Old 11-20-2010, 11:08 AM   #42076
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,396
Originally Posted by Rob.G
So what if the KLR makes 8 hp more. They're also carrying around an extra 80 lbs., and if they're pre-2009, another 10 lbs in extra oil (if they're smart).
Besides, on dual sports, I don't think raw power is the key anyway. It's weight and maneuverability. Yeah stock for stock, the KLR is better on the highway, but stock for stock the DR is vastly superior offroad. Big deal either way. Rob
Stock for stock HP is very close between the two. Not a 8 HP spread from dyno reports I've seen and from many I've ridden and owned.
The original KLR650 ('86 to '07) DRY weight is just a few lbs. more than the DR650. (DR: 324 lbs. - KLR approx. ? 334 lbs. ? ) The KLR carries over 6 US gallons of fuel, so that adds weight. Some riders love that huge tank.
The new KLR had some mis-prints about it's weight. They ARE heavier than the pre '08, but not 50 lbs. heavier. So, the NEW KLR wet weight is about 35 lbs. heavier than a stock, wet DR650. This is a lot for a dual sport bike, especially off road.
Somewhere this is all laid out by owners. Probably check out KLR.net to verify. You are correct about carrying extra oil. Both old and new KLR's tend to use oil. My '98 did from new. This is very well documented. The new one is even worse as a bad batch of pistons/cylinders from Thailand were the wrong spec. But even when things are right (all corrected by Kawi) ... the new KLR still uses oil. I have several KLR riding friends into these issues. Just rode with my friend Mike last weekend. He owns a new AND an old KLR. He's got 50,000 miles on his '03 KLR. Very trick bike. We rode to Copper Canyon. Never missed a beat. Here's another KLR rider ... headed for Tierra del Fuego. He made it.
KLR in Copper Canyon on the road to Batopilas.
But Mike loves my DR. Says its the fastest and smoothest single he has ever ridden. (maybe he never rode a KTM 690? )
The reason the "better on the highway" myth persists is that the KLR comes with a small windshield and a wider seat in stock form. So right away the ride is perhaps a bit quieter and the seat is better than the DR650. But the motor is another story. At 70 mph the KLR is a bit vibey and buzzy. Over that speed it is not all that comfortable. The new KLR is better all around: Smoother, with better suspension, better brakes. But the DR is still smoother ... especially at speed.
So ... for those who want to match the KLR on comfort simply fit a small shield and better seat to their DR650. Add a big tank and you're there.
The fact is, if you can get over the shear size (especially the width!) of the KLR then a well set up KLR works quite well ... even off road. With good suspension/brakes fitted the bike works damn well. Does it match the DR650? Pretty close. The DR still feels lighter and the front tracks and sticks better off road. But a really well set up KLR can do the business. On the highway the KLR has a problem. Can't get away from the buzzy motor.
Both are good bikes. The DR crashes better and if you're getting "out there" this is a bonus. The DR is less likely to leave you stranded. Also, KLR sub frame bolts routinely bend or break.
Nicely tricked out KLR .... and yes ... it works very well!
Mike and company on his Blue '08 KLR ... Yes ... Uses Oil!
HU meeting in Copper Canyon in 2004. Out of 105 bikes present ... 34 were KLR's! Go Figure! Zero DR650's. Oh how things have changed!
Old 11-20-2010, 11:13 AM   #42077
chipwich
chipwich's Avatar
Oddometer: 112
Originally Posted by foxfire
Out of curiosity, did you're Clark tank come that shiny or did you wax it or something? Mine came with a haze that took polishing compound to remove, and its still nowhere near that shiny. Just wondering...
I usually Armor All the plastic after washing. Makes it look shiny and keeps mud from sticking a bit.
1971 Honda Z50A K2 Mini Trail
2006 Suzuki DR650SM
chipwich is offline   Reply With Quote
Old 11-20-2010, 03:42 PM   #42078
atpalmer
Broken
atpalmer's Avatar
Oddometer: 244
Originally Posted by shu
This gets said a lot and has come to be accepted as true, but I'm not so sure. I've never ridden a KLR but I rode with one on a trip in Mexico and my friend said that the KLR was a pretty buzzy ride at 65 mph. For sure, he kept vibrating fairing screws and other things off his bike.
With the stock gearing my DR is a pretty smooth and stable ride, cruising at 70-75 and with good passing power up to about 85 mph.
All my humble opinion, of course......................shu
I hit 120 MPH (indicated) on my DR the night before i wrecked it. It was nice and smooth. I was running a well worn D606 rear no less. I think the DR is a fine highway bike.
atpalmer is offline   Reply With Quote
Old 11-20-2010, 03:52 PM   #42079
LukasM
Oddometer: 4,923
We discussed this before, the pre 08 KLR is more than 30 lbs heavier than the DR, the 08+ >45 lbs.
