Old 03-08-2006, 07:39 PM   #1
Johnny KLR OP
Woefully Adventurous
Johnny KLR's Avatar
Oddometer: 1,282
My Blackbird & Review
I don't know if this will get any interest, but I figured since it was already written, I might as well post it. Mods, feel free to delete.
I wrote this for another member who is interested in buying a Blackbird. I figured I'd do it 'review style'.
Honda envisioned creating a machine that would put them on the top of the big fourís top speed rivalry, to earn them a place in history as the most potent speed-machine ever produced. And they did. Kind of. They just barely edged out the venerable Kawasaki ZX-11D in top speed trials, this much is true, but during the pursuit of this goal, they wound up designing in some odd and mismatched items that create a bit of a quirky machine. The Honda build quality, attention to detail, and silky smooth precision engineering abound in the bike, but corners have been cut in an attempt to keep the machine available to the masses while still making money on all the R&D that went into the Zed-Killing ĎBird.
Itís not a sport bike, you know. It looks like a sport bike, but it really isnít. It differs in a few very important ways. First, it is way too heavy to be a pure sport bike. Secondly, the power delivery is a bit different. Third, and certainly not last or least, the ergos arenít nearly as tight. What this bike is, in fact, is a grand-touring (GT) bike that was built with a singular purpose; to go very, very fast in a straight line.
The heavy machine is at a disadvantage in the tight stuff, especially with a more relaxed geometry than a true sport bike. When entering a corner, even a long fast sweeper, a bit too hot, the bike isnít happy about a change in direction. Worse, when the rider goes to scrub off entry speed a tad too late, the weight is heaped on the front tire, causing it to flatten out and Ďkickbackí into the non-adjustable front suspension. This causes the bike to pitch back. Do this when actually beginning to lean over and you wind up with a near tank-slapper as the front tire and forks got through their little mating ritual dance. It is unsettling. Just when you thought things couldnít get any worse, in comes Hondaís most diabolical invention this side of VTEC; the dreaded linked brake system (LBS). The LBS makes this particular situation just that much worse by not allowing the rider to give a nice step on the rear brake to trail brake the bike and cause the front end to straighten out. Many riders donít have any issue with the LBS, to be fair, but this rider despises them with every molecule in his being. If thereís any good news here, it is that there are a couple of de-linking kits available. Iíll be making this purchase. I will say that I think a lot of my hatred of this system is related directly to my constant running on wet, gravely, and frozen surfaces. If you live in a nice dry climate with good roads, you probably wonít ever notice it one way or the other except in the lack of nose-dive that most other bikes with lower grade suspension exhibit, which brings me to my next gripe.
The suspension is, for all intents and purposes, non-adjustable. The rear shock allows you to dial it in a bit, but nowhere near what a bike with of this caliber should be equipped with. The front suspension is, absurdly, non-adjustable. Iím sure Honda did this to keep the costs down and hope, desperately Iím sure, that the LBS properties would keep the bike Ďflatí in a stop and mask the forkís shortcomings. Iíve already noted the nasty weight/suspension issue with the front fork, and donít think that needs any further discussion. The rear performs well enough for me to forget about it in most circumstances. The whole package works fine for daily use, and deals fine with road irregularities. It is a real-world bike that doesnít like to be pushed hard in any other condition than straight lines or very long and predictable fast sweepers. Itíll do tight stuff fine, but youíll need to really be familiar with the properties of the machine and be willing to deal with the large weight penalty and non-adjustable suspension issues. So, while the XX clearly is not a true canyon slicer, it destroys true sport bikes when it comes to other aspects of riding.
It is a fact that fighter pilots launched off aircraft carriers suffer tunnel-vision as their optical cornea is flattened under extreme acceleration. I have no doubt the Blackbird rider with a heavy hand gets to experience this firsthand. The word Ďspeedí and the Honda Blackbird are nearly synonymous. The bike was very appropriately named after a bird, and thereís no doubt this machine flies. Unlike a true sport bike, this machine doesnít require the same top-end only throttling that track derived machines do. While it doesnít quite have the bottom-end power that some of the super-standards do, it does make quite a bit down low. The delivery is nearly seamless; an exercise in linearity. Once the bike makes it to around 7000rpm, however, the engine seems to wake up from a dutiful existence of pulling the rider and chassis around and gets really gung-ho. The modern, reserved Japanese businessman who is the engine most of the time instantly turns into a ravaging Genghis Kahn and goes tearing to work destroying everything itís alter ego has created. The sound changes from a docile whir to a banshee howl as the air gets sucked down the ram air intakes, gets set ablaze and blown with extreme force out of the twin tail pipes. It is truly one of the most Jekyll and Hyde personalities in the motorcycling world.
