Old 09-07-2009, 07:28 PM   #91
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,033
[quote=vfr870]
I've got more time and money in my trailer than it cost me but I'm happy with the end result. It can haul 3 bikes but it did require some additional work. I use the E-track for hold down points and it works well.
That's a nice set up, but watch your shins!
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 09-08-2009, 04:43 AM   #92
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
What is a good paint to paint the plywood for weather resistance?
I'm going to be snagging some plywood that has been used for a bed for a couple years, and figure I should paint it, as it may end up stashed outside for a good portion of the year.
Do you talk to people you meet on the road?
Home is where the skid lid sits.
xcgates is offline   Reply With Quote
Old 09-08-2009, 09:08 AM   #93
BobDobalina
BobDobalina's Avatar
Oddometer: 43
Originally Posted by vfr870
They're OK to grease the bearings, but they're very cheap grease fittings, mine broke right off. I replaced them with better fittings and that's the way I grease the bearings. Grease them before going on your first trip.
Can you tell me where to get those replacement fittings? Mine broke off too.
Also, when filling with a grease gun, should I fill the cavity all the way?
2005 Speed Triple
BobDobalina is offline   Reply With Quote
Old 09-08-2009, 09:26 AM   #94
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,046
Oddly enough, Harbor Freight sells an assortment box of them, I think it was $5.
If the threads of the old fitting are still in there, this works well for getting them out. Also, just a few bucks at the store.
When greasing, I pull the grease cap on the axle and when I see the bearing covered in grease, I stop filling.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 09-08-2009, 09:32 AM   #95
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,611
I would not waste my money on that crappy set, they break off very easy!
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 09-08-2009, 09:34 AM   #96
Lil' Steve
Lil' Steve's Avatar
Oddometer: 4,046
Works just fine for a broken grease fitting.
Steve
Old 09-08-2009, 10:19 AM   #97
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
Some of the smaller, less 'corporate' parts stores have selection boxes, as do TSC's. I'll probably pick them up from TSC, as I have greater faith in their stuff.
Old 09-08-2009, 10:21 AM   #98
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
I will chime in here as well, I have had one for at least 6 years now. When I got it I cleaned the bearings and repacked them with Mobil 1 grease. Haven't had any bearing issues, ever, I do carry a spare set, they are like $3 at Walmart.
I have changed out the tires to 12 inch car radials, unfortunately nobody makes 12 inch car tires anymore so I can't buy another for a spare. In order to mount the larger car tires I had to raise the fenders about 2 inches.
Right off the bat I did replace the hitch, mine never worked smooth enough that I would trust it. I used 3/4 pt plywood for the deck which I painted then sprinkled sand all over then painted again.
I added tie downs at the corners and also added a rmovable outrigger tie downs at the front. I have towed from Raligh to Orlando with 2 DL1000's on the thing at 80 MPH. I don't think I will do that again though becasue the trailer can't handle the weight in a corner and the whole thing flexes a lot.
It takes about 20 minutes to unfold and set up by myself.
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 09-08-2009, 12:13 PM   #99
klrmoto
thumpering along
klrmoto's Avatar
Oddometer: 8
I rented a single rail kendon trailer and I was really impressed for the 5 days I used it (at ~$40/day). At times I am tempted to spend $1000 dollars on a used kendon tailer that I will use very seldom ($2000 dollars new).
When I decide to buy a trailer the HF folding trailer will be the ticket with the 12" wheel upgrade.
Any idea how much it weighs?
klrmoto is offline   Reply With Quote
Old 09-08-2009, 12:50 PM   #100
BobDobalina
Oddometer: 43
Great, thanks. Will try to find something similar, as I have no idea what size the broken one is.
2005 Speed Triple
Old 09-08-2009, 12:51 PM   #101
BobDobalina
Oddometer: 43
I believe it's 263lbs with the 12'' wheels.
2005 Speed Triple
Old 09-08-2009, 05:43 PM   #102
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
MoterBiker, what kind of paint did you use? Just some type of rattlecan outdoor paint?
I like your tip on sand, that sounds easy enough. I can just grab some from the volleyball pit about 100 meters outside my front door.
Old 09-09-2009, 05:23 AM   #103
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
It was a leftover can of paint my buddy had, I think some kind of primer, we rolled it on like you paint a wall.
Bummed about the lack of 12 inch tires now, probably have to find some 13 inch rims.
BTW, I have trailered 600 pound bikes on that thing behind my 02 Civic with 115 HP, just had to donwshift going up the big hills
I can throw my XT225's on there and tow it with my 2.4L Accord pretty easily too.
Old 09-14-2009, 06:06 AM   #104
BobDobalina
Oddometer: 43
Has anyone figured out a better way to handle the four bolts that must be removed to make the trailer fold? They're so damn hard to get rid of. I was tempted to try to fit something in there that uses a pin I could pull, or maybe a wing nut, but thought I'd see what others are doing.
2005 Speed Triple
Old 09-21-2009, 03:26 AM   #105
gman350
Oddometer: 156
I only put on 2. The ones on the side rails behind the tires. I also put them with the nuts out, that way I just reach under and slip the bolt into the hole.
gman350 is offline   Reply With Quote
Times are GMT -7.   It's 06:37 PM.
