04-03-2006, 02:35 PM
#1 |
Ed Venture Heir
Oddometer: 6,771
Problems
Last night I accidentally filled my Ruckus with 1.1 gal of diesel fuel. I did not start the motor.
A friend and I then lifted the bike up and sideways and dumped out as much as we could. I then filled it with .95 gal of premium gas. It idled OK but seemed down on power when I rode it approx 3 miles home. Today I can't get it to run right at all. The coolant reservoir is showing lower than usual also. I siphoned out the mixed gas and disel today and filled it with 89 octane gas. I changed the oil which looked fine. I put in a new air filter. I drained the carb. bowl. No luck. Any ideas? Thanks.
"They killed Ed Venture for what?" - Kowalski "For not being alive." - Savage Henry |
04-03-2006, 03:11 PM
#2 |
Where are we going today?
Oddometer: 14
Check the Spark Plug. I will bet it is an oily mess.
04-03-2006, 03:21 PM
#3 |
Two-Bit Throttle Bum
Oddometer: 5,008
Ditto on change the plug.
Also, does the Ruckus have a fuel pump or gravity feed? If it's gravity you might have to disconnect the fuel line at the carb and let the gas run to make sure you're getting pure gasoline to the carb. Short of that, drain the carb bowl a few more times. Probably not a big deal overall EAJ - and I doubt the coolant issue is related. Does it start at all?
-Spikehead "I was tempted by the Invisible Man, I surely was." -Propforward |
04-03-2006, 06:33 PM
#4 |
Despair & Repair Garage
Oddometer: 2,039
Ruckus gas.
Ruckui have pressurized fuel systems, with the gas tank under the floorboard. A friend of mine is putting a drivetrain from an Elite 150 into has Ruckus frame. He didn't realize that he was going to have to be dealing with fuel regulators and all that. It's definitely not a gravity-feed fuel system.
2001 HD XL1200S 1977 Vespa + 1985 Honda Elite CB550K project. "Man whoever came up with Ronald McDonald was dropping some serious acid.." - SpoonKiller / tiotalruckus.com |
04-04-2006, 09:47 AM
#5 | |
Scofflaw
Oddometer: 154
No... a small amount of diesel remaining in fuel system won't hurt anything as long as engine isn't "pinging" while running normally. Yes... I have diesel powered vehicles. |
04-04-2006, 02:19 PM
#6 |
Ed Venture Heir
Oddometer: 6,771
Thanks all.
I put a new plug in and did a better drain on the gas tank. It's running great again
