Old 06-02-2011, 07:41 PM   #49711
enduro scissorhands
enduro scissorhands's Avatar
Oddometer: 6
Originally Posted by smilin jack View Post
If you look on bikebandit.com and other motorcycle parts places, they have parts listed with prices... to order parts.
Looks like you can use your big crescent hammer (adjustable wrench) to pry the skid plate back to normal position and use some brake cleaner to get the oil off the engine case. Then put the JB Weld on to seal up the leak. It could be considered a permanent fix. It all depends if the bike is for show or riding.
Did the snake get away unharmed?
Dave
yea the snake took a look at me and slithered away from me slowly.. i already put some jb weld on there and shes looking better. ill try to pry that bent piece back. thanks for the tips.
enduro scissorhands is offline   Reply With Quote
Old 06-02-2011, 07:49 PM   #49712
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,713
Originally Posted by John E View Post
would it be to carry a larger front sprocket and then change it over when on a ride that involved both freeway as well as dirt road riding?
I know folks who ride a lot on one or the other setup their sprocket/chain rings to suit the roads but what about doing both?
Still working on my busnride on the DR, work, life and a death in the family have interfered with my plans.
Hoping to get it home in mid June...hoping...
Very easy if your chain length is set to suit larger sprocket. I just ground down the original retainer and the swap from 15 to 14 and visa versa takes about 10 minutes by the time you loosen the rear axle to slide the wheel forward to get the chain off the front sprocket. I did this recently on a long trip. had 15T on but felt it was lugging a bit much, so I swapped over to 14T and found it too 'buzzy', so pulled up and swapped it back on the side of the road.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 06-02-2011, 07:53 PM   #49713
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by M Singer View Post
I don't agree with that either. I have been installing my own tires for years and never once have I even come close to max psig when seating a bead. In fact it rarely takes more then 10 psig to seat the bead on a dual sport tires at least the ones that i have used anyway.
Even the tubeless tires that on my FZ1 rarely take much more the 15 psig to seat the bead and I do run max psig in the rear. Both Yamaha and the tire manufacturer recommend max pressure (42 psig) for my weight on the rear tire. I know that tire pressure is a bit of a gray area and people's opinions vary on it.
Do you have a DR650?
I've gone to 60psi a few times to try and seat the rear bead.
NordieBoy is offline   Reply With Quote
Old 06-02-2011, 08:07 PM   #49714
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Same here. Very common with big dual sport tires. (like a 130/17) Oddly, street tubeless tires seat more easily.
Dirt and dual sport tires need more pressure and dish soap. I've gone over 60 PSI ... even blew up a tube once. DOH!! Tubeless tires (with tube of course) seem toughest to seat 100%.
On the trail I've ridden miles and miles with only a partially seated bead after a flat repair. No worries .... but you do feel it on pavement. On dirt you generally won't feel much. Hard to seat the bead with a bicycle pump or CO-2 cartridges.
Old 06-02-2011, 08:23 PM   #49715
Adv Grifter
Oddometer: 6,128
Ditto!
Many DR650 riders here swap front sprockets routinely while en route. No big deal at all ... and if you're technique is right, the 14 to 15 swap ... or vice versa, you need not loosen axle nut. It can all be done in place ... unless the chain is adjusted too tight.
I also ground down my retainer plate ... and carry some Blue Loc-tite for the 3 bolts ... and don't over tighten them.
BTW, resist the temptation to put on a 16 tooth sprocket because you think it will help on long highway stretches. It really does not help. The stock gearing on the DR is ideal for cruising at 75 to 80 mph indicated. This equates to about 70 to 75 mph actual. The higher gearing of the 16T means you'll be twisting more, thus using more fuel. I hated it in any sort of mountainous areas. You could try this ... see what you think. But the DR likes to be revving just a bit higher for max efficiency/smoothness. Even the 14T on highway is not bad.
The 14 T sprocket makes only a slight difference off road but it does help some and makes slow going in 1st gear slightly easier in slow, technical going.
Old 06-02-2011, 09:41 PM   #49716
kezzajohnson
kezza
Oddometer: 1,713
Originally Posted by jet123 View Post
Folks,
Trying to get at my NSU screws...
I cannot get the clutch release arm off the clutch release pinion. The bolt tightening the clutch release arm is loose. The clutch release arm slides 'up' the clutch release pinion a bit - enough so that the clutch release arm is flush with the top of the clutch release pinion, but no further. I did try gently spreading the clutch release arm with a flat screwdriver, but the (small) amount of force I used made only made a small difference (this spreading got the arm to be flush with the pinion).
Thoughts on how to remove the clutch release arm? I was going to use a small amount of penetrating oil (Liquid Wrench).
Clutch cover...
It seems to be slightly loose all the way around when I grab those molded-in tabs. But it almost feels as if something inside is hanging up on the clutch cover. It does not appear to be the not-yet-removed clutch release arm / clutch release pinion issue I discussed above.
I tried gently tapping it with a rubber mallet, but no difference.
Thanks in advance!
