Old 10-13-2010, 05:42 PM   #40576
procycle
procycle's Avatar
Oddometer: 2,367
Originally Posted by NJ-Brett
Sea level, cut airbox, stock exhaust, twinair filter, think the 150 mainjet is ok?
145 main with stock exhaust.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-13-2010, 05:58 PM   #40577
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,967
Originally Posted by Mariner55
Hello,
2009 DR-650 with 2200 miles. $4695.
Is this a good deal? John
My local dealer is selling a new 2010 for $4500.
"I go where the voices in my head tell me to!"
2012 KTM 990 ADV- "Annika"
2007 KTM 250XCF- " Viktoria"
Grizz Adams is offline   Reply With Quote
Old 10-13-2010, 06:22 PM   #40578
NJ-Brett
Brett
Oddometer: 6,496
I guess that is what you put in since its skipped in the bag o jets.
Thats service!
Very pleased with your customer service!
Brett
NJ-Brett is offline   Reply With Quote
Old 10-13-2010, 07:03 PM   #40579
No Degree
Oddometer: 319
Got my tm40 today and installed it.
The test ride was WOW!
You have to be careful with the throttle or the wheel comes right up.
There seems to be a lot of power available instantly, at almost any rpm.
I keep reading about all this extra power with the TM40. Whack the throttle and the wheel comes up, etc, etc.
I bought mine from Procycle. Didn't touch the jetting and have yet to experience all this extra power. K&N filter, cut air box, ground weld on pipe, GSXR slip-on but where is this extra power that everyone's talking about?
No Degree is online now   Reply With Quote
Old 10-13-2010, 07:15 PM   #40580
Elvis70
No speed traps in the sky
Elvis70's Avatar
Oddometer: 5,056
You must of skimmed those posts. You have to bolt the new carb to a KTM.
I'll tape it to the handlebars, it's just logic George! If your hand is broken, you tape it to the bars! - Evil Knievel's reply to George Hamiliton's question, "How will you jump with a broken hand?".
Elvis70 is offline   Reply With Quote
Old 10-13-2010, 07:41 PM   #40581
NJ-Brett
Brett
Oddometer: 6,496
I don't know, but it was crazy what it did to my bike.
I almost lost it as I gassed it in a turn out of my driveway and the wheel came up....INSTANT throttle response, plus the big hole in the airbox which used to be very restrictive.
I got the bike stock, and thought it had good power (for what I am used to).
Pulled the snorkel and it had even more power, drilled the slide and shimmed the needle and it had much better throttle response.
Cut the airbox a bit, and it had a bad bog with full throttle and low/mid revs, a BAD bog (too lean). Put some of the airbox back in, but it was lean and top speed was down. That is how I know the airbox is so restrictive, just a slightly larger hole and it went lean big time.
Put the tm40 on, cut out the airbox full size, fit a twinair filter and almost lost it twice on the test ride.
I did not test the top speed yet, last time I did carb/speed tests locally I got 4 tickets! I do know it revs out nicely.
I can tell I am going to have to recalibrate my throttle wrist.
The wheel comes right up in 1st (stock gearing) and I think it does a bit in 2nd also.
Now the power will likely be the same with both carbs all other things being equal, that is, air box and jetting, but I doubt the throttle response would ever be as good with a CV carb, even if its modified and set real rich.
Old 10-13-2010, 07:42 PM   #40582
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
I got my tank panniers and front fender toolbag from ProCycle today. The tank bags are "ATV Logic" and are of decent quality. They fit okay, but to keep your knees from hitting them, you need to be sure they hang as far forward as possible. Since I have the IMS tank, I went ahead and stuck the velcro to the tank, since I know it won't stay for too long. :)
The fender bag is of nice quality, but is smaller than I thought. Also, I'm not confident that it will stay on the front fender. Besides, the extra weight really makes the fender wiggle, so I'm worried about it cracking it. I've relocated the bag to just behind the seat, between it and the OEM rack. It fits pretty well there and with my Givi box on the back, you barely even notice it.
