Old 02-19-2011, 08:58 AM   #45046
Willy G
Willy G's Avatar
Oddometer: 154
Nice DR650
Not mine but a nice bike.
http://cgi.ebay.com/ebaymotors/2009-...e#ht_500wt_973
Willy G is offline   Reply With Quote
Old 02-19-2011, 09:51 AM   #45047
newride
newride's Avatar
Oddometer: 704
Originally Posted by NordieBoy View Post
Snip the wires a couple of cm inside the cases, fold it back on itself a couple of times and zip tie it.
You can always solder on a new one later if you want.
cool, if it is that easy, I will do it today. When I have a chance down the road, I will get a new oil pump gear, new gasket and new NSU.
Just wanted to make sure if I just cut it, it wont short out any thing that way.
Thanks man!
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 02-19-2011, 10:14 AM   #45048
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,254
Originally Posted by Willy G View Post
I guess the guy doesn't understand that adding $2000 worth of farkles doesn't actually make your bike worth $2000 more when you resell it.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 02-19-2011, 11:15 AM   #45049
RamMan4x4
RamMan4x4's Avatar
Oddometer: 179
Originally Posted by Trbig67 View Post
Turn signal problem.... I rode to work one day and they both worked fine. All highway, so no rough stuff to wiggle things loose. Next day, the right side doesn't work, but left side is still fine. Does this indicate the switch on the left control needs to be taken apart and maybe cleaned up, or is there something else I should look at? I'm pretty mechanical, but electrical stuff isn't my forte'.
+1 for the bulb unless both front and rear on the right side are out. Even in that case, I would check bulbs first.
08 Suzuki DR 650SE
99 Suzuki DR 350SE
07 Buell XB12X
RamMan4x4 is online now   Reply With Quote
Old 02-19-2011, 01:27 PM   #45050
Paloma Paul
Paloma At Its Best
Paloma Paul's Avatar
Oddometer: 385
bulbs
Sounds like bulbs to me...........my left rear is often not working so I have an extra wrapped in a piece of sock..I can't say it goes out. I replace it almost every year or two. never had any problems with the other ones/
Paloma Paul is offline   Reply With Quote
Old 02-19-2011, 01:31 PM   #45051
Paloma Paul
Paloma At Its Best
Oddometer: 385
Handlebars
After a long ride (100+ miles) my back muscles around my shoulders always are sore and burning....I read on here some time ago about a certain handle bar that eliminates this problem (ATV bar) somebody help me out and post what it is.........seems like it was some bar for an ATV is all I remember.
Old 02-19-2011, 01:48 PM   #45052
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I doubt it's the switch or a bulb. More than likely a loose connection at one of the signals. Happens all the time to me as mine have been re-wired with different signals several times and no longer use the stock Suzuki plugs. Go through and find turn signal wires ... very easy. Then start wiggling.
Fast flash means one or both are out.
Old 02-19-2011, 02:23 PM   #45053
Trbig67
Oddometer: 108
Seriously... That is the first answer that actually has any thought put into it. Both bulbs on one side magically burned out at once guys? Really? Checking the air in the tires actually does make about the same amount of sense.
Trbig67 is offline   Reply With Quote
Old 02-19-2011, 02:59 PM   #45054
ram1000
ram1000's Avatar
Oddometer: 1,833
He stipulated that it was not loose wires...
but I missed that it was both bulbs out on one side...
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 02-19-2011, 03:24 PM   #45055
newride
newride's Avatar
Oddometer: 704
NSU saga continues
wow, not sure what my karma is with my bike lately, but...
So I snipped the wires and pulled the NSU out. Putting clutch pressure plate bolts back on in reverse order all labelled. Putting bolt # 2 back in and it is not tightening down all the way............snap!!!! noo!!!! bolt breaks off inside where it goes. By some miracle, I got it out with some small allen wrenches. So I am buying all new good bolts. I am not sure why this happened. I was not cranking on the bolt and I was working in reverse order...4, 3, 2, 1,. Are you supposed to take one bolt, put it in all the way tight, then go to the next,etc..or is there some secret technique I am missing? Don't want to do this again. The bolt hole itself is a little bit sticky in some places when finger tightening it. Maybe the threads are slightly messed up.....
1975 BMW R90/6
Old 02-19-2011, 03:28 PM   #45056
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,397
The first thing I'd do is adjust the stock bars and see if you can find the sweet spot that makes the pain go away, if your bars are too far forward it will feel like your elbows are sticking out, too far back and you elbows will be feeling like they are too close to you body and you wrists will not be straight to the grips. I'd bet your bars are rolled too far down or close to you. That being said, I'm 6'3" so like a taller bar for riding when standing so I go with the Pro Taper 7/8 ATV high bend bars. Thy still need to be adjusted for personal fit as decribed before.
Mike M.
Creswell, Oregon
'14 KLR 650
Ride what makes you giggle in your helmet
oremike is offline   Reply With Quote
Old 02-19-2011, 04:01 PM   #45057
BergDonk
BergDonk's Avatar
Oddometer: 3,467
Bummer...
With a clutch pressure plate you should progressively tighten the bolts up a couple of turns each at a time else the plate is distorted and all the spring pressure is on one bolt.
I also recommend a suitable torque wrench like:
http://www.justtools.com.au/prod1776.htm
Accurate for the torque required.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 02-19-2011, 04:12 PM   #45058
Paloma Paul
Paloma At Its Best
Oddometer: 385
Thumb bars
This is what I was looking for........I knew it was something for ATV
Old 02-19-2011, 04:31 PM   #45059
Paloma Paul
Paloma At Its Best
Oddometer: 385
Thumb Atv
Thats what I was looking for ATV high bend
Old 02-19-2011, 04:51 PM   #45060
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,997
Puke
Hard to tell who does what ... but reading this thread you can get a pretty good idea .... Anyone remember that "hot shot" from L.A. , handle was "Goodcat8" ? He crashed his DR ... and no one even wanted to buy the leftover carcass.
It's amazing what a complete and total douchbag you are. Seriously. It's gotten to a point where I just shake my head and sigh everytime you post anything.... in any thread.
For the record, so you can actually know what your talking shit about for once, I sold my DR w/in a week of listing it in the fleamarket to a fellow "inmate". Who has enjoyed the bike very much since he picked it up.
So for the love of god, just for a day or two, maybe, just maybe... STFU.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Times are GMT -7.   It's 06:58 PM.
