Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 01-31-2011, 08:58 AM   #886
Thumber
Sweden
Oddometer: 31
Winter tour
Hey Higland dudes. (and possibly dudettes)
Yesterday I had a nice ride in my neighbour hood. Some snowy and icey gravelroads, some old quad tracs a few snow mobile tracks and a hillclimb was covered within this short 20km trip.
quad tracs
Gravel road
Snow mobile tracs
Top of the hill
Rear tire, 285pcs, 8mm long BestGrip studs.
A nice ride but to short. Had to go home and do some cross country skiing with the kids. Also a lot of fun.
/TF
Thumber screwed with this post 01-31-2011 at 09:05 AM
Thumber is offline   Reply With Quote
Old 01-31-2011, 11:25 AM   #887
John in Leeds
John in Leeds's Avatar
Oddometer: 378
Thumb
Nice pics mate, keep 'em coming
Moto Guzzi V11 Rosso Corsa
Highland Outback 950
Highland Motard 950 x 3
Highland for the Body and Guzzi for the Soul
John in Leeds is offline   Reply With Quote
Old 02-01-2011, 05:51 PM   #888
Mnrider2
Mnrider2's Avatar
Oddometer: 225
My best wishes to US Highland.
06 Ulysses
09 KLR 650
Mnrider2 is offline   Reply With Quote
Old 02-12-2011, 12:52 PM   #889
Keithy
Chaotically Keith
Keithy's Avatar
Oddometer: 286
Can you imagine using those spikes in the UK John?
I'm thinking the key would be thrown away
I'll give you a bell one night and have a natter mate.
Keithy is offline   Reply With Quote
Old 02-13-2011, 05:38 AM   #890
John in Leeds
Oddometer: 378
Snakey has a set spare I reckon
Would love to try them out on the tops with a bit of snow eh?
Yep, give me a bell or pop round, always some nice beers or good coffee here
Old 02-26-2011, 12:33 PM   #891
Lorretto
City Dweller Crushperado
Lorretto's Avatar
Oddometer: 334
Need Some Help Starting
I had what I thought was a starter torque limiter issue and may still be. My bike is an 04 950 Allroad. I ordered a new limiter just before US Highland shuttered the doors along with a very sweet tiny toy like Shorai Lithium battery. The new battery and limiter should have brought joy but alas there was no joy in my Highland corner.
The bike had been getting progressively more difficult to start and finally just wouldn't properly engage the starter. Cranking was hit or miss, sometimes the bike would crank properly with no god awful noises. Other times, ie hot restart, cranking was next to impossible as it would start to crank for less than a second and make bad grinding mechanical misfire noises from the starter or just spin. Now both the new and old torque limiter just doesn't seem to let the starter do it's job; it will crank for a moment, less than a second, and then spin totally free.
It is possible I got a bad new torque limiter or I messed up on the install. I have had a bad new voltage regulator and a bad new battery which makes it difficult for the mechanically dopey to sort such things out. I always had assumed replace old crappy stuff with new shiny stuff and the problem is supposed to go away. Not so much this go round.
I was looking at the KTM Adv which had torque limiter issues on some of the later model bikes. One the issues discussed was a “Sprag” being the culprit for non-starting other than the torque limiter. I am a little embarrassed to say, I don’t know what a “sprag” is never mind what it does. I don’t even know if the Highland has a Sprag. Anyway, if somebody can point me at what to check, any help would be appreciated
Lorretto is offline   Reply With Quote
Old 02-26-2011, 01:59 PM   #892
benzok
benzok's Avatar
Oddometer: 7
The Highland do have a "sprag", a sprag is a one-way freewheel clutch. It resembles a roller bearing, and get to it you have to remove the flywheel and the cover behind it.
I have replaced mine , it is fairly simple.
'99 Highland 950
'00 Triumph Sprint RS
'06 EXC 400
'13 Gas Gas EC 300 F
benzok is offline   Reply With Quote
Old 02-26-2011, 04:31 PM   #893
dentvet
Oddometer: 1,370
here's everything about sprag repair
http://advrider.com/forums/showthread.php?t=222515
i'd love to check your bike out sometime
dentvet is offline   Reply With Quote
Old 02-27-2011, 10:02 AM   #894
Lorretto
Lorretto's Avatar
Oddometer: 334
Thanks Benzok the picture helped out a lot
I found the description of how to swap the the Highland "Sprag" freewheel hub just in case anybody else turns up SOL on starting.
Assemble the transmission cover and gasket
(221032-01). Lubricate, the shift shaft with
grease. Turn the impeller shaft so it fits in the
slot of the primary gear nut. Secure cover with
four M6 screws (306130-22) and two longer
M6 (306130-30). The 30 mm. screws fits
where the alignment sleeves are located.
