Old 08-28-2011, 03:24 PM   #53686
barko1
barko1
barko1's Avatar
Oddometer: 3,351
[QUOTE=PHILinFRANCE;16730635]Hi all
Got myself a DR 650 for my Morocco trip and been pulling it apart and putting back together checking every thing !!! i need a new chain and sprocket kit and the stock one is a 15/41 ....is it ? well thats whats on !!! Anyway i'll be riding down from SW France to Algeciras some 1500 km avoiding tolls bimmble around Morocco for a couple of weeks with as much off road as poss, and 1500 km back !!!
So would i be ok running on 15/41 or can anyone suggest another set up ????
I run a 14/45 which is just right around town and good on the trails. I don't like sustained runs at 70mph (112k) or above although it is happy to zoom up there.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 08-28-2011, 03:41 PM   #53687
Eddieb
Eddieb's Avatar
Oddometer: 986
Originally Posted by PHILinFRANCE View Post
Cheers for the feed back guys
@ Andy, Looks like you're right , why do they FCUK with them aint tarmac the same all over?
In terms of gearing yeah you'd think so. Given that the US seems to be the odd country out it's probably some federal mandate or something? NZ probably has a lot more hills per sq/m than most of the US but if anything you'd think they would gear the bikes the other way round because of it.
Our tarmac is not the same as most countries. It's all black and relatively smooth but NZ's tends to use a coarser chip than most countries, that doesn't impact gearing though.
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is online now   Reply With Quote
Old 08-28-2011, 03:47 PM   #53688
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,185
One tooth in the back is only 100 rpm. I have no idea why it'd be different, but oh well.
When I changed my chain back around 10k miles (I'm at almost 18k now), I went to a 112-link chain and run 16/46 (the equivalent of 15/43). When I want more gearing, I pop on a 15T. If I wanna go even lower, I can do a 14T and not worry about a 13T curving the chain too tight.
It's really easy to change the front sprocket on these bikes, so why not keep a couple around?
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 08-28-2011, 03:55 PM   #53689
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,362
Rob
I do and wrote the snail cam adjustment numbers for each front sprocket on top of the swing arm with a marker pen.
A sprocket swap and chain adjustment to suit takes little more than five minutes.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 08-28-2011, 04:27 PM   #53690
Rumlover
Ed
Oddometer: 707
Originally Posted by JMR View Post
I pulled the trigger on a brand new DR today!
Did a 24 mile break-in run then did an oil change at sunset...
Oil is pretty discolored...
And had this crud hanging out after draining all the oil...
It looks to be loose gasket sealing material.
And more crud on the filter...
And there was no drain plug washer! (Could feel this when untightening.)
Sure glad I changed it right away!
Also the chain was too loose with a good 2-inches of play. I tightened it up a smidge for a bit more than 1-inch play. Axle nut seemed a bit too tight (had to use a mallet on the Suzi tool kit cheater bar to loosen it).
First ride impression:
I LOVE THIS BIKE!
Congrats!
Good call on the oil change. I don't think the gasket material will be an issue, a few others have noted similar debris on their fist oil change with no ill effects long term. Might be worth keeping a log of all your maintenance though (with your pics) if anything comes of it -- but I doubt it will be an issue.
Hard to know who messed up on the drain plug gasket (factory or dealership), but my money is on the dealership. Just another example of why YOU should maintain your bike and not the dealership IMO.
Now go get a skid plate for it and Enjoy!!!!!
Rumlover is offline   Reply With Quote
Old 08-28-2011, 04:34 PM   #53691
Tech23
Tech23's Avatar
Oddometer: 476
I LOVE THIS BIKE!
Congrats on your new DR.
To me it looks like the drain plug seal in on the drain plug in your picture. The drain plug seal is more like a spark plug style gasket (crush washer)...might not be what you were expecting to see. Same seal as the timing inspection hole plug. It sounds like you need some better tools to maintain the bike with. Those tools in the tool kit work in a pinch, but there are much better tools to do routine maintenance with. Makes life a lot easier too.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 08-28-2011, 04:35 PM   #53692
ADV8
ADV8's Avatar
Oddometer: 2,362
The stock washer is alloy and can jam onto the plug making it hard to see...fwiw.
Old 08-28-2011, 05:07 PM   #53693
Davis53
Oddometer: 567
Hi all
Here she is
That bike has to have a skidplate.
Northern California
Davis53 is offline   Reply With Quote
Old 08-28-2011, 05:47 PM   #53694
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,608
Why would the dealership have had the drain plug out on a new bike ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-28-2011, 06:31 PM   #53695
epix1718
epix1718's Avatar
Oddometer: 730
LED Tail Light
Wanted to do something a little different so decided to try a go at putting on a sequential LED tail light from a Yamaha R6 on the DR650. Still haven't decided whether to install a DRZ250 tail in replacement of the stock tail or possibly just put a plate over the stock tail light mount.
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 08-28-2011, 06:43 PM   #53696
Commander Crash
Commander Crash's Avatar
Oddometer: 46
clean your air filter
Air filter did not look very dirty. Replaced FMF Q2 with a GSXR 750 pipe . Bike ran OK no real difference between the two pipes. I could not dial in the idle or WOT . Change the main jet from 170 to 155 (my 160 was in my other DR650) no difference in performance . Changed 155 main to a 160 main , no difference in performance . I cleaned the air filter, My raped ape is back . I will clean my air filter . I will clean my air filter . I will clean my air filter . I will clean my air filter . I love my DR's.
Commander Crash screwed with this post 08-28-2011 at 06:46 PM Reason: spellin
Commander Crash is offline   Reply With Quote
Old 08-28-2011, 07:19 PM   #53697
mercenario27
mercenario27's Avatar
Oddometer: 61
That is sweet!
Current
1997 Suzuki DR650 & 2006 Honda CB900F 919 Hornet
Gone
1996 Suzuki GSF750 Kan.of.tuna & 1986 Honda VF700 Intercepter
mercenario27 is offline   Reply With Quote
Old 08-28-2011, 07:36 PM   #53698
Eddieb
Eddieb's Avatar
Oddometer: 986
Thats Sweet. What did you have to do to wire that up?
Old 08-28-2011, 07:43 PM   #53699
epix1718
epix1718's Avatar
Oddometer: 730
Spliced it into the tail light wiring AND the the turn signal wiring. Made my own bracket for the tail light using a 90* Aluminum stock, couple 35mm long 7mm 1.0 pitch bolts, some washers/nuts as well.
97 Suzuki DR650
98 Honda XR250R
Old 08-28-2011, 08:20 PM   #53700
Rumlover
Ed
Oddometer: 707
I have no idea. I was just speculating, because the dealerships as far as I know do the final assembly and setup. And usually thats where things can go wrong, depending on the skill level of that person. I assume they are shipped without oil in them. Maybe the setup guy at the dealership overfilled it and had to correct it. Or maybe they are shipped with the oil already in and as part of the final inspection the setup guy felt it was wrong.
Maybe I am a little quick to throw the blame at the dealership -- but my opinions are based in my experience in dealing with them. And generally dealerships (motorcycle dealers in particular) have left me with little confidence in their expertise. Just my 2cents.
Rumlover screwed with this post 08-28-2011 at 08:25 PM
Times are GMT -7.   It's 01:04 PM.
