Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 05-16-2009, 10:14 PM   #286
nice1trev
Oddometer: 43
low fender
Thank you very much John i dont know how you found that but glad ya did
nice1trev is offline   Reply With Quote
Old 05-19-2009, 01:17 PM   #287
nsx
Oddometer: 157
removing flywheel
Originally Posted by GreaseSnake
MOST COMMON: the flywheel "eats" the two yellow cables mentioned above, just behind the flywheel. ALWAYS CHECK THESE CABLES!!!
Is the nut retaining the flywheel right or left hand threads? I want to be sure before I continue. Thanks, Robert
nsx is offline   Reply With Quote
Old 05-20-2009, 11:46 AM   #288
John in Leeds
John in Leeds's Avatar
Oddometer: 378
Brian the Highland man from Rock and Road says it is left hand thread. Should have a puller on Friday and be able to give the thread sizes.
Moto Guzzi V11 Rosso Corsa
Highland Outback 950
Highland Motard 950 x 3
Highland for the Body and Guzzi for the Soul
John in Leeds is offline   Reply With Quote
Old 05-20-2009, 03:18 PM   #289
nsx
Oddometer: 157
I have a puller. The one for my Husqvarna fits. It's 26 x 1.5, from Motion Pro, MP#12, but the package says Dennis Stubblefield Sales, www.dssalesusa.net.
Thanks for the info on the thread.
Robert
Old 05-21-2009, 05:20 AM   #290
nsx
Oddometer: 157
Mine were beautifully secured, but at least now I know. When reinstalling the flywheel, do I do anything special? Retaining compound on the taper or threadlocker on the nut? Since it's keyed, I doubt it.
Thanks, Robert
Old 05-21-2009, 03:16 PM   #291
Lorretto
City Dweller Crushperado
Lorretto's Avatar
Oddometer: 334
Stator RR
Hey Guys:
There is a least one of us that lacks wrenching know how (that would be me) who would benefit greatly from write-up for dummies of the RR of the stator.
I got a new stator, thank you Highland Group, got the flywheel puller drawing and sourced a puller in the US that should work. Yanked the stator cover and had no way to secure the flywheel, so borrowing an impact wrench to spin the retaining nut off the crank. Learned the retaining nut is left hand thread, good to know, probably easier to get it off without adding a couple hundred lbs of torque first, thanks John & Robert.
Robert if you haven't already buttoned your bike up a photo of how the stator wires are secured would be a great help as a benchmark to look for.
Any guidance is appreciated.
Lorretto is offline   Reply With Quote
Old 05-21-2009, 05:36 PM   #292
GreaseSnake
2wheeled maniac
GreaseSnake's Avatar
Oddometer: 120
I'm quite addicted in using Loctite 222 Low strenght locking on about every threaded thing I can find on the Highland. Not including the plugs..
I think I secured my stator cables using gasket silicone, to get the cables to stay in place.
Edit: Rumor say that Mr Lind finished 3rd in the open class in the States with the 507cc. Not confirmed, but if that's a fact
then it's "quite!" impressive having that the bike is a prototype just been tested for a few months...
GreaseSnake screwed with this post 05-22-2009 at 12:49 AM
GreaseSnake is offline   Reply With Quote
Old 05-22-2009, 03:49 AM   #293
John in Leeds
Oddometer: 378
Results Johan
http://www.supermotojunkie.com/showthread.php?t=82961
a real fan
http://www.supermotojunkie.com/showthread.php?t=82648
only problem is the entrant numbers are down. SM does not seem to be that popular recently, don't know why
John in Leeds screwed with this post 05-22-2009 at 03:59 AM
Old 05-22-2009, 01:13 PM   #294
John in Leeds
Oddometer: 378
Ride out Wednesday
Nice ride round the Yorkshire Dales. Really suits the long travel comfortable suspension, light handling and torquey engine. Company was a Guzzi 1200 Sport and a Versus, nice lads.
Old 06-17-2009, 12:39 PM   #295
nice1trev
Oddometer: 43
Highland muffler size
Hope everyones well
Can someone measure the muffler outlet size for me from highland 950
I want to junk the cats and run dB dawg inserts to reduce the noise, these come in sizes
1.3 - 1.5"
1.5 - 1.75 "
1.75 - 2.00 "
Has anyone removed the cats before ? What to do ?
OFF TO SCANDINAVIA IN AUGUST !!!
Old 06-19-2009, 10:43 AM   #296
nsx
Oddometer: 157
removing cats
The cats are built into the front of the mufflers, actually into the pipes welded into the mufflers, and are VERY difficult to remove. I ended up tossing the mufflers and installing new ones without cats.
Old 06-27-2009, 01:00 PM   #297
nice1trev
Oddometer: 43
Thanks for the info nsx
I dont really know what to do now as i havent the time to muck around with these mufflers
Out of interest whats your mufflers and how much ?
Old 06-28-2009, 01:26 PM   #298
nsx
Oddometer: 157
I had some Two Brothers titanium slip-ons that I bought used for my RC51. I cut the pipes off the stock mufflers as close to the mufflers as I could and slipped the new mufflers over the stock pipes. After cutting the pipes off you still have to remove the cats, no fun, but it turned out well.
nsx screwed with this post 06-28-2009 at 01:31 PM
Old 07-03-2009, 01:36 PM   #299
nsx
Oddometer: 157
Suddenly running better!
John, my SM is now running quite well, for some unexplained reason. My gas mileage jumped from 30 to 42-45 miles per US gallon (last two tanks). What could cause this? The only thing that seems remotely possible to me is that an injector was not working properly, and now is. I had previously checked for a loose TPI or ignition pickup; everything was fine.
Now that it runs good enough that someone might actually buy it, I'm not sure I would sell. Now I'm ready for dual throttle bodies!
Robert in Oak Ridge
Old 07-05-2009, 01:25 AM   #300
GreaseSnake
2wheeled maniac
Oddometer: 120
There is something fishy going on in the woods of Sweden..
Times are GMT -7.   It's 09:11 PM.
