Old 08-27-2009, 09:53 PM   #76
Adventure Slade
tireburner
Adventure Slade's Avatar
Oddometer: 19
oh my, that is cute!
Adventure Slade is offline   Reply With Quote
Old 08-28-2009, 02:51 PM   #77
zap2504
Dave E.
Oddometer: 605
I also have one of the 8" wheel versions. Originally purchased/assembled a very long time ago by my father-in-law to haul his aluminum boat. I bought it more than a decade ago for general use. Re-greased the bearings with synthetic grease, replaced the bed with exterior 3/4" plywood and created a 2'-high sidewall with removable tail section. Replaced the tires/wheels when they got age cracks; added a spare tire rack for a 3rd wheel. It's carried a variety of drywall and other construction materials, 4 different bikes from different locations, variety of furniture to two different colleges at either end of my state, camping equipment for some vacations and various other loads. It could probably fold, but does not have the "T" wheel setup (nor do I have room in my garage) so it sits outside. I do have a gallon of Rustoleum paint to paint it some time.
zap2504 is offline   Reply With Quote
Old 08-28-2009, 08:21 PM   #78
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,002
I've got the predecessor to the sweet Harbor Freight folding trailer:
The way the newer ones fold is much better and easier than mine. On mine you have to lay underneath and remove 4 rusty bolts. I've given up folding it and it now sits outside beside our house. I can't believe the neighbors haven't complained yet, it looks pretty rough. It's about 15 years old now and has been outside for about 5 years now. Getting rusty and the paint is flaking off, but it still works.
As others have mentioned, the bearings it cam with were not very good. I had to replace mine after the first time I used it in the rain. I've also installed Bearing Buddies, and have had no trouble since then. I estimate it has 5-7,000 miles on it, and has brought home 8 motorcycles. Still on the original tires. I always carry a spare but have been lucky so far. I've noticed the new trailers and tires carry a speed limit if 55 mph. Mind did not, and it has spent hours going 70+. Just keep them inflated correctly.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 08-30-2009, 03:47 AM   #79
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,582
Originally Posted by MrPulldown
Didn't know there were Harbor Freights in Ireland.
They don't - I was living in Colorado at the time
I agree with the loctite - I found it a good idea to check all the bolts before a longer trip, as they are subjected to a ton of vibration.
You get what you pay for. For under $300, this is a decent trailer for the money. Clearly it's not comparable to an $800-1500 trailer.
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is offline   Reply With Quote
Old 08-31-2009, 10:37 AM   #80
BobDobalina
BobDobalina's Avatar
Oddometer: 43
I got it registered at the DMV today. In and out, no problem. $12 registration fee, whoopie.
What wasn't so easy was putting the damn thing together yesterday. What a PITA But, I paid $240 for the thing including tax, with the 12'' wheels, so I can't complain too much.
Regarding the bearings, Harbor Freight sells a knockoff Bearing Buddy called something like a bearing protector. The idea is you hammer it on and fill it with grease... but I'll be damned if I could get the thing to stay on there. I hammered the hell out of it and it just fell right off every time.
I'm guessing the Bearing Buddies stay on there much better on this trailer? I'll have to order a set... if only because the grease recepticle on the hub snapped off on one of the wheels when I was filling it with grease
2005 Speed Triple
BobDobalina is offline   Reply With Quote
Old 09-01-2009, 09:39 AM   #81
67L48
Dangerously Incompetent
67L48's Avatar
Oddometer: 46
Have a HF trailer and like it. Works great. Well worth the $225.
http://klxforum.suncup.net/viewtopic.php?f=6&t=142
67L48 is offline   Reply With Quote
Old 09-01-2009, 07:58 PM   #82
Sir Not Appearing
That's no ordinary rabbit
Sir Not Appearing's Avatar
Oddometer: 1,111
About how big is the package that this thing comes in?
