Old 02-16-2011, 01:37 PM   #44971
Redbean
Inanely Adventurous
Redbean's Avatar
Oddometer: 5,327
Installing Dynojet kit.
Looking for fuel mixture plug so I can drill it and remove it, so fuel mixture can be ajusted. Where is it? Can't tell up from down in illistration that came with kit.
Redbean is offline   Reply With Quote
Old 02-16-2011, 01:47 PM   #44972
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 5,054
Underneath.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 02-16-2011, 01:55 PM   #44973
BergDonk
BergDonk's Avatar
Oddometer: 1,652
Originally Posted by ShadyRascal View Post
Underneath.
at the front, ie the engine side.
shed time IS quality time
Check my DR650 story:
BergDonks DR650 Build
BergDonk is online now   Reply With Quote
Old 02-16-2011, 01:55 PM   #44974
Redbean
Inanely Adventurous
Redbean's Avatar
Oddometer: 5,327
Underneath.
Thanks,
On the bottom of the float bowl? Don't see a plug under there but do see a threaded rather deep screw hole. Would need a very small screw driver to get to the screw?
Old 02-16-2011, 01:57 PM   #44975
ShadyRascal
Master of None
Oddometer: 5,054
Thanks,
Front of that on carb body, see post simultaneous with yours.
Old 02-16-2011, 02:00 PM   #44976
Redbean
Inanely Adventurous
Redbean's Avatar
Oddometer: 5,327
See a alluminum protudence on the carb body on the engine side, there is a rusty machine screw coming out of it, the head of the screw is broken off. Bought the bike with 350 miles on it from a dealer.
This rusty screw is between two threaded hole on the carb body it is not in the middle of the two unused threaded holes.
Redbean screwed with this post 02-16-2011 at 02:06 PM
Old 02-16-2011, 02:03 PM   #44977
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,070
Wow! Page 3000! Just thought someone should mention it
Edit: Doh! too late lol
FloridaSteve is offline   Reply With Quote
Old 02-16-2011, 02:05 PM   #44978
ShadyRascal
Master of None
Oddometer: 5,054
#9 in this picture.
Here it is with the adjustable screw installed.
Old 02-16-2011, 02:12 PM   #44979
Redbean
Inanely Adventurous
Redbean's Avatar
Oddometer: 5,327
#9 in this picture.
Yep, that's it, but mine has a rusty screw coming out of it with the head broken off.
Have finished installation but for this last step.
Old 02-16-2011, 02:26 PM   #44980
Redbean
Inanely Adventurous
Redbean's Avatar
Oddometer: 5,327
Thanks guys, got it pulled on rusty screw, is had what was left of the plug on it. Going to botton it up and check it out.
Old 02-16-2011, 02:55 PM   #44981
HMT
Oddometer: 50
Originally Posted by RamMan4x4 View Post
B/W is negative per the wiring diagram. So you need to solder the red on the LED to the brown on the harness and the black on the LED to the B/W on the harness. I did this recently...but couldn't remember hence the need for the wiring diagram.
Link to online diagram (also in the DR650 service manual)
http://tiltpen.net/DR650/640x480/Wiring7.jpg
Been a long time since I've studied any wiring diagrams.
Red to brown it is!
I'll finish this and the DRZ tail light as well. Will make her much more svelte ...
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together.
HMT is offline   Reply With Quote
Old 02-16-2011, 03:36 PM   #44982
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 1,306
Originally Posted by procycle View Post
The secret to getting any of the post mounted windscreens just right is not to be afraid to bend the mounting posts. They are a very pure aluminum alloy and will easily bend enough to make fitting the screen much easier. I bent mine to a 90 degree angle which allowed my to get the screen behind the headlight cowl.
I saw pics of your guys black DR and was wondering how you got it behind the headlight cowl! The secret is out! I tried every combination of mounting and couldn't get it behind without a steep downward angle. That thing is deffinately an errector set! Ofcourse, bending a new windscreen never came to mind...
Mongle is offline   Reply With Quote
Old 02-16-2011, 03:42 PM   #44983
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 1,306
Originally Posted by newride View Post
Bump. Anyone?
Sorry have limited resources and Hawaii is quite a pain in the ass to travel all over the island to find the correct socket size.
If you don't have a 27mm an 1 1/16 is very close (.0005" diffrence). Most metric sockets OVER 26mm are within a thousandth of the SAE sockets. Use a good six point socket and you shouldn't have any trouble.
Old 02-16-2011, 03:45 PM   #44984
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 1,974
If you set your preferences to display 100 posts per page, then it's only 451 pages!
_______________
"You can't put the shit back in the donkey." - Tony Soprano
FYYFF
thumpididump is offline   Reply With Quote
Old 02-16-2011, 04:07 PM   #44985
newride
newride's Avatar
Oddometer: 668
Nsu.......fu
well, I suck. days of running around trying to get the right tool, finally get the clutch off, locktite some good screws, tightening the nsu on and......snap.
Putting in the upper screw and almost half of the plastic on the nsu holding the top screw breaks and falls off.
so.........definately have to cut that f'ing thing out of there now. I know you just don't cut it out. do I follow the wire somewhere and disconnect it?
So frustrated, going swimming. lol
1975 BMW R90/6
2006 DR 650
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
