11-22-2008, 01:56 PM
#166 |
Oddometer: 2
Thanks Robert
Thanks buddy.
12-15-2008, 08:38 AM
#167 |
Oddometer: 373
Out again
Been out playin' again so a couple of pics.
Why is only me who has a working camera ![]() ![]() ![]()
Moto Guzzi V11 Rosso Corsa Highland Outback 950 Highland Motard 950 x 3 ![]() Highland for the Body and Guzzi for the Soul
12-22-2008, 08:41 PM
#168 |
Oddometer: 43
starting
Hello again Max, man your really having a bad time with your bike huh, sorry to hear about it brother.
My 2003 highland wasnt starting very well either even if i jumped it off a car. Mine also fired through the airbox and exhaust when i held the throttle open abit. John has explaned to me the ignition fires both cylinders at the same time until (i think) the ecu see's an increase in crankshaft speed then must revert to normal firing order. happy enough with this explanation, i can see this causing the firing in the inlet. When i put a Oddysey pc535 battery in fully charged it was much better - it spins over so fast theres no time for spitting out the airbox ! it just fires the fuck up . If its running funny even after you get it going remove and check the flywheel index/firing ring, the ring can come loose.there was a man in italy had this problem, manufacturing fault aparently. ( i checked mine and while it was off pinned it with a brass screw) If its not running properly just buy a new updated one and try it. Hope ya fix it and apologies if this has been metioned already in the thread. Still waiting to get mine back from overland solutions where its getting kitted out ( putting a dakar fairing on it like the photo ya posted John !) Oh... and failed my motorcycle liecence theory for the forth time - pricks. Happy christmas all !!
12-23-2008, 11:44 AM
#169 | |||
Oddometer: 373
Happy Chrismas Highland friends
12-27-2008, 03:19 PM
#170 |
2wheeled maniac
Oddometer: 119
Hi guys!
First off; MAX! The first video sounds like your starter freewheel is slipping. They ar "killable" when the engine constantly mis-fires during startup... Second vid: not impossible that this has to do with the tooth wheel on the flywheel. Check it! Otherwise, I think you need an updated firmware and software in the ECU. Cold start difficulties (engine temp below 60deg cels) was fixed in a later firmware. Then to "how the ECU works". It's mostly true about how the ecu figures wich cyl to fire at what time (as it has no cam sync..). It reads the accelerations of the crank and then fires at the right time. However... Initially the the ECU fires each cyl twice in a 720deg cycle. This is known in motor -terms as "Waste fire" or "wasted spark". So, EACH cylinder is fired at x-deg (x stands for degree value at a given load(TPS) and engine speed(RPM) ) from tdc. This gives one ignite in compression phase and one in exhaust. When the ECU has figured when it gets a burn after firing, it'll loose the "wasted spark". This is to get higher spark energy from the coils (longer charge time=more power to the spark) Back firing is due to lean A/F mixture or/and low inlet air speed (Poor A/F mixing). This is not unusual to any bike, especially big twins. But better fueling/mapping can give some remedy. Mine seldom backfires, but I'm quite careful with the throttle during cranking... A clean startup need very precise tuning of the throttle pos, the TPS adjustment to this and so on. Even if the TPS value is right, it douesn't mean that he throttle butterfly is in it's correct pos. For stock throttle I think it's somewhat like this (John can probably correct me if I'm wrong. I'm not close to my manuals at the moment). The idle stop bolt: Adjusting: turn counter clockwise until the butterfly is fully closed. Turn clockwixe an index to the fully closed throttle arm. Turn clockwise, count 4.0 full turns (1/1). Lock. Turn Ign. on. Adjust TPS to 0.65v (to know you are measuring at the right spot, move the throttle, the value should rise with more throttle.). Done. Startup: Ign on. (first check that the kill switch is in RUN) THEN, apply the choke leveler. Push starter. IF you ever touch the chocke leveler BEFORE turning ign on, it'll go BANANAS! Every time you turn ign on the ECU reads the value from the TPS and uses this value as a set point of idle pos. That's why you shouldn't mess with the chocke before turning the ignition on. ('cause in fact you are way past idle pos when fully applied choke. A/F will be rubbish during crank, the bike misfires. The rest is known.) This is straight out of my head, don't shoot me if I mistook or missed some little part. But in the big picture, this is the deal. Yep, John is coming to pay me a visit, to get the first Highland in the UK with twin inlets (I hope he'll be the first!). Just need to sort some things out first, but we'll get there. Time is my my greatest lack at the moment ![]() Happy New Year, all you Highland Riders out there! /Gs |
01-08-2009, 10:35 PM
#171 |
Oddometer: 43
Ah greasesnake !... may Alah grant you a thousand camals !! Excellent information - you very smart man
Ill have a go at tuning the throttle valve and TPS on mine when i get it back. Ild like an updated map for mine ( Alloy body ECU 2003) its possible to load this with the ECU off the bike ? Do you like Scotch wisky ? Money ? Cigars ? Tabacco ? Porn ? Could i send my ECU to you ?