When that wild barbarian side of the Blackbird is present, youíd best be on your toes, or heíll crush you. The Blackbird is a narcissist and is handily equipped to kill anyone, at any time, if their attention wanders elsewhere; as if it could. When the throttle is twisted with any vigor, a few different things happen. First, the world you once knew is left behind for a decidedly blurrier one. Acceleration is what this bike does best; maybe better than any other bike available. While it may not be the fastest bike on the planet anymore, or even the one that gets you to extreme speed the fastest, it absolutely does so seamlessly and with a level of competence that this rider has never found in any other bike. Super sport bikes have no refinement when it comes to acceleration; their task is to get you there as fast as possible, damn the consequences. The Blackbird can attain and maintain amazing speeds while keeping the rider in stellar comfort and control. It is stable to a fault, at any speed. I have yet to find the true top speed of this machine, and frankly I am more concerned about the tires shredding than I am about any part of the bike failing.
The bike is solid. Solid to the point of feeling like it is sculpted from a single piece. Everything is well put together and, aside from suspension, a good match of high-performance bits and gentlemanly refinement. The rider is privy to a well-padded saddle that is a single piece unit capable of accommodating two real-sized people. The finish is typical Honda quality, and the instrumentation is relatively easy to read. The pegs are a bit tight for such a large bike, but put the rider in a good position to explore the bikeís capabilities. The cliponís are well placed, if a little low, and feel Ďmeatyí in the palm. The throttle actuation throw is extremely good and very intuitive; better than most bikes (especially EFI equipped ones) Iíve ridden. The EFI programming works well, but is a bit abrupt when coming off the line. Once underway the power is easy to modulate. I think it could be smoother with some Power Commander tweaking, but not necessary.
While the true sport bike is a torture rack, the Blackbird isnít. It is, certainly, more aggressive than a super-standard, but not so much as a VFR or ST3. The rider position allows you to sit up and enjoy the air, or crawl under the paint and tuck into a Zen like tranquility that exists behind the windscreen. The reach is long enough that this rider finds the bike nearly sublime when leaning on a tank bag which is likely to be standard equipment for the Blackbird owner. As a sport touring rig, the Blackbird would be extremely difficult to displace as king of the hill; and I donít believe it has happened yet despite larger and faster bikes being introduced all the time. The Blackbird is extremely smooth; and while not to the point of being soul-less like many other Hondas, it is much smoother everywhere in the rev range. Itíll cruise happily, nearly invisibly, at 55mph. Itíll do the same at 85mph. Not much changes except wind pressure when the rider rolls at 95mph, which the Blackbird could easily maintain for hours on end.
The only reason to move for hours and hours is to get somewhere. The Blackbird is a roomy bike. Unlike a lot of sport bikes, or even GT bikes, the Blackbird takes well to having luggage draped over its sleek lines. Several companies make luggage for the bike, and with its addition, the bike goes from a refined day-tripper to a multi-state mile-devouring land missile that has the ability to tote an entire wardrobe if needed. This machine, though initially built with the single purpose of becoming the king of the top-speed hill, it managed to earn a very secure spot as sport touring mogul.
Sport touring riders appreciate some particular attributes in their bikes. In addition to the previously mentioned luggage options thereís: good lighting, the ability to run a variety of gadgets, good range, good tire life, and ease (and rarity) of maintenance top the list. The Honda has an excellent headlight that can be made better with a swap of the bulb without infringing on available power for other goodies. At 440 watts to spare, the Blackbird has enough power to drive the most common moto-goodies a sport-touring rider would fit., and the larger fairing and well laid-out instruments make it relatively easy to find a place to put them. The slightly lower power (and smooth power delivery) of the XX makes for good tire life, and with the advent of ever widening tires for more powerful bikes, the 190 rear is becoming downright affordable by comparison. The Blackbird will get about 190 miles to a tank before the reserve light comes on (there is no reserve switch). By the end of a tank, most riders will be ready to get off for a stretch. Draining the tank three times in a day is an easily attainable feat, but Iím not sure many riders would be willing to do much more unless they had some specific need. I can attest to the fact that the finding the bottom of the second tank marks the end of the seatís comfort. It doesnít take much of a break to limber back up enough to ride through the third tank if need be. Being a Honda, the inline four is nearly trouble-free. Preventive maintenance comes in at longer than normal intervals in its class; nearly double its nearest rival the ZZR1200.
