08-21-2008, 04:48 AM
#121 | |
Oddometer: 76
Robert |
09-18-2008, 12:29 AM
#122 |
Oddometer: 373
Highland ATK tie up
This seems to point to the way things are going in the US
Interview with Richard Harrisson race engineer http://www.youtube.com/watch?v=u7ROEoTNT7o |
09-21-2008, 02:39 PM
#123 |
Oddometer: 43
Hello all
Nice bike greasesnake ! Like what youve done with it - crazy sweeds
Mine was one of the early imports into the uk and runs the old style ecm like yours. Ive just reassembled it with 20% harder springs front and rear , magura hyrdaulic clutch - much better scott steering damper new model exhaust new model plastics Its also got 6 piston front brake which is nice Goes like stink im not even concerned about the rough idle as im coming off a '98 ktm 620 and its sooo much better than that thing.(Ill send photos when i work out how to make them smaller) Hello there John hope your well - ill give ya a ring soon To max red kadett - i like your style travelling to france from kiev for your bike ... im sure youll be very pleased when its running properly ! (I have pdf assembly instruction manual if you want) Grant scotland uk
10-04-2008, 03:55 AM
#124 |
Oddometer: 373
No suspension, no ground clearance, NO Problem!
10-06-2008, 04:01 AM
#125 |
Oddometer: 373
ECU setup in UK
For Highland owners in UK. I have purchased the ECU management update software together with some spares from Tim the previous Highland importer. If anyone needs some attention to their ECU just contact me and I'll do my best to help.
I think things are likely to be a little quiet until I can get together with FettSnok to get an upgrade for the inlet system, until then I will post some of Tim's dyno results taken from a Power Commander dyno. He was getting about 89 rwhp by removing the existing airbox and cats in the exhausts. Seems somewhat better than the results from MCN on their test (72 hp). Puts it a bit closer to the KTM 950 (92 ontest) but still strangled at the top end.
10-16-2008, 02:53 PM
#126 |
Oddometer: 43
Hey John
now thats sounds interesting ! wonder if it does anything for the start up and idle ? also wonder if it communicates with the old style ecm , do you run it through a laptop or just plug a box in somewhere Have you any news on highlands new factory / bikes progress, i tryed looking for the highland/atk bike but couldnt find it Cheers mate hope your well
10-17-2008, 01:23 AM
#127 |
Oddometer: 373
Hi Grant
I think the set up will communicate with the older ecu. I have yet to experiment with the mapping and if you fancy bringing your bike down we could try some stuff. I think most of Tim's mapping efforts were going towards power and racing whereas I will concentrate on ride and sweet running. There is likely to be some improvement in the starting but remember the ignition has to interpolate it cylinder recognition as it has no cam position sensor. The fitting of the new Oddysey battery has improved starting significantly. Still no news from any of the Highland tie ups except that posted in #124. They are playing things very close to their chest and I don't think this devastating slump/depression will help one bit. I think for the time being out best hope at getting our bikes to run to their astonishing potential is with FettSnok (Johan). Let's hope his latest development is successful. If it is I know where my money's going. Cheers John
Moto Guzzi V11 Rosso Corsa Highland Outback 950 Highland Motard 950 x 3 ![]() Highland for the Body and Guzzi for the Soul
10-17-2008, 09:11 PM
#128 |
Oddometer: 43
Yeah John i definatly think the oddysey battery is the way forward even though i had to hack mine to bits to get it in there - pc535 from memory, very tight height wise but the side fins can be shaved off and it fits neatly shall i say. Improved cranking speed greatly, i only tried it for a day due to shipping it of to overland solutions in a hurry but it solved the starting probs i had. very confident...i think
(did you run a pc 535?)It is a shame about the slump in the economy , these guys could do great things - have ya seen the '07 450 supermotard - mega !
10-18-2008, 11:33 AM
#129 | |
Oddometer: 373
10-24-2008, 02:38 PM
#130 | |
Oddometer: 373
It might help if you specifically described how your bike was running and what symptoms it showed. None of the Highlands except the dual inlet versions run at all sweetly. Mine is not at all good below 3000rpm. An updated ecu map may make a difference. keep us informed
10-26-2008, 01:21 PM
#131 |
Oddometer: 373
Lost again John?
Fell off on the wet grass with the road tyre on the back. Better with the 47 tooth rear and 17 tooth gearbox sprocket combination. The front Bridgestone nobbly was excellent off road and on.
![]() and yes it is a KTM, Gavin's nice example of a 950
John in Leeds screwed with this post 10-26-2008 at 04:15 PM |
10-27-2008, 02:26 AM
#132 | |
Oddometer: 373
Also they are shown on the LuoJia Highland site here http://en.luojiamotor.com/product/Pr...oductClassID=3 I expect the agreement is that Highland China will handle any road bikes from now on. What does concern me however is that the ATK connection seems to be falling down see http://atkmotorsports.com/atkbb/view...5b6e8967186d0a I thought there would have been some good developement as both companies are involved in track competition. Once again thing don't look good, that said I enjoyed my ride out in the Yorkshire Dales last Friday. Good bike - great fun
10-30-2008, 03:04 AM
#133 |
Oddometer: 373
So come on Max, just what are the problems?
you never know, we might be able to sort something
10-30-2008, 07:12 PM
#134 | |
10 fingers 10 toes
Oddometer: 12,010
I don't agree with you statement. The valves on my 04 650 are rock solid. The highland motor looks way different from the bergs. There is a guy in Colorado who is in tight with highland. They said that he did some design work for the. He has two Highland or his own built twins with Hiland motors in them. He has run them for a few years now. I run across the guy a couple of times. He is always riding those bike. They look great and run strong. I know if Highland was importing into the US I would probbly be riding one of thier twins right now.
Why are we stopping?: Wayne Weber |
10-31-2008, 05:21 AM
#135 | |
Oddometer: 373
Cheers John
