Old 10-12-2010, 07:31 PM   #40561
bross
Where we riding to?
bross's Avatar
Oddometer: 4,549
Originally Posted by thumpididump
I love it ! That's something I would do. Finding creative ways to make something work... better.
I wanna know how the takeout was?
Old 10-12-2010, 07:40 PM   #40562
toddiscdn
Take off, EH!
toddiscdn's Avatar
Oddometer: 1,019
Originally Posted by svwayne
Got my new Seat Concepts seat over the weekend. Quality appears to be top notch. I have not installed the cover/foam yet but on initial look it appears the Seat Concepts foam is ~1" lower right in the "valley" up near the seat. I spend a lot of time "up on the tank" offroad and my old knees need all the help they can get when I need to stand up. If you've got a Seat Concepts seat then have you noticed that it appears/feels lower when sitting up near the tank?
I'll probably give them a call tomorrow but wanted to get the general consensus from those in the know.
Mines not any lower front to rear anywhere that I noticed, just wider at the rear.
Cheers, Todd
"It's all about the beer"
drcool
08DR650 - Jack of all trades, master of none
toddiscdn is offline   Reply With Quote
Old 10-12-2010, 08:22 PM   #40563
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Won't start but will later
Originally Posted by dirtmucker
I was out doing a slow speed follow the leader drill with a buddy today. I stalled my bike and it would not start. Plugs were changed less than 2,000 miles ago and valves were adjusted at that time. We pushed the bike to the top of a hill and then I bump started it while holding in the starter button. The bike started again. It stalled again a few minutes later and would not restart. I towed the bike home and changed the oil since it needed it. I just rode around 2,500 miles round trip from SoCal to Colorado for the MXon and even with a 16 tooth front sprocket, it was a long hard slog for the bike. After I changed the oil, I hit the starter and the bike fired right up. I let it run for a couple of minutes to let the oil warm up and check for leaks. I shut it down and then tried to start it again. No go. After my Colorado adventure, I had put 36 miles on the bike on short trips in the area and before the stall, had run the bike for nearly an hour today with periodic engine stops and restarts. Lots of gas in the tank. Anybody got any ideas?
That's what my bike did... it was the little fuel filter that's in the end of the carb fuel intake. Remove the fuel line and use your finger nail to remove the little white strainer screen and use air to blow out. A soda straw from the tool box works in the field. Replace filter and buy a lawn mower inline fuel filter and install it too. Now you have two filters in a row. NO dirt will get into the carb.
happy riding
Dave
smilin jack is offline   Reply With Quote
Old 10-13-2010, 09:49 AM   #40564
jenx
misadventurer
jenx's Avatar
Oddometer: 553
I remember the biggest improvement in fuel consumption resulted when I lowered th needle.
+1 Thump. That needle plays a big role. I'm getting around 4,5l/100kms after dropping one clip to second. That's slightly less than a ten percent improvement in consumption. The bike runs a tad hotter tho'- but not much.
Plans to get my own piece of paradise (comments and advice welcome):
http://mountain2c.wordpress.com/
jenx is offline   Reply With Quote
Old 10-13-2010, 10:46 AM   #40565
gogogordy
gogogordy's Avatar
Oddometer: 1,941
front tire size questions....
I am preparing to put some Shinko E705 on my DR650, am curious if it's possible to "upsize" the front from 90/90 X 21 to something a little bit "fatter".
My bike is bone stock, the ONLY obstacle I can see could be the metal fork boot clamps...which could rotated so the tabs face to the rear.
Has anyone bumped up to a fatter aspect ratio up front?
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 10-13-2010, 10:57 AM   #40566
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I don't think there is another aspect ratio for the E705 Shinko front. I would not even go there. It won't help anything ... and could get very weird. If you want to run wider tires I would swap over to a 17" front Super Moto set up. But even that can get weird if not set up right. When you do that you are getting into balance, bias and geometry changes. Tricky.
Stick with the 90/90 front. It's hard to believe ... but they perform very well on pavement leaned over to the max. Yes, its a skinny tire but its a light bike. When it slides, its quite predictable and gradual. (this with the 705 which I've got on the front now ... Distanzia rear)
Old 10-13-2010, 11:00 AM   #40567
Mariner55
Oddometer: 37
2009 Dr-650
Hello,
2009 DR-650 with 2200 miles. $4695.
Is this a good deal? John
Mariner55 is offline   Reply With Quote
Old 10-13-2010, 11:05 AM   #40568
gogogordy
gogogordy's Avatar
Oddometer: 1,941
Good advice, I hadn't considered those implications. Will stick with the OEM sizes. Thx
Old 10-13-2010, 11:12 AM   #40569
MotoZot
MotoZot's Avatar
Oddometer: 2
Originally Posted by Mariner55
Hello,
I bought a 2009 with 465 miles a couple of weeks ago for $3850. Included skid plate and rack.
MotoZot is offline   Reply With Quote
Old 10-13-2010, 12:45 PM   #40570
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
But go for the 130 rear. The 120 is a bit too easy to use all the tread on the road just around town.
NordieBoy is offline   Reply With Quote
Old 10-13-2010, 12:51 PM   #40571
NJ-Brett
Brett
Oddometer: 6,450
A 1998 with extras for $1500 is a lot better, esp if you run out and dump it in a mud hole....
Hello,
NJ-Brett is offline   Reply With Quote
Old 10-13-2010, 12:53 PM   #40572
NJ-Brett
Brett
Oddometer: 6,450
The kenda k270 came in 3 inch and 3.25 inch sizes for the front, I got the 3.25 and would not mind a 3.5 in all the sand around here...
Old 10-13-2010, 04:41 PM   #40573
scary fish
scary fish's Avatar
Oddometer: 40
safari tank and spring weights
I pick my new DR650 up in the next few days and will be fitting the 30ltr safari tank. I know that I will also need to beef up the front and rear springs but not sure what spring weight to go for.
I'm around 80kg ( without riding gear), the bike will be used as daily transport as well as regular ADV trips with moderate/ light lugage set up.
I what to stick with linear rate springs and will also be fitting a set of ricor fork valves.
I 'm currently looking at the procycle 8.3 kg rear spring and eibach .50kg front but i am a little concerned that this may be too heavy so i would weclome your collective advice
cheers
Scary.....
scary fish is offline   Reply With Quote
Old 10-13-2010, 05:06 PM   #40574
NJ-Brett
Brett
Oddometer: 6,450
Got my tm40 today and installed it.
Not a great fit, the cables are a little off, the fuel line hits the choke cable pipe, the pump part hits the crankcase vent hose, but it does fit.
The only setting I changed was to drop the needle one position to 2nd from the top, and adjusted the pilot screw after the motor was hot.
The test ride was WOW!
You have to be careful with the throttle or the wheel comes right up.
There seems to be a lot of power available instantly, at almost any rpm.
I suppose I will have to fine tune the jetting (main and needle) and see what the mpg is like.
Sea level, cut airbox, stock exhaust, twinair filter, think the 150 mainjet is ok?
Brett
Old 10-13-2010, 05:42 PM   #40575
procycle
procycle's Avatar
Oddometer: 2,307
Hello,
That would be a very good out the door price for a brand new bike straight from the Suzuki dealer with full warranty, etc. Knock $800 off of that price and you would be in the ballpark of a good (not great) deal.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 10-13-2010 at 06:11 PM
procycle is offline   Reply With Quote
Times are GMT -7.   It's 03:07 AM.