22. Assemble hose connection (900022-01) to the
water pump cover (900098-01) The complete
water pump cover secures to the transmission
cover with four M6 screws (306125-229 and a
gasket (221008-01)
23. Mount the oil line (261036-01) from oil line to
oil filter. Use banjo bolt (960072-01) and two
cooper washers (320160-01). Make sure that
there is clearance between crankcase and oil
line.
24. Mount gear shift pedal (231073-01) with M6
screw (306621-22)
25. Mount the free wheel hub (251059-01) on the
crankshaft end. Lubricate the free wheel
bearing (201057-01) with engine oil and
assemble into hub with a turning motion. The
locking spring of the bearing must face
inwards to function.
26. Lubricate the bearing (360017-01) and place it
on top of the free wheel hub. Assemble the
start gear (251056-01) by turning it into the
free wheel bearing. Place a washer (251058-
01) on top of the start gear.
Dentvet: Thanks for the link. If you find your way into DC just let me know. Your welcome to check the bike out. Course it would be a little better if the beast would light up.
Since I didn't know what a sprag was, the freewheel hub was equally unknown to me. It helped to see the photos. It was throwing me off on the Highland as I had removed the flywheel to replace the stator and didn't remember seeing the freewheel hub assembly. On the Highland it apparenly is behind the stator housing.
So next question. Anybody have any idea who the MFG is of the Freewheel Hub or any kind of cross reference or a big ass kick start conversion.
U.S. Highland question - Are you guys done? If so, where did the parts inventory go? If not, I need some bits and how does somebody get a hold of you?
Old 03-03-2011, 08:28 AM   #895
benzok
benzok's Avatar
Oddometer: 7
Lorretto,
On my invoice it says free wheel Borg-Warner
I found one picture of the sprag in situ, unfortunaltely i've lost all other pictures from the repair
From Highland
'99 Highland 950
'06 EXC 400
Old 03-03-2011, 09:19 AM   #896
Lorretto
Lorretto's Avatar
Oddometer: 334
Thanks Benzok
Thats a big help to know that Borg Warner was the MFG and gives me something to work with.
I also contacted the U.S. Highland consultants to see if they can help with the parts or a list of the manufacturers. I got a response that they would try and get one of the operations guys to help me out.
Old 03-29-2011, 04:05 AM   #897
GreaseSnake
2wheeled maniac
GreaseSnake's Avatar
Oddometer: 120
Thanks Benzok
I've tried to get through via my connections, no answer on the phone at the moment. I'll reply here as soon as I get the info. Shall I buy one for you?
Kr
Johan
(sorry for my absence, been a bit too much on my shoulders lately... Better now! )
A visit to John in Leeds was a good recovery
2000 Highland 950 Motard (Project Hooligan)
2008 Aprilia RSV1000R Tuono Factory (Project Big BIG bore )
2004 Highland 950 Motard (Twniletified and ready)
2007 Aprilia RSV1000R Tuono (for the missus)
A 100% Sushi-free
Highland for the fun and Aprilia for the run
GreaseSnake is offline   Reply With Quote
Old 03-29-2011, 04:55 AM   #898
Calvin T
Calvin T's Avatar
Oddometer: 14
Sorry to hear of your ailments, just thought I would show my face here, I still have my orginal 03 Motard.
I'll bomb over soon John if you are about.
Calvin T is offline   Reply With Quote
Old 03-29-2011, 12:53 PM   #899
John in Leeds
Oddometer: 378
Anytime
It'll be good to see you at last Calvin
Old 03-29-2011, 01:24 PM   #900
John in Leeds
Oddometer: 378
Oh yes!
Good for me too, after Johan worked his magic on my recalcitrant ecu management software. His latest map installed the Outback ran sweetly and with far greater economy.
The following day we took his latest Tuono (does he really need 2?) and Heidi (the Outback) for a run round the Yorkshire Dales, both beautiful and challenging. Starting to warm up as we headed into Nidderdale
Call in at the Druids Temple
Stopped for lunch in Masham
Then on and up over Fleet Moss.
Don't know how he stood it but the short travel suspension on the Tuono doesn't make it the ideal tool for the bumpy roads round here. Don't know how he wasn't crippled after that run. Seemed to be getting a lot of air in the mirror
Having breather under Kilnsey Crags
Then on to 'Route 65' in Ilkley where they have many exotic bike for sale including immaculate RVF 750s, RG 500s, Yamaha 500 4 cylinder two strokes, sundry MVs and tasty racing Dukes - lots of money though
Finish the day with a few beers in Woodies our local pub with a feed, entertainment provided by the local student population in fancy dress (MY God, those Lasses must be freezin')
A big thanks Johan, come again
Times are GMT -7.   It's 03:57 AM.
