01-16-2011, 12:32 PM
#44011 |
Living on a DR
Oddometer: 1,456
Loud Knocking Sound from the Starter
Hey guys,
I'm in southern Patagonia here in Chile with about 40,000 miles on the engine. I've developed a loud knocking sound from the starter gear when I turn off the engine. It's not always, but about 50% of the time. What part is starting to fail and what parts do I have to replace? ![]() It's a 2003 engine. thanks,
J A Y on a 98 Suzuki DR650SE (sanDRina) Trip Website: JamminGlobal.com Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos |
01-16-2011, 01:19 PM
#44012 |
Oddometer: 146
+1 - good bit of kit for my needs
Cheers Craig 2010 DR650 - Shiny Black one
01-16-2011, 01:27 PM
#44013 |
Butler Maps
Oddometer: 14,577
+1
awesome setup. i use the GL coyote sitting on the rear of my seat w/ only the 2 center straps on the rear rack plus the 2 lower straps on the passenger fotpeg brackets. fender straps not used. i then have a rear rack w/ a wolfman dry duffel & rox straps. camping gear in the rear, everything else in the GL. i also have one of those bungie nets on top of the GL to throw someething there quickly if need be. since it's all removable i have nothing left on the bike for daily riding.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
01-16-2011, 01:30 PM
#44014 | |
Butler Maps
Oddometer: 14,577
i think the GL fandango tank bag is better however. http://www.giantloopmoto.com/products/fandango-tank-bag the enduro is really small to be able to work w/ the fuel cap whereas the fanadango has a cutout and zipper base for this issue.
01-16-2011, 01:44 PM
#44015 | |
Butler Maps
Oddometer: 14,577
not so.
the 1520 which is the size most use. here's dales again: http://www.advrider.com/forums/showthread.php?t=146117 weigh 8.3 lbs each so 16.6 lbs or 4.4 lbs more than your quoted MS paniers weight. http://www.pelican.com/cases_detail_specs.php?Case=1520 since the dr is no waif to start 4.4 extra lbs is worth it for the most bomber cases in the biz. there is a reason why the military & police forces worldwide use pelican over ALL other options! http://www.youtube.com/watch?v=JgEefnTeOGU some don't like side loaders but once you use a inner linner bag and quickly drop into a side case you'll never go back to the bottomless pit top case design. with a inner linner you pack you gear in the comfort of your tent, house, hotel room and quickly drop it in the side bag and shut the lid. you can always access side cases cases even if you have large top bags on top. try that with a top loader. http://www.pelican1520case.com/ Quote:
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps eakins screwed with this post 01-16-2011 at 01:51 PM |
01-16-2011, 02:05 PM
#44016 | |
Oddometer: 660
Thanks. |
01-16-2011, 02:38 PM
#44017 | |
Butler Maps
Oddometer: 14,577
fatchance has ms paniers frames w/ pelican 1520 and shows pics of his frame setup. i have pelicans (caribou cases) on my wee so that's how i know about them and how well they work. cee bailey's and i developed the bag linners for the 1550.
01-16-2011, 02:49 PM
#44018 |
dirt junkie
Oddometer: 33
Does anyone have a picture of a 2002ish DR650 frame? Preferable a picture of a bike without a seat and tank. Picture taken from behind the bike would be the best.
I just picked up a 2002 DR650 that was in an accident and isn't straight anymore. I'm just trying to figure out where the frame is tweaked. Thanks, KC |
01-16-2011, 05:04 PM
#44019 | |
Oddometer: 660
Thanks. Never really considered the GL................maybe I will. |
01-16-2011, 05:20 PM
#44020 | |
HappyMan
Oddometer: 498
Kudos to Wolfman
I should add that I have their stuff on at least three of my bikes.....(no I'm not affiliated)
John MN 06 Triumph Tiger Suzuki DR650SE Yamaha XT350 Suzuki DR 200 Yamaha TTR Yamaha RT Suzuki JR 80 and JR50 “Success is not final, failure is not fatal: it is the courage to continue that counts.” - Winston Churchill http://ridedualsport.com |
01-16-2011, 06:02 PM
#44021 | |
Life behind "Bars"
Oddometer: 6,345
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
01-16-2011, 06:17 PM
#44022 |
lifelong reject fixer
Oddometer: 1,223
DR luggage?
I have the Wolfman Enduro tank bag, a set of the ATV panniers, and the Wolfman Summit saddle bags. The Wolfman product is tough as nails, and will hold a buttload of stuff. I was not really as overloaded as it looks in the picture... at least it didn't feel that way. ![]()
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member ------------ "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius |
01-16-2011, 06:18 PM
#44023 |
Oddometer: 277
Oops
So I finally got around to replacing the IMS supplied fuel valve with the Raptor valve that I got about a month ago. I got a little Dremel happy when opening up the hole. I don't know why I had it in my head that I needed to open the hole up sideways as well, but anyway made the hole just a little too big. So I tried fixing it with some JB-Weld Stik, but it's seeping a little after a few hours. So I've drawn up a plate that I'll cut out tomorrow to fix it. I think my best bet is to cut it out of metal and use some Permatex #2 between the plate and the tank. Moral of the story, draw out what you plan on cutting....(and Dremel side cutters go through plastic REALLY fast.)
01-16-2011, 06:38 PM
#44024 | |
Oddometer: 488
Inspecting/adjusting the valves right away is a smart thing to do.
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way. |
01-16-2011, 07:01 PM
#44025 | |
Armature speller
Oddometer: 6,844
Not a worry. Seems to happen less if you use the kill switch to turn it off. |