Many sport-touring bikes are generally compromise machines that do nothing extremely well. The Blackbird is a bit of an anomaly in the sport-touring realm. While its forte is the ability to go extremely fast, it also is an extremely versatile bike that does an excellent job of eating miles in moderately good comfort and looking gorgeous while doing it. The Blackbird may not be king of the power or top-speed hill, but it still continues to dominate the world of long distance sport touring (with an emphasis on sport). It wonít carve canyons like a 600cc supersport, but itíll do better than most bikes in its class. It wonít put to the highway like a Goldwing, but itíll be much sportier, and decidedly more powerful for those who enjoy a more sporting perspective. The Blackbird is a rare bike that does everything very well, and few things just average, tipping the performance versus practicality scales to a point of near perfect balance. It is a bike that satisfies the hooligan speed-junkie while pacifying our responsible side. The Blackbird has a few quirks, but thankfully even these character flaws can be easily corrected, and the bike personalized to meet most riderís needs to a nearly perfect fit.
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines, Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream."
-Samuel Langhorne Clemens
Johnny KLR is offline   Reply With Quote
Old 03-08-2006, 08:09 PM   #2
sfarson
On a Ride
sfarson's Avatar
Oddometer: 2,128
Excellent review. Bikes have come and gone in the barn here but the '99 XX remains. Honda nailed it with this thing, despite the narrow niche it occupies. The colors of your first image remind of this one...
sfarson is offline   Reply With Quote
Old 03-08-2006, 10:05 PM   #3
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,351
A-plus for effort but it'd be a heckuva lot easy to read if you made the pics smaller
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 03-09-2006, 08:19 AM   #4
crackerguy
Oddometer: 173
Good review, although I think that is the first time I have seen the phrases "good tire life" and "Blackbird" anywhere remotely near one another I guess for a heavy high hp bike it does OK though.
My buddy who rides a Blackbird likes to say "life begins at 8000 rpm," it is something when the bird gets up a head of steam and starts pulling up the front wheel headed north of the ton..
crackerguy is offline   Reply With Quote
Old 03-09-2006, 08:59 AM   #5
markjenn
Oddometer: 10,419
Another compliment on a good review, but in both picture size and verbage, less is more.
- Mark
Old 03-09-2006, 09:45 AM   #6
SQD8R
Eat squids and be merry
SQD8R's Avatar
Oddometer: 7,370
good review, thx
2006 BMW HP2E: Teutonic Dreadnought
2011 Husqvarna TE630: Swedish heritage, German engineering, Italian flair
2011 BMW S1000RR: The Barvarian Bullet
Married men don't live longer, it just seems longer.
Sour grapes are a lesser man's fruit.
SQD8R is offline   Reply With Quote
Old 03-09-2006, 03:24 PM   #7
Red J
Adventureless.
Red J's Avatar
Oddometer: 769
It's a bitchin' real world do-all street bike which hauls ass.
That's my review.
J.
Red J is offline   Reply With Quote
Old 03-10-2006, 12:16 AM   #8
glynb
Relentless Underachiever
glynb's Avatar
Oddometer: 777
When I sold Honda motorcycles we had a Blackbird tht sat on the floor for months. Nobody even payed it any attention. Everybody was interested in the crotch rockets, cruisers, or Goldwings (unfortunately ST's sat on the floor unwanted too.) Finally, one of the wrenches in the back bought the bike. he said the XX is absolutely one of the best bikes Honda ever made, kind of echoed what the review said.
He let me ride it one afternoon after the shop closed. I ride an ST 1100 so I figured it would be about the same. Not even close. This thing SCREAMED . I have never experienced such acceleration out of a bike before, and it handled very well.