01-09-2009, 11:26 AM
#172 | |||||||
2wheeled maniac
Oddometer: 119
![]() Quote:
![]() Quote:
01-15-2009, 08:51 PM
#173 |
Oddometer: 43
Cool as Mr FettSnok ! Thank you very much
I think ill have the scoot back about march... maybe. so some time in April i guess if you can spare the time. Im also chasing a spare ecu if you know who might have one, Highland say their out of spares. Do ya put spikes in your tyres and ride in winter ?
01-16-2009, 12:15 PM
#174 |
Reformed Kneedragger
Oddometer: 4,383
Does anybody want a Highland Motard here in the states? There's one for sale here in TN. PM me and I'll send a link.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides "A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad |
01-19-2009, 12:48 PM
#175 | |
2wheeled maniac
Oddometer: 119
Any labels or such? Spiked tyres is a big plus when riding on the lakes ![]() Gotta get my own for the annual MOT (sort of), need to mount the "pre-scilencers", a red reflex at the rear, some licence plate lighting, a some new turn signals and a new rear tyre... Well, it's just expendables. Quite ok after riding the bike for 10000km (yep, all those zeros) since the last MOT. (I recon about 2000km of themm, where at the red line. Poor thing |
02-03-2009, 11:39 AM
#176 |
City Dweller Crushperado
Oddometer: 284
A Pair of Dirty Twins
![]() As a new addition to the I’ve only put a few hundred K on the Allroad so not much experience with it as yet. The only addition I have for now is battery related. A Braille B14115 with 330 CCA will fit under the seat without modification. Likewise, a KTM 950 battery a YTZ14S, which is smaller with 230 CCA will fit no problem. Each battery had no problem firing up the bike. Also count me in on the intake mods, I’m not much of a wrench but I’ll give it a go. |
02-03-2009, 12:19 PM
#177 |
Oddometer: 373
Welcome
Good to have you on board Lorretto
Will be good to have a comparison from an unbiased rider. ![]() They get together over here too
02-04-2009, 11:45 AM
#178 |
Oddometer: 284
Dirty Twins
Hey John; Thanks for the Welcome.
![]() I’m not sure about the unbiased view of the KTM vs Highland comparison as I have not spent enough time with the The The issue I have with the KTM Twin is the weight, she is a big girl. I’m 175 lbs with a 29” inseam and can deal with the seat height but if she decides to take nap on the side it’s best to get out of her way. The To unleash the Even though I will probably like almost every feature of the KTM over the |
02-04-2009, 03:13 PM
#179 | |
Oddometer: 373
Both FettSnok and guys who have ridden the twin inlet bikes at the factory say the bikes run really sweet and have loads more top end, must be something worth waiting for. I just hope that Highland or one of their partners puts together a proper lightweight powerful dual sport bike that is sophisticated enough for a wide market. It would certainly be the worlds best for adventure touring. Your Allroad I think is the best version of the Highland 950, seat height and clearances making it comfortable for mere motals. It will do both on and off road well. The Motard is just a missmatch, too much suspension travel, underbraked and no top end power. Also you need a smooth engine set up on a tarmac bike. My bike the Outback is a little too tall and needs a weight reduction to really do well on the single track, it also needs an ability to chuff along at low revs on partial throttle where the going gets technical. The levers are really good off road and I've never even bent one in coming off. The steering lock has never worked but there is a luggage rack available from the factory (see my pics). Hand guards are essential, the bars help to protect the radiator when it goes over. Lots of things can be done but at the cost of extra weight. Your bike does need a new map or something 'cos mine is at its best above 3000 rpm under load, pinging up the front effortlessly. At present it runs out of puff over 8000, that is well below the rev limit but there is plenty of power below that so it's not much of an issue. Hope you are able to enjoy both bikes for some time. Lets also hope that FettSnok's modifications to my bike are successful and that we can put a few sets together for anyone who wants their Highland to run really well. ride safe John
John in Leeds screwed with this post 02-05-2009 at 04:51 AM |
02-04-2009, 06:49 PM
#180 |
Oddometer: 43
Greasey's parts finder
Hey Greasesnake
my ecu is the old aluminium type , i carn't remember seeing any labels on it though there's a couple of dates and signitures on it where its been re-programed over here. I dont know the details as was before i got it. Im travelling on it soon you see so wouldn't mind a spare if you know of any If i fry it somehow ill have to fit most components from the new system to get running again ! cheers