You need to remove the bolt completely as it holds the arm in a groove on the shaft. It still may be tight but get a screwdriver in the split and prize it open a bit. It'll slip off quicker than grannies undies.
kezzajohnson screwed with this post 06-02-2011 at 10:49 PM
Old 06-02-2011, 10:39 PM   #49717
jenx
misadventurer
jenx's Avatar
Oddometer: 553
It'll slip off quicker that grannies undies.
Plans to get my own piece of paradise (comments and advice welcome):
http://mountain2c.wordpress.com/
jenx is offline   Reply With Quote
Old 06-02-2011, 10:47 PM   #49718
jenx
misadventurer
jenx's Avatar
Oddometer: 553
Jet ...
Kezza is spot on. Not sure about grannie's undies tho
Remove that little screw and slip the arm off the splines. Also use the mallet on the cover and wiggle that baby loose. You may even be able to re-use the gasket. Mine was cemented onto the cover face. So I bought another and oiled it so it'll come off nice 'n easy next time.
Finally ... make note of the different screw lengths on the cover!!
Old 06-03-2011, 12:07 AM   #49719
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 452
Originally Posted by Adv Grifter View Post
It is a clunky box for sure. Your neutral noise is mostly likely just a noisy gear. Will it fail? I seriously doubt it. Try a different oil. I like synthetic.
Shift slow, especially from 1st to 2nd.
For the first time, I gotta disagree with ya. I say, shift fast and positive, i.e., with a firm - but not overly hard - toe under the shift lever, from first to second gear. I believe lazy shifts into second are the cause of much premature wear on the engagement dogs of second gear, especially when the rider lets the rpms drop too far. The DR transmission does not like the engine revs to drop to idle between upshifts.
I manage the rpms between shifts both up and down, and at least on my '09 with 10k miles on the odo, I find the transmission to very acceptable and not at all "clunky" unless I mismanage the engine rpm. I feel for the guys here complaining of their transmissions, but also wonder if they know how to properly manage the shifting.
I have experience with owning over 20 bikes from all the Japanese builders plus Harley and Triumph, including road bikes and dirt bikes. The DR shifts as well as my KLR, Valkyrie and ZX-10. Well, maybe just a little less than the ZX.
Match the engine rpms to the gear you are shifting into and life will be much better.
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 06-03-2011, 12:30 AM   #49720
ladeda
Oddometer: 38
Sprockets
Ditto!
I have a dr650, and have loved long highway riding on it, its just perfect, but I agree with others on this thread. When on the dirt, and wanting to go slow, say down hill, tight turn, I didnt feel comfortable. I have bought a size 14 sprocket, as intend to do more dirt riding. Do you think I could have it on the bike all the time? I ride it around town, to work etc, and dont have the patience or mechanical knowledge to be changing it all the time. Also, Could I for instance ride it form Bris to Cairns with the size 14?
ta, Jane.
ladeda is offline   Reply With Quote
Old 06-03-2011, 03:22 AM   #49721
nii
Johnnie Walker
nii's Avatar
Oddometer: 62
Excuse my stupidity, I have a question.
Did an oil+filter change yesterday, drained all I could.
Filled 2000ml fresh oil, ran the engine for a while, shut off and the level on the inspection glass reached F (full)
When the engine is on, the level is below L
Q: Do i look at the level with the engine on, or off???
If I fill 2400ml as per the manual the level will be OK with the engine running, and way too high when not running.
'08 Suzuki DR650SE
nii is offline   Reply With Quote
Old 06-03-2011, 03:29 AM   #49722
dirtymartini
Shaken, Not Stirred
dirtymartini's Avatar
Oddometer: 2,627
Originally Posted by nordieboy View Post
do you have a dr650?
+1
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
dirtymartini is offline   Reply With Quote
Old 06-03-2011, 03:31 AM   #49723
12ARX
12ARX's Avatar
Oddometer: 1,498
Warm Engine and off for 1 min (engine off when checking).. I only ever fit about 2100ml after a oil/filter change without being over full mark using suzuki's method. Remember the slightest angle of the bike changes the level considerably.
Current Ride:
09 DR650SE
12ARX screwed with this post 06-03-2011 at 04:25 AM
12ARX is offline   Reply With Quote
Old 06-03-2011, 03:31 AM   #49724
dobbo
dobbo's Avatar
Oddometer: 1,008
Check it without the engine running.
With the bike on it's side stand the oil level will be at the very bottom of the view glass (or may not even be visible). For a true measurement check it with the bike vertical, this will allow you to see it in the window.
Do not overfill it, I have found the 2400mls (incl Oil filter) to be too much, and it backfeeds through the motor/overflow/airbox.
Roughly put in 2 litres then ensure the bike is vertical, and add until it reaches the right level in the inspection window.
dobbo is offline   Reply With Quote
Old 06-03-2011, 03:53 AM   #49725
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
You must follow the manual or you will get a false reading.
The bike must be vertical when you check the level.
This is the 1996 and on manual.
http://www.mediafire.com/?ej1uxyilyjd
This is the oil level cold,bike vertical and been sitting overnight.
Note how high it looks,its not.
Engine started and run for 5 or so minutes then shut down,bike is vertical.
It now looks low.
About one minute later as per the manual,bike still vertical,oil has started to return from the top end to the sump.
This is the actual oil level.
I would have added a little oil to the 3/4 mark.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Times are GMT -7.   It's 08:47 AM.