I am comparing the most relevant figure - ready to ride, no fuel.
I think you should try again with a GPS to see how fast you are really going.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 11-20-2010, 04:11 PM   #42080
YnotJP?
Oddometer: 1,626
A typing mistake, the "M" key is just below and to the left of the "K" key.
YnotJP? is offline   Reply With Quote
Old 11-20-2010, 04:18 PM   #42081
kaijb
ianb
Oddometer: 107
Originally Posted by Foot dragger
I had a bone stock 98 SC620 KTM that would dust XR650R's no problem,top end,bottom end,where ever.
There is not one test ever that rated the 98 SC620 or the 2000 KTM above the XRR. I have no doubt that you did so against lesser riders and maybe uncorked bikes but the 620 never had the top end of the XRR.
kaijb is offline   Reply With Quote
Old 11-20-2010, 04:20 PM   #42082
Ant001
done even ask
Ant001's Avatar
Oddometer: 3
My DR will hit 160kmh, which is roughly i think 100mph and thats fully open, on a very flat road
Ant001 is offline   Reply With Quote
Old 11-20-2010, 05:00 PM   #42083
inire
Browncoat symp
inire's Avatar
Oddometer: 409
Send a message via Yahoo to inire
Originally Posted by SkunkWizard
They are out there, I saw this yesterday.
http://losangeles.craigslist.org/ant...064485249.html
I made contact! You rock!
Anyone with a spare midpipe?
1982 AR80 (The Neverending Story)/ZX750A3 "99 Problems"/VTR250
inire is offline   Reply With Quote
Old 11-20-2010, 06:56 PM   #42084
atpalmer
Broken
atpalmer's Avatar
Oddometer: 244
That's exactly what i was planning to do. until THIS happened the following morning.
It's probably only about 110 MPH actual due to the generous speedo. But 120 mph sounds so much cooler.
Funny, but my bike has MPH in big numbers.
For those interested the bike has a gutted exhaust, airbox mod, unknown carb work, worn Trailwing front, D606 rear, 25 PSI, 16/42 gearing, Long Downhill at night, closed course, professional driver, and no animals were harmed.
I did 110 up the same stretch with some room to go. That DR isn't bad.
atpalmer screwed with this post 11-21-2010 at 08:27 AM
Old 11-21-2010, 05:56 AM   #42085
RockyNH
Older Than Dirt!
RockyNH's Avatar
Oddometer: 1,057
Soft bags
I have Happy Trails Racks and HT Teton alum Panniers mounted. I am thinking of getting something soft like dirtbagz, or anything that might work with my current racks.
Anyone put soft bags on there Happy Trail racks?
Thanks,
Pat in NH
RockyNH
Dualsport Corespondant for
SideStandUp.com Radio Show
02 1800 Gold Wing - "Wing"
05 Ural Gear Up "Herbie"
07 F650GS - "Grasshopper" - Totaled July 2010
05 DR 650 - (?????) Purchased August 2010
Trip Report 2009 Trans Lab Highway
Trip Report 2010 James Bay & North Road Quebec
RockyNH is offline   Reply With Quote
Old 11-21-2010, 06:38 AM   #42086
Rumlover
Ed
Oddometer: 691
A foot of snow in Murray Utah (Salt lake city area) and still accumulating. No riding today.
Rumlover is offline   Reply With Quote
Old 11-21-2010, 06:54 AM   #42087
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,592
dr650 the ton not
yet to see proof of the ton on stock dr650
plugeye is offline   Reply With Quote
Old 11-21-2010, 07:43 AM   #42088
Rumlover
Ed
Oddometer: 691
I am pretty sure a well tuned dr with moderate gearing would do 100mph. I admit I have never done it, but I am old and getting wimpy. Might depend on how strict you are with the "stock" thing. I would think a little air box work and maybe a 15/43 gearing would pull it.
Old 11-21-2010, 08:12 AM   #42089
exoff-roadgoat
Will ride for food
exoff-roadgoat's Avatar
Oddometer: 3,259
I hit 80 mph corrected on my stock DR on a gravel farm road but it felt more like 180. Yikes!
exoff-roadgoat is offline   Reply With Quote
Old 11-21-2010, 08:24 AM   #42090
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 1,972
Oh, man. That sucks. Hope you recover quickly. Just be thankful it wasn't worse.
How much damage to the bike?
That's exactly what i was planning to do. until THIS happened the following morning. .. .. ..
_______________
"You can't put the shit back in the donkey." - Tony Soprano
FYYFF
thumpididump is offline   Reply With Quote
Times are GMT -7.   It's 01:04 PM.
