Old 12-20-2009, 02:36 PM   #29911
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 432
Originally Posted by NC Rick
We got 12" of snow S.E. of Asheville, NC mucked things up for the weekend. We kept power but some of my shipping did not get out on Friday.
Rick --
Guess that means my shock is snowed in????
-- alonzo
alonzo is offline   Reply With Quote
Old 12-20-2009, 03:24 PM   #29912
TRAVELGUY
Old Traveler
Oddometer: 699
That's the one I saw a Harbor Freight today. Looks much like the one I have been using and is cheap enough for almost anyone.
TraveGuy
Originally Posted by Mfed
This one, right? linky
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 12-20-2009, 04:33 PM   #29913
psmcn
psmcn's Avatar
Oddometer: 22
19"
It did a little snowing yesterday in the DC area.
The DR is incapacitated right now
THe picnic table is in use as well
Never Leave your wing-man
2001 DR650
1996 GoldWing GL1500SE
psmcn is offline   Reply With Quote
Old 12-20-2009, 10:10 PM   #29914
JibJab
Oddometer: 38
Procycle Low Mount Fender Kit
Anyone had an opportunity to install Procycle's new Low Mount Fender Kit? I'm wondering how well it fits, sturdiness of the plastic, ease of mounting, amount of wheel coverage width-wise (picture on web makes it seem a little thin, like water would spray up on the sides), etc. Does it have to be painted or can you just go with the black? Any feedback would be great to hear.
Thanks...Andy
Andy
2001 Kawasaki ZR-7S
2010 Kawasaki KLX250SF
JibJab is offline   Reply With Quote
Old 12-20-2009, 10:48 PM   #29915
Jay
Redbear Rides
Jay's Avatar
Oddometer: 159
Check DR350 thread for info on petcocks
Originally Posted by Elvis70
Easy solution is to get a plastic tank and new pet cock with it. Other wise clean it out once in awhile to keep it from hanging open.
I am learning the hard way with a failed petcock membrane.
"The Ride is the Reason"
1998 Suzuki DR350SE Bearcub
1995 BMW R1100GS Redbear
2001 Suzuki DRZ400S Yellowbear
1981 Suzuki GS850G
1980 Honda XR500 Big Red
2001 F650GS Dakar w/ Ural - Fast Kitty (Wife's Bike! )
Member: CCBR, AMA, BMWMOA, NRA, CRPA, CCRKBA
Jay is offline   Reply With Quote
Old 12-21-2009, 10:40 AM   #29916
drdirty
drdirty's Avatar
Oddometer: 92
Thanks...Andy
drdirty is offline   Reply With Quote
Old 12-21-2009, 11:57 AM   #29917
thumperdr
thumperdr's Avatar
Oddometer: 6
2000 DR650 Fuel in air breather box
Does any one know why Iam getting fuel in the air breather box ?
I tryed to start it today, It flooded I got it to crank but the breather
box is still filling up with gas. Thanks if any one can help ...... Joe
thumperdr is offline   Reply With Quote
Old 12-21-2009, 12:04 PM   #29918
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 497
Grip heater switch mount. Piece of aluminum sandwiched in right bar riser
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 12-21-2009, 12:12 PM   #29919
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 497
12v outlet location. No bracket--uses existing screws.
'08 Suzuki DR650
'15 Yamaha FZ 07
Old 12-21-2009, 12:27 PM   #29920
bigdon
Oddometer: 2,662
I would check the O ring under the Float assembly or check for junk under the float needle!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 12-21-2009, 01:05 PM   #29921
HugoBLISS
here and gone....
HugoBLISS's Avatar
Oddometer: 69
Originally Posted by HugoBLISS
So, we live 4 miles from pavement . The dirt is native clay without the benefit of any added gravel. After a full day of rain I was commuting home on my new DR650 and left the pavement to find that, sure enough, the clay was saturated, thick, sticky and deep; I struggled through on my Deathwings. Several pounds of wet clay continued to jam between rear wheel, rear shock and swingarm and I continued to dig it out with sagebrush branches. I worked the clutch hard to keep moving.... Made it home but the DR had lost all clutch play . Changed the oil to determine how much of the clutch had disintegrated. I found enough aluminum flakes in the oil to require 3 more oil changes to come clean. There was no adjustment left at the lever so I moved the clutch arm in one notch and all seems fine. Do I go in and take a look or let the dealer do it (since it's still under warranty)? Thanks in advance for any offered wisdom.
HugoBLISS is offline   Reply With Quote
Old 12-21-2009, 01:10 PM   #29922
Paloma Paul
Paloma At Its Best
Paloma Paul's Avatar
Oddometer: 385
Thumb 19"
Sorry about the snow, here in sunny sw arizona its tshirt and blue jean weather
Paloma Paul is offline   Reply With Quote
Old 12-21-2009, 01:45 PM   #29923
Radar51
Oddometer: 75
DJ Kit
Just ordered a DJ kit from Jesse. Any advice using stock exhaust and filter for now.
09 DR650SE (White they are faster)
Radar51 is offline   Reply With Quote
Old 12-21-2009, 01:54 PM   #29924
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 5,000
ask Jesse. He knows all.
"When the monkey tells you to give it up, give it up." ~ Bubba Satori
monkeyfez is offline   Reply With Quote
Old 12-21-2009, 02:59 PM   #29925
Paloma Paul
Paloma At Its Best
Oddometer: 385
rear shock leak
Just came back from a ride and noticed oil all over rear shock linkage. Seems my oil seal for shock is leaking. Did a search but....... anyone know where I can get a rebuild kit for the rear shock of a 98 650?
Times are GMT -7.   It's 09:42 PM.
