Old 02-18-2011, 01:30 PM   #45016
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,737
Originally Posted by The_Commander View Post
Just got a call from the shop regarding my '08 that was having some trouble. I feared the worst but in the end it just needed a new fuel line. $10 later and I'm on the road.
They're bulletproof.
Nice when it's something little and inexpensive.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-18-2011, 02:23 PM   #45017
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by foxfire View Post
I got the impression he was asking about electrical power...
Oh ... crap! You could be right! Whoops!
To cover the elec. output issue I'd look at the DR thead index and find instructions for re-wiring the stator. This gives you about 50 more watts but at a slightly higher RPM. Idle output actually drops ....
I installed a headlight switch, others use a 35 watt HID headlight and LED bulbs throughout. This saves more power.
I run a Gerbing and grips no problems. Night riding is more of a challenge if you run Aux lights or other accessories.
Old 02-18-2011, 02:31 PM   #45018
Adv Grifter
Oddometer: 6,128
Originally Posted by MarkGS View Post
That's it? Awesome. One less question for when I'm rollin' down there.
Mark, keep in mind, that is the "quick fix" solution. It will help some but there are a couple other things I would do:
1. Make sure you install an extended fuel screw adjuster. At high altitude, lean it out a bit (turn IN ... clockwise) This will help idling and starting, save fuel and bike will run better overall. Re-adjust when back down at lower altitude ... Always run this as lean as possible while retaining a reasonably smooth idle.
2. If you plan to stay up high for extended periods, I would change the pilot jet and possibly the main jet. (both need to be Leaner ... smaller number) Just be sure to return to normal jetting once down to lower altitudes.
Old 02-18-2011, 02:42 PM   #45019
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by newride View Post
any help would be much appreciated. I am on a time crunch. Moving. Have to get my bike done and out of my place in less than 10 days. Can this NSU be workable or should I just cut the wires and remove????
Panicing,
Snip the wires a couple of cm inside the cases, fold it back on itself a couple of times and zip tie it.
You can always solder on a new one later if you want.
NordieBoy is offline   Reply With Quote
Old 02-18-2011, 03:24 PM   #45020
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Thank you and yes electrics is what I was asking for and after looking at my post I can see I wasn't very articulate about it...must have been the 4 hr sleep the night before.
Engine power I know plenty about. That thing was pushing 52 @ the wheel without an air box @ one point...Yes it's possible but not worth the expense and you end up with a purpose built motard and takes the rest out of the equation (dual sport, drivebility and everyday livable use).
Dalmatino screwed with this post 02-18-2011 at 03:34 PM
Dalmatino is offline   Reply With Quote
Old 02-18-2011, 03:25 PM   #45021
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Originally Posted by Rusty Rocket View Post
That is the best looking DR I've ever seen. Love the black pipe!
Thyank you Rusty...It was one off the fastest too.
Old 02-18-2011, 03:33 PM   #45022
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Originally Posted by alonzo View Post
I like that black exhaust system. What did you paint it with?
-- alonzo
That is custom built exhaust from one end to the other By one of the originals, Mr Garry Wullf himself, for those who remember Wullf headers of the 70's and 80'.... It was ceramic coated, flat black. It wasnt fancy but man did it work
Old 02-18-2011, 03:35 PM   #45023
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Heres couple more pics...
Old 02-18-2011, 03:36 PM   #45024
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Another
Old 02-18-2011, 03:38 PM   #45025
Adv Grifter
Oddometer: 6,128
DR650 Parts for sale in Flea Market ...
More to come ...
Cleaning out the garage .... fire sale prices. Enjoy!
http://www.advrider.com/forums/showthread.php?t=661353
Old 02-18-2011, 03:41 PM   #45026
Dalmatino
Dalmatino's Avatar
Oddometer: 336
Had a penskey shock set up by LE out of California along with the fully reworked front end...The handling was amazing on and off road. Unfortunately I didnt have much off-road experiance to utalize evan 50% of it. In the paved twisties...well that was another thing
Old 02-18-2011, 03:52 PM   #45027
Squiggles
Oddometer: 23
Jetting Question
How white should the plugs be?
Having a second go at jetting my DR, it only has the snorkel out and a twin air filter.
When i did it 20,000km ago i raised the needle by 1mm (0.04") and ended up with the mixture screw 2.25turns out. Was never entirely happy with it, seemed to surge a tad.
In those 20,000k's the plastic spacer had a groove worn into it (~0.5mm (0.02")). Have flipped the spacer over and shaved a bit of material off the washers so it should now be raised by 0.76mm (0.03") which I believe is the ideal?
Mixture screw is about 2 turns out (I did it for a smooth idle and then a quarter turn further)
Plugs are a bit grey/white, they're up for replacement in another 2k, what do you guys think of the colouring? All good?
Squiggles is offline   Reply With Quote
Old 02-18-2011, 03:58 PM   #45028
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,993
Originally Posted by Xplorr View Post
I'm looking to get a clip-type master link for my 08 650. The manual says OEM is a DID 525 v9. My chain, which I assumed was OEM is stamped v8. I understand you can't switch master links across brands, and I'm having trouble finding one specified for the 525 v8. Any insights or part numbers?
Thanks, matt
call Jesse @ Kientech. That's where I got mine.
"I go where the voices in my head tell me to!"
2012 KTM 990 ADV- "Annika"
2007 KTM 250XCF- " Viktoria"
Grizz Adams is offline   Reply With Quote
Old 02-18-2011, 03:58 PM   #45029
BergDonk
BergDonk's Avatar
Oddometer: 3,926
Originally Posted by thumpididump View Post
Which mid-pipe are you using, BergDonk?
The one that came with the Megacycle muffler.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 02-18-2011, 04:38 PM   #45030
MotoScooter
MotoScooter's Avatar
Oddometer: 21
JoefromSF -- I really like my DirtBagz. They hold up well. They are not water proof though, so I put gear in trash bags if rain is expected.
'06 DR650
MotoScooter is offline   Reply With Quote
Times are GMT -7.   It's 10:19 PM.
