Old 07-07-2008, 05:53 PM   #15016
adriftAK
adriftAK's Avatar
Oddometer: 50
Originally Posted by Chuck Chiodini
Lewy wrote "Looking into using a vacuum or electric pump to use up the last little bit."
If you rotate the fuel inlet on the carb to the 8 o'clock position you will be able to use all the fuel less an ounce or two. Same setup I run except I have a small bronze in-line fuel filter from a bike shop in the "common" line to the carb. I removed the OEM white plastic fuel strainer from my inlet tube when I rotated it. No need for a pump IMHO or experience.
Good luck!
Can the inlet be safely rotated with some force or do you mean actually bending it? Don't want to break it
07 DR650
~Rapid motion through space elates one~
J.Joyce
adriftAK is offline   Reply With Quote
Old 07-07-2008, 05:56 PM   #15017
Brewcelero
Oddometer: 32
2nd Try
Hello, I couldn't figure out how to post them, so here is a link to my pics:
http://www.photoshow.com/watch/Sx6HE2HN
Brewcelero is offline   Reply With Quote
Old 07-07-2008, 07:40 PM   #15018
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
It will rotate. Use a vice if the carb is off the bike.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 07-07-2008, 08:40 PM   #15019
macdesign
Just another f@t b@st@rd
macdesign's Avatar
Oddometer: 136
KTM USD's on a DR650
Originally Posted by LukasM
Yeah, some people have done it and posted in this thread. I am one of 'em! Check out the link in my signature (yeah I know I have to update the log...).
Thanks Lukas you have saved me a bunch of time measuring stuff.
I'm onto it asap.
If it ain't broke, modify it.
'07 GSX1400 for .... my ego
'08 DR650 for .... everything the 14 doesn't do
'69 Honda 750-4 for teaching my son how to build bikes
macdesign is offline   Reply With Quote
Old 07-07-2008, 10:43 PM   #15020
El Toad Man
Offroad adventurer
El Toad Man's Avatar
Oddometer: 636
It will rotate with enough force. The trick is to not crush the elbow before it rotates.
Shown here:
http://www.advrider.com/forums/showthread.php?p=5121717
KLX650C 1993
El Toad Man is offline   Reply With Quote
Old 07-08-2008, 02:55 AM   #15021
DRjoe
DRjoe's Avatar
Oddometer: 5,256
Originally Posted by PhL0aTeR
Well im glad.... lol.... cuz i did it today and nearly fell off the bike laughing so hard at how loud it was...... i figure next time someone is an idiot and talking on their cell phones ill hold the kill switch in for a few seconds then let it out KAPOWWWWWWWW
watch out it can fairly mess with the packing in your silencer.
I had a d*!k head of a mate who used to do it with his car, every time he did it a big chunk of smoldering packing would fly out of the exhaust.
DRjoe is online now   Reply With Quote
Old 07-08-2008, 04:43 AM   #15022
svwayne
Oddometer: 945
Originally Posted by scootertrash
There's the neutral switch. I locktited the lower screw and removed the upper screw with a flat screwdriver and hammer as a chisel. It wasn't loose, but it came out real easy. I will eventually replace with a hex bolt, but for now, the lower screw is holding it in and is securely locktited.
I'm tempted to remove the switch while I'm in there. Will it come out at this point or am I going to have to pull the clutch basket?
Thanks for taking the time to post the pics.
svwayne is offline   Reply With Quote
Old 07-08-2008, 05:08 AM   #15023
dedsmurf
dedsmurf's Avatar
Oddometer: 398
right click the pic on your site, select "copy image location" (link) and then when posting click the "insert image" button in the wisiwig toolbar and paste the link. the pic stays on your site but is simply linked to the forum page.
no uploading.
just dont remove the pics or the link will be broken and ppl wont see your great ride(s)/tool/mod/oops....
09 GSA
84 RD350
Bergman650
dedsmurf is offline   Reply With Quote
Old 07-08-2008, 07:10 AM   #15024
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,870
All you need is a small air impact to pop the clutch off. Put in some longer bolts after cleaning the case and loctiting the bolts and your done. Not too sure about running it with one screw holding it in place.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-08-2008, 07:13 AM   #15025
PhL0aTeR
10:90
PhL0aTeR's Avatar
Oddometer: 511
Does the stock exhaust have packing?
2006 Suzuki DR650
PhL0aTeR is offline   Reply With Quote
Old 07-08-2008, 07:13 AM   #15026
Foot dragger
singletracker
Oddometer: 12,870
Heres a pic of mine with two longer allen head screws loctited in place,didnt take long to get the clutch off and change out the screws and put the clutch back on.
Foot dragger screwed with this post 12-16-2010 at 08:54 AM
Old 07-08-2008, 07:15 AM   #15027
Foot dragger
singletracker
Oddometer: 12,870
Nope,all metal baffles. Probably not the best thing for the bike to make it backfire though. My old BMW does it when the points are dirty.
Old 07-08-2008, 08:26 AM   #15028
IL_Bow_Man
Oddometer: 10
Well, I pick her up tonight...an 08 Blue DR650SE.
So now I need some help on what everybody thinks the best mods for the buck are. Short term it won't see any heavy duty off road, but it will see some.
I read all sorts of different mods that are common. Suspension, Air Box, Skids, etc... Can somebody give me a link to the air box mod? I can't seem to find a good one.
I plan on skids and upgraded hand guards in the near future. Maybe taking down the front sprocket by a tooth, but I will see how it goes for now.
Tell me what you think should be on my list.
Another quick question...if I search sites by my model of bike for accesories, it doesn't list anything. I am guessing because it is new?? Will an 08 fit the same accesories as an 06?
IL_Bow_Man is offline   Reply With Quote
Old 07-08-2008, 08:32 AM   #15029
DevilofSky
DevilofSky's Avatar
Oddometer: 78
hey guys...
i'm in italy... do you know where i can find a cheap side racks for my dr... posted 2pages ago... 190$ are too much...
Just an italian guy
DevilofSky is offline   Reply With Quote
Old 07-08-2008, 09:26 AM   #15030
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
When you're shopping for mods, they are pretty much all the same from '96 to this year's model.
Go to kientech.com for a picture of the airbox mod. Keep in mind tho, that the airbox mod is best done with a jet kit. The stock needle profile doesn't work easily with an opened up airbox. Best first step with the carb is to yank the snorkle from the airbox, shim up the needle ~.040" and unplug the pilot screw so you can dial in the idle mix. Search the thread for carb needle shim or some such and you should find lots of info.
Check out the Wiki page http://dr650.wikia.com/wiki/Main_Page for a good overview of what to do with the new toy.
itsforrest is offline   Reply With Quote
Times are GMT -7.   It's 02:55 AM.