I should have gotten photos, but it's dark out now so I'll get some tomorrow.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 10-13-2010, 07:55 PM   #40583
gogogordy
gogogordy's Avatar
Oddometer: 1,945
There were no 2010's in Calif.....I bought my 09 a year ago Monday, and now the dealer is waiting on the '11's. They've seen no '10's.
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 10-13-2010, 08:01 PM   #40584
procycle
procycle's Avatar
Oddometer: 2,367
Some time soon we expect to have a stainless steel front fender brace.
I want to make sure you don't run out of things to buy!
Old 10-13-2010, 08:12 PM   #40585
TrophyHunter
Oddometer: 2,240
Originally Posted by scary fish
I 'm currently looking at the procycle 8.3 kg rear spring and eibach .50kg front but i am a little concerned that this may be too heavy...
I have the IMS tank, .50's and the 8.3 but I'm 230 (104 kg). It's pretty stiff with me on it but I can ride it hard when I want without mashing it.
Call Jeff at Procycle....he was a great help with deciding which way to go.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 10-13-2010, 08:14 PM   #40586
vicster
Oddometer: 1,089
Gerbing Jacket Liner
2009, new 3/10, 2100 miles, stock.
Tried out my new Gerbing jacket liner with thermostat on my 4 a.m. commute this morning. 55 indicated in 4th gear, thermostat set to about 1/3 power. Headlight dims and brightens in 2 or 3 second intervals. Connections tight. Running through my battery tender hookup. 7.5 amp fuse per directions.
Is this normal on the DR?
vicster is offline   Reply With Quote
Old 10-13-2010, 08:16 PM   #40587
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
Suzuki didn't make any 2010 model year motorcycles, FYI...
Procycle:
SWEET!! I was thinking of making one, but if you're coming up with one, I'll wait. Awesome.
I still want to order a set of those Solstice LED lights, but I'm out of $$ now. :)
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 10-13-2010, 08:38 PM   #40588
PaulSF
Oddometer: 149
I pick my new DR650 up in the next few days and will be fitting the 30ltr safari tank. I know that I will also need to beef up the front and rear springs but not sure what spring weight to go for.
I'm around 80kg ( without riding gear), the bike will be used as daily transport as well as regular ADV trips with moderate/ light lugage set up.
I what to stick with linear rate springs and will also be fitting a set of ricor fork valves.
I 'm currently looking at the procycle 8.3 kg rear spring and eibach .50kg front but i am a little concerned that this may be too heavy so i would weclome your collective advice
cheers
Scary.....
.50 is probably too stiff in the front. For your weight, even with the Safari tank, .45 would be fine. Your back spring is too much as well - something closer to 7.4 kg would be better ...
But go to the professionals for advice - If you call Procycle, or Rick at Cogent, they'll steer you to the right springs for your weight, riding style and gear set up.
PaulSF is offline   Reply With Quote
Old 10-13-2010, 08:42 PM   #40589
Krogdor
Krogdor's Avatar
Oddometer: 11
Working on a trade...
I'm potentially trading my 2004 CBR 600 F4I for a 2000 dr650 tomorrow. However I was just talking to the guy w/ the bike and he happened to mention that there is a small leak that just showed up. I'm wondering if it's the gasket issue mentioned @ the beginning of the thread. Should I be freaked out? Should I let it hold me back? It only has 4900 miles on it?
Krogdor is offline   Reply With Quote
Old 10-13-2010, 08:47 PM   #40590
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
I wouldn't worry too much about the leak, especially if it's the base gasket. A lot of people have sealed them without replacing them. I will do that to mine if it starts leaking (knock on wood) as a stop-gap measure until I have the time to replace it.
Is this an even trade you're working on or is there cash involved? I would use the leak to my advantage if possible. :)
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Times are GMT -7.   It's 10:40 AM.
