bike on it? I am looking to get a slightly larger bike (GS 1150 ADV) and will need to take it when the entire gang travels together. Looking for trailers and appreciate you taking the time to post this on ADV.
J
Sometimes it takes a whole tankful of fuel before you can think straight
The twisties - not the superslabs -separate the riders from the squids
NEVER argue with a woman holding a torque wrench
2003 BMW 1150 GSA
2005 Suzuki DR 650
Sevoman is offline   Reply With Quote
Old 03-05-2006, 07:41 PM   #3
G-Force Junkie
G-Force Junkie's Avatar
Oddometer: 1,328
Keep an eye on the bearings and tires, they are of the lowest quality, and tend to self destruct. Ive seen 3 or 4 do just that. At least pull and repack the beaings with some quality grease, they probaly come from the chinese factory with very little in them. Keep a eye on all the nuts and bolts, they tend to rattle out and loosen up. Several people I know who have those eventualy had all the joints welded up.
G-Force Junkie is offline   Reply With Quote
Old 03-05-2006, 08:10 PM   #4
GoNOW
Oddometer: 1,367
I have the same trailer, but without the folding option. It works great and it's never given me any problems. I can get 2 quads and 1 dirt bike on it.
GoNOW is offline   Reply With Quote
Old 03-05-2006, 08:54 PM   #5
koncha
Oddometer: 9,779
I know of a few people that own these trailers. DEFINITELY pull and repack the bearings. They come with very little grease and low quality bearings.
Put LocTite on everything threaded.
Since you are pulling it with an Element, you won't ever have to worry about exceding the max speed on the tires.
koncha is offline   Reply With Quote
Old 03-06-2006, 06:37 AM   #6
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,318
To answer several of the comments - yes, you absolutely have to pack the bearings before installing them. They do not come with enough grease. However the instructions do tell you to add grease (although not necessarily to pack the bearings).
I think an 1150GS would be a seriously heavy load for this trailer. I would only do it in emergencies.
I haven't taken it out on the highway, but suspect one probably shouldn't go much over 55mph. Hate to think what people are out there doing with the same trailer on 8" wheels.
F800GS review.
Old 03-06-2006, 06:49 AM   #7
ktrjc
Displaced Yooper
ktrjc's Avatar
Oddometer: 3,619
What is the max speed listed for that trailer? Or do they have one? Thinking of getting one of these, that way we will actually have room inside the truck for the kids, dogs and us.
ktrjc is offline   Reply With Quote
Old 03-06-2006, 06:55 AM   #8
motogon
Like wind
motogon's Avatar
Oddometer: 968
I used to have such trailer. Use to put two street bikes on it, drive 75 mph - no problem. Trailer had about 50000 troublefree miles on it. Sold it just because I don't need it anymore. It's great trailer!
Andrew
motogon is offline   Reply With Quote
Old 03-06-2006, 07:01 AM   #9
Freddiefudpucker
Oddometer: 88
Trailer
Okay guys,
I am now onto my second trailer that is being questioned. The first one I gave to a buddie and bought a new one last summer to help us move from NY to NC.
In it I had a 450lb motocycle and numerous other items, with a total payload of about 700lbs. I did put on larger tires from new. We criused at 70 mph no problem, didn't know we were pulling a trailer, smooth and no wiggles at all. I have the optional rails with my own way of securing them and they have hooks to take tie-downs. all is well. It has been used quite a bit since being down here and the wheels are rotating smoothly with no side play.
I managed to get a trials bike and a BMW boxer in place at the same time....with care!
I must say that the supplied grease looks a bit iffy so i will do something about that.
A GREAT buy. Get one if it suits your needs.
Regards Fred
Freddiefudpucker is offline   Reply With Quote
Old 03-06-2006, 07:04 AM   #10
goblin
pig rider
Oddometer: 371
If you were going to pull the bearing's why not just replace them with some temkin bearing while you have them out?
XRL rider western mass.
goblin is offline   Reply With Quote
Old 03-06-2006, 08:12 AM   #11
ozrockrat
Ozrockrat
ozrockrat's Avatar
Oddometer: 377
Replace the safety chain hooks with real shackles
Looking at your photos of the hitch area I would suggest you replace the safety chain hooks with real shackles
I have had the ones on my trailer (the same one) shake loose while towing.
Also consider a set of Bearing Buddy caps. They will save repacking and ensure that the water ingress will be reduced if you ever take it through any puddles.
I also drop the A frame on mine and put it behind the axle when storing. I learned from experience the hitch sticks out enough to give your shins a fair wacking.
ozrockrat is offline   Reply With Quote
Old 03-06-2006, 08:14 AM   #12
GB
Mod Squad
GB's Avatar
Oddometer: 53,446
a great report, thanks for posting.
Old 03-06-2006, 08:18 AM   #13
Wheedle
I love inflatable fun!
Wheedle's Avatar
Location: Villa Rica, GA otherwise known as Ala-damn-bammer
Oddometer: 3,725
Send a message via AIM to Wheedle Send a message via Yahoo to Wheedle
I dont know what its supposed to be, but mine has done 75-80+ from Douglasville GA to Jennings Fl repeatedly , once with two SV650s and a GSXR750 crammed on it (but mine already ate its wheel bearings and they were replaced )
Wheedle is offline   Reply With Quote
Old 03-06-2006, 09:03 AM   #14
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,318
Geat advice - thanks!
F800GS review.
Old 03-06-2006, 11:37 AM   #15
markgsnw
WTF?
markgsnw's Avatar
Oddometer: 3,471
the light foldable trailer is listed as having a 990 lb payload and 8 inch wheels. The larger one is listed as 1175 lb payload with 12 inch wheels.
http://vasaphoto.wordpress.com/
2011 Moto Guzzi Norge 8V GT
markgsnw is offline   Reply With Quote
Times are GMT -7.   It's 10:15 AM.