This bike scared the shit out of me, so the ride didnt take long. I'll stick to my tried and trued ST1100 that wont kill me unless I do something stupid. The XX will kill your ass unless you are an experienced rider. But as said before it is a beautiful machine. People are idiots for never taking a serious look at the XX or ST's . All they cared about was looking good, or sounding good.--Sheep. The XX is for the true motorcycle conosuer, and ranks with good cigars and wine.
glynb
2014 Honda CB1100 DLX
2002 Honda ST1100 "Stella" Gone but not forgotten!
glynb is offline   Reply With Quote
Old 03-10-2006, 12:35 AM   #9
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Enjoyed the review. I had a Suzi Hayabusa. I know the feeling of tremendous power and acceleration on tap with this type of bike. Can a person honestly use ALL that power on the street? No. After a 2.5K mile road trip last summer, I sold the Busa, and bought a 1 liter Strom. Much more comfortable, PLENTY of power for the street and way cheaper to insure. Reliability was (is) not a problem with either of these bikes.
As far as handling in the twisties, the Strom (IMO), handles better. On unpaved roads, no contest.
Stromdog is offline   Reply With Quote
Old 03-10-2006, 06:46 AM   #10
wickedsprint
Oddometer: 2,386
Interesting, I pay a tick over 400 a year for full covereage for my Busa, what were you paying for each?
wickedsprint is offline   Reply With Quote
Old 03-10-2006, 07:54 AM   #11
Popey
Nutter
Popey's Avatar
Oddometer: 1,708
Great review. I owned one of the earliest ones in the UK back in about 1996/7 IIRC. Did a couple of runs down to Spain on it...not much speed enforcement down there - awesome.
The fact that Honda still makes it today says a lot. Incredible bike, but I don't remember the handling being all that bad. I loved this bike.
Ed
'15 KTM 1190S
'10 KTM 990SMR
'08 KTM 690E
'08 CBR 1000RR (Track)
Popey is offline   Reply With Quote
Old 03-10-2006, 09:03 AM   #12
Mike Butt
Agent Provocateur
Mike Butt's Avatar
Oddometer: 55,635
Nice review.
The Double X was the shit for LD riding for a few years.
Mike Butt is offline   Reply With Quote
Old 03-12-2006, 10:54 PM   #13
Johnny KLR OP
Johnny KLR's Avatar
Oddometer: 1,282
Well, I'm comparing tire life to bikes in class; the 'Busa, ZZR, ZX12... The XX is pretty easy on tires; mainly due to the linear nature of its power delivery. Better yet is the slightly narrower tire (at 190) and it'll run you a bit less for new hoops.
The engine goes berzerk at about 7500rpm. I was out for 250miles a couple days ago, running with an FJR1300, 2 Tigers, a Victory, and a TL1000. I was chasing the Tigers (since they knew where we were going) and the TL was generally behind me. The TL rider was thoroughly impressed, it seemed, with the XX's acceleration. I ran it in the powerband for most of the outing.
Tell ya what though, I sure was impressed with those Tigers!
Old 03-13-2006, 01:19 AM   #14
Dixter
Boxertrixter
Oddometer: 216
Fantastic review Johnny - really enjoyed reading it.
One question I have to ask of all you guys who own these rocketships (XX, 'busa etc) - is there ever a time when not being able to use the bikes' awesome power becomes frustrating? A good friend of mine owns a '99 XX and loves it. He's a very accomplished rider, and finds the 'Bird fits his bill very nicely indeed. He's not especially quick on the bike, and doesn't really tap into its power reserves very often, if ever. I've often found that, within reason, the more often one can get onto full throttle and really use a bike's engine to the full, the more rewarding it can be to ride.
Maybe I'm looking for reasons to justify buying someting like a Blackbird, but if that's the case maybe it's not the bike for me?
I think that having a bike where I'd be riding it gently nearly all the time would become somewhat boring? It's a sincerely-asked question, and something which has bugged me for a while now.
Thanks for any ideas on the subject.
'00 Honda VFR800FiX
www.boxertrix.com
Dixter is offline   Reply With Quote
Old 03-13-2006, 07:39 AM   #15
wickedsprint
Oddometer: 2,386
I'd agree if it didn't have those goofy linked brakes.
Times are GMT -7.   It's 10:11 PM.
