Old 04-18-2006, 07:42 AM   #1
R1150GSA OP
Saint "Alloy"sius
R1150GSA's Avatar
Oddometer: 26,174
Stella Owners - Check Your Screws
All of the hex screws in my front brake rotor were loose upon returning home from a ride this past Saturday. ALL OF THEM!
Had I not investigated the strange sound coming from my front end I would never have known.
If you find that yours are loose, beware. They are made of pretty soft steel. Don't overtighten them or you'll strip the heads. I'm not going to tell you how I know this. Just trust me, OK?
IBA #17734
R1150GSA is offline   Reply With Quote
Old 04-18-2006, 10:04 AM   #2
RiverRat280
RiverRat280's Avatar
Oddometer: 751
Use a little blue locktite and you won't have to worry about it again.
"Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who niether enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat"
-Theodore Roosevelt
RiverRat280 is offline   Reply With Quote
Old 04-18-2006, 08:52 PM   #3
Srbenda
Embassy of South Carolina
Srbenda's Avatar
Oddometer: 11,980
Cat-Daddy-O, where have you been?
It seemed to me that the earth may he borrowed but not bought. It may be used but not owned. It gives itself in response to love and tending.... But we are tenants and not possessors, lovers and not masters.
Srbenda is offline   Reply With Quote
Old 04-19-2006, 10:43 AM   #4
R1150GSA OP
Saint "Alloy"sius
R1150GSA's Avatar
Oddometer: 26,174
Praying for all of you. How've you been BreadMan? Happy Spring!
IBA #17734
Old 04-21-2006, 07:48 AM   #5
wanderingwaldo
wanderingwaldo's Avatar
Oddometer: 6
lockwashers
if you've got enough thread (4 threads are about all you need for most bolts not in an exceptionally agressive application) split lockwashers are great to prevent bolts from backing out, and won't get you in a "sticky" situation when dismantling as adhesives can.
wanderingwaldo is offline   Reply With Quote
Old 04-22-2006, 04:00 PM   #6
R1150GSA OP
Saint "Alloy"sius
R1150GSA's Avatar
Oddometer: 26,174
Speak English, you half-bake! I just put stainless steel bolts in with blue LocTite and everyone (and I mean EVERYONE) has an opinion.
You know what? I put those stainless steel screws in and who cares? They're in! I'm so sure they're better than the screws our Indian friends installed, I willing to bet my life on it.
There. I'm done. Over and out!
IBA #17734
Old 04-23-2006, 09:53 AM   #7
wanderingwaldo
Oddometer: 6
I was just giving some friendly advice, no need to be rude.
Old 04-23-2006, 11:28 AM   #8
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
Don't mind him. He's just upset that he stripped out the head on one of those precious stainless screws and needs to take it out on someone who is right.
He'll be better after communion (Father Muldoon always slips him a Prozac instead of a host).
JohnTM is offline   Reply With Quote
Old 04-23-2006, 11:29 AM   #9
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
PS: Welcome to the Asylum!
Old 04-23-2006, 11:53 AM   #10
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,231
Is blue Loc-Tite heat resistant enough to use on rotor bolts? Just wonderin'.
BTW ... I don't believe in lock washers, personally. In the NASA Fastener Design Guide, the author states the following regarding helical split washers: "In summary, a lockwasher of this type is useless for locking."
PS: Welcome aboard, Waldo!
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 screwed with this post 04-23-2006 at 11:59 AM
Jack90210 is offline   Reply With Quote
Old 04-24-2006, 06:07 AM   #11
JohnTM
I suck toes
JohnTM's Avatar
Oddometer: 29,206
Good point! Both blue and red loctite release when hot, and it doesn't take that much heat. One way to find out. Use the loctite, go for a ride, then see if the screws turn out easily while the rotor is hot.
Times are GMT -7.   It's 07:59 AM.
