02-18-2011, 08:39 PM
#45076 | |
Brett
Oddometer: 4,716
The picture makes them look on the dark side....
02-18-2011, 08:50 PM
#45077 |
Oddometer: 1,607
The plugs will only show what was happening in the last several seconds the engine was running before they were removed. If the last thing you did was idle up your driveway the spark plugs are a snapshot of that operation. You can't really determine anything about jetting by looking at the spark plugs unless you put in brand new plugs in an already warmed up motor and then take it out immediately and to a "plug chop" (google it). Then, if you are experienced at reading spark plugs you might make some determination about the size of the main jet.
A better indication of jetting setup is whether is runs great and gets good fuel economy.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
02-18-2011, 08:58 PM
#45078 |
Sleep, Wrench, Ride
Oddometer: 4,445
I was ordering parts for the DR350 and somehow ended up with DR650 parts. Probably my fault.
Anyway, I have a brand new, OEM, in sealed bag, clutch and throttle cable for a 90-91 DR650S. Anyone need these? The clutch cable (58200-14A00) cost me 13.75. I'd like $10 for it. The throttle (58300-12D00) cost me $18.22. I'd like to get $15. If you buy both I'll pay shipping in the US. PM me if you're interested.
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
02-18-2011, 10:36 PM
#45079 | |
on the road o'dreams
Oddometer: 5,386
Yea, hard to know miles on a DR anyway. Pretty easy to unplug that Speedo! Modern bikes with computer speedos make that harder ... a good thing for buyers, IMHO. But so true about the kind of miles a bike has done. Constant riding in City traffic in hot weather would be "bad" miles, as would very rugged single track at slow speeds or desert riding through lots of deep sand. Deep sand and mud are very hard on engines. Highway cruising is a breeze for the DR ... and I'd guess very little wear takes place. Some riders are abusive and bang a bike off the rev limiter on every shift. Hard to tell who does what ... but reading this thread you can get a pretty good idea .... Anyone remember that "hot shot" from L.A. , handle was "Goodcat8" ? He crashed his DR ... and no one even wanted to buy the leftover carcass. Service records are good. I keep 'em on ALL my bikes. Every service gets noted, and all receipts saved. Nice to know the history when you buy a used bike.
02-19-2011, 04:09 AM
#45080 | |
lifelong reject fixer
Oddometer: 1,218
Well, I got there to find the bike had been dropped and had a dent in the tank the size of a small potato (photos didn't show that), the can had been drilled (poorly), the fins on the oil cooler were flattened from having been sprayed too hard with a high pressure washer, and the engine (at 3.5K miles) sounded like it had bb's rattling around in it. On top of all that, he indeed had the title (no lien) but the bike was still in the original owner's name. So the original owner was not available to sign a bill of sale and "no, he has changed jobs and I don't have his new cell number." I didn't dog cuss the guy but I did let him know that the bike was not accurately represented. And I left with my money still in my pocket. End of rant... Back to your question: I recall that NADA or some other accepted vehicle watchdog group considers 5,000 miles a year to be average for a motorcycle. Granted, sterling maintenance would take away some of the risk, but it remains that the mileage is nearly double the allocation. Assuming the oil was changed and the air-filter kept clean, there is still to be considered the matters of chain wear, brake wear, and the wear on other moving parts. "How soon will I have to replace __________? (fill in the blank). Even so, if the owner has good records, can answer your questions, and you can tell he is legit then it might work into a good deal in spite of the high mileage. Beyond that, was the bike stored in a garage or shed or left out in the elements? What his riding off road or on-road? Off road would call into play a higher degree of wear on the bike in general. And if on road, what type of commute was it? As someone noted, stop and go big city traffic is much harder on the bike than straight up highway miles. With all that said, there is a thread here someplace on the site about high mileage DR's. I read that last year and there are plenty of DR's out there with 50K on them. High mileage alone is not a deal breaker, but low mileage is no guarantee the bike has been adequately cared for. As someone noted on the Gold Wing board years ago, "As much as anything we buy the owner when we buy the bike." All other things being equal in terms of a credible owner and solid maintenance, I do think you could leverage the mileage for a great price. Your call, dat. Just MHO
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member ------------ "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius basketcase screwed with this post 02-19-2011 at 04:24 AM Reason: The usual spillin' & grammer issues... |
02-19-2011, 04:35 AM
#45081 |
His mudda was a mudda!
Oddometer: 488
Flea Market Posting...
______________ '08 DR650 '07 DL1000 |
02-19-2011, 06:13 AM
#45082 | |
Tiger Rider
Oddometer: 222
http://cgi.ebay.com/ebaymotors/NEW-2...item43a53c6f5d
'08 Triumph Tiger '09 VSTROM 650 |
02-19-2011, 07:01 AM
#45083 |
Oddometer: 108
Turn signal problem.... I rode to work one day and they both worked fine. All highway, so no rough stuff to wiggle things loose. Next day, the right side doesn't work, but left side is still fine. Does this indicate the switch on the left control needs to be taken apart and maybe cleaned up, or is there something else I should look at? I'm pretty mechanical, but electrical stuff isn't my forte'.
02-19-2011, 07:42 AM
#45084 | |
Oddometer: 1,710
Chrome and noise are no reason to ride a motorcycle! :2002 KTM 640 DS :2003 Suzuki GSXR1000 :2005.5 KTM 950 :2007 VStrom 1000 :2008 DR650 :2009 Aprilia DorsoDuro :2009 KLR 650 :more to come |
02-19-2011, 07:58 AM
#45085 |
Oddometer: 153
Nice DR650
Not mine but a nice bike.
http://cgi.ebay.com/ebaymotors/2009-...e#ht_500wt_973 |
02-19-2011, 08:51 AM
#45086 | |
Oddometer: 668
Just wanted to make sure if I just cut it, it wont short out any thing that way. Thanks man! |
02-19-2011, 09:14 AM
#45087 | |
867-5309
Oddometer: 2,528
DO WHAT YOU LIKE - LIKE WHAT YOU DO Explain to me again why enjoying life when I retire is more important than enjoying life now? |
02-19-2011, 10:15 AM
#45088 | |
Oddometer: 84
08 Suzuki DR 650 - 15k, FCR-MX, GSXR-40F0, Header mod, TKC80, SC Seat, PWD Skid Plate, TCI Rack, TCI HL Guard, Wolfman Wolf Tail, DR250 TL, Ulysses Windscreen and Turn Signals, IMS tank, Raptor Petcock, GL Coyote and Fandango Bags, MR Tie Downs |
02-19-2011, 12:27 PM
#45089 |
Paloma At Its Best
Oddometer: 385
bulbs
for the bulb unless both front and rear on the right side are out. Even in that case, I would check bulbs first.
Sounds like bulbs to me...........my left rear is often not working so I have an extra wrapped in a piece of sock..I can't say it goes out. I replace it almost every year or two. never had any problems with the other ones/
02-19-2011, 12:31 PM
#45090 |
Paloma At Its Best
Oddometer: 385
Handlebars
After a long ride (100+ miles) my back muscles around my shoulders always are sore and burning....I read on here some time ago about a certain handle bar that eliminates this problem (ATV bar) somebody help me out and post what it is.........seems like it was some bar for an ATV is all I remember.