1998 Triumph Daytona
1991 EX500
2007 Suzuki S50
Sir Not Appearing is offline   Reply With Quote
Old 09-03-2009, 12:52 PM   #83
BobDobalina
Oddometer: 43
Two boxes, both of which fit in the back of my wife's Honda Fit. One is about 4' long, the other not so long but taller and wider. Both are pretty heavy, but they'll load 'em for ya.
2005 Speed Triple
Old 09-03-2009, 01:00 PM   #84
BobDobalina
Oddometer: 43
Curious, when you say you got two sheets of plywood for decking, did you stack them to make the deck, or use one sheet for the deck and the other for the sides? Was wondering whether it would still fold with a double-layer of plywood on there.
2005 Speed Triple
Old 09-03-2009, 02:49 PM   #85
DADODIRT
DADODIRT's Avatar
Oddometer: 3,439
I've had mine for about ten years. One big CC trip and a lot of trailering bikes around Colorado. Took it to Death Valley and back in the Spring(too much snow to ride).
About 4 years ago I replaced the plywood deck. I decided I would not cut the sheet in half as I never folded it anyway. The one time I did fold it, when I got it unfolded I pinched the wires to one of the tail lights.
Other than greasing and replacing the bearings I haven't done much.
I do carry a spare tire though I haven't had to use it.
DADODIRT is offline   Reply With Quote
Old 09-03-2009, 03:04 PM   #86
Tail Gunner
Life is Good !!!
Tail Gunner's Avatar
Oddometer: 1,584
I am not sure if this will work but it is for 20% off any one item.
http://www.harborfreight22.com/Forwa...?r=5753_919001
Drew
06 BMW HP2 - BLUE
94 Goldwing - BIG RED
06 BMW RTP - BLACK & WHITE
Meet & Greet Thursdays 6pm
Tail Gunner is offline   Reply With Quote
Old 09-04-2009, 07:30 AM   #87
BobDobalina
Oddometer: 43
Same coupon w/o having to enter in any info:
http://www.harborfreightusa.com/usa/...9&keycode=0000
And yes, it does work on the trailer if your local HF has it in stock, which it probably will. My store had 12 in stock.
2005 Speed Triple
Old 09-07-2009, 11:13 AM   #88
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
The Harbor Freight trailer I got (and is still in pieces) has little grease fittings on the hubs, inside of the wheels. Are those usable to squirt grease into the bearings? Or do I really need to pull the assembly apart?
It will only be used for a short 200 mile trip the first time out, and I'm looking to reduce my turnaround time where I have to assemble the trailer, fix the bike, and bring both back to school. Oh, and I might have to install the hitch there as well.
Do you talk to people you meet on the road?
Home is where the skid lid sits.
xcgates is offline   Reply With Quote
Old 09-07-2009, 12:16 PM   #89
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,951
They're OK to grease the bearings, but they're very cheap grease fittings, mine broke right off. I replaced them with better fittings and that's the way I grease the bearings. Grease them before going on your first trip.
I've got more time and money in my trailer than it cost me but I'm happy with the end result. It can haul 3 bikes but it did require some additional work. I use the E-track for hold down points and it works well.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 09-07-2009, 02:47 PM   #90
hugemoth
hugemoth's Avatar
Oddometer: 2,792
I've bought several of these trailers over the years and have never had a problem other than worn out tires. They've all been the 8' models, some with 12" wheels and some with 8". I have 2, 8 footers right now, 1 with tall sides used as a garbage trailer, one flat bed used to haul my ultralight and dirt bike. On the flat bed I cut and extended the axle and modified the hubs to accept 14" car wheels.
Just yesterday I picked up my first 4' one to tow my little dirt bike behind my Suzuki Swift (like a Geo Metro). It was on sale for $169 and I used a 20% off coupon for a total of $134. A few bits of metal from the scrap pile made it into a nice little bike trailer. I flipped the axle over and put it on the top side of the leaf springs to lower it a few inches. The Suzuki pulls it just fine. Here's a pic.
Times are GMT -7.   It's 05:25 PM.
