Old 09-14-2011, 05:38 PM   #54436
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Originally Posted by ADV8 View Post
What is back and forth ?
If you mean inline with the axle,it is the inner spigot that supports the carrier.
The excess clearance can load the bearing.
Well, getting started and this is the wabling I was talking about. Shoulda noticed this a while ago. Everything looks good except the bearing though. SO FAR
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 09-14-2011, 05:39 PM   #54437
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Oops wrong photo
Old 09-14-2011, 05:44 PM   #54438
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,261
damn. was it the usual crappy single sealed OEM bearing? dust, water and mud will eventually get in on the non-sealed side and make a mess of things quickly. i'd suggest replacing all your bearings (front and rear) with ones sealed on both sides as the original ones wear out.
B1 is offline   Reply With Quote
Old 09-14-2011, 05:54 PM   #54439
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
New bearings in the freezer now. Yep 10000 miles on an 2010 DR650se. Must have been all the water crossings on the OBDR last month
Well know I'm having trouble, I need help. Anyone have a diagram of the cush drive and bearing assembly. I have no clue where to start. I took the seal off and race and everything fell out in pieces. Need an assembly chart. Shit usually when I take things apart I take pix of how they came apart so I can look at them if need be for reassmble. This is a pile of dust.
Old 09-14-2011, 06:13 PM   #54440
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Other question, how in the hell am I gonna get the bearing race outta there?
Old 09-14-2011, 06:32 PM   #54441
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,256
I can't remember if the outer race shows enough to knock it out (broken bearing)
There are some pictures here,PM me if you want the manual PDF.
The fully seal bearing is a must.
Take the time after fitting the new one to refit the wheel without the cush drive rubbers.
Tighten the axle then see how much movement there is at the sprocket outer edge in line with the axle.
Then make a face light this.
http://s30.photobucket.com/albums/c3.../DR%20Bearing/
ADV8 is offline   Reply With Quote
Old 09-14-2011, 06:36 PM   #54442
ADV8
ADV8's Avatar
Oddometer: 2,256
This picture suggests it would be hard to knock the outer out by itself.
You might be able to get a drift on an angle and ease it out.
Heating the hub would not hurt.
That or putting a small bead of weld on the race to shrink it.
Old 09-14-2011, 06:43 PM   #54443
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Hmmmmmmm. Thanks for the pix. Good info. Dammit I can barely get in thru the other side to get on it. I think the welding idea may work. I was thinking about dry Ice on the race and then tap at it. I'm worried about it coming out at an angle and scaring the seat. Pm set for the manual. shoot this thing looks like hell, I think I'll take it to shop to bath it first. Maybe get a better look at it then. Shop up street has solvent tank. Hmmmmmm dammit
Old 09-14-2011, 07:35 PM   #54444
Heavy
Heavy's Avatar
Oddometer: 120
...Well know I'm having trouble, I need help. Anyone have a diagram of the cush drive and bearing assembly. I have no clue where to start. I took the seal off and race and everything fell out in pieces. Need an assembly chart. Shit usually when I take things apart I take pix of how they came apart so I can look at them if need be for reassmble. This is a pile of dust.
Hope this helps....
There is never enough time or money to do it right the first time.
2008 DR650, 2006 V-Strom 1000
Heavy is offline   Reply With Quote
Old 09-14-2011, 07:45 PM   #54445
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Originally Posted by Heavy View Post
Hope this helps....
Yes anything helps. That's good stuff. Adv8 is somehow from OZ helping too. Fairly shur it's early in the morning there. Thanks guys keep ideas coming. Gonna have a drink now and think about it. Tried drift and tapping. No success, and scares me to hit inside there like that. I'll have it figured out after a double.
Old 09-14-2011, 08:25 PM   #54446
sander
sander's Avatar
Oddometer: 313
Definitely put a small weld bead on the inside of the outer race mate. It'll probably fall straight out. Or maybe you can cut a slot in it with a dremel but I'm not sure it maybe to hard.
sander is offline   Reply With Quote
Old 09-14-2011, 09:46 PM   #54447
procycle
procycle's Avatar
Oddometer: 2,251
+1
Running a weld bead around the inside of the race is the quickest, easiest solution.
Once it cools the race will fall right out.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-14-2011, 10:21 PM   #54448
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Low priced knobbies
I've ridden with someone who had one of these on. The knobbies were so tall and soft you could grab the knobby and wiggle it with ease. That tire wouldn't have lasted 500 miles on the street. Neat tire though
asrvivor, I've had good luck using the Shinko 244 knobbies on my DR650.
This tire picture shows the rear 244 that was put on 7/1/2011 (3312 miles ago) and has LOTS of highway miles commuting to work 40 miles per day, and lots of weekend rides to the woods.
You can see by the chicken strips that it handles the corners pretty well, and can't beat the price (around $50 for rear and about 1/2 that for the front). I've been getting about 10K on the front and 6K to 9K on the rear, depending on throttle use (heavy or light).
Dave
smilin jack is offline   Reply With Quote
Old 09-14-2011, 11:35 PM   #54449
wfo600
Oddometer: 192
ghey fork gaiters
I'm in the process of rebuilding the front forks. New seals, emulators, springs, bushings, blah blah blah. Can anyone give me two good reasons to reinstall those ghey fork gaiters? I've got a fork brace on there now and that squishes them all up and makes them look even more low budget than they already are... I know the first reason will be to keep rocks and debris from dinging the fork tubes. I've ridden plenty of street bikes with exposed tubes so I don't really buy that. Looking online though, I don't find many pictures of dr's without them. Enlighten me, please...
wfo600 is offline   Reply With Quote
Old 09-14-2011, 11:45 PM   #54450
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Dirt riding = dust and dirt = quicker wearing seals.
Street bikes don't get out in the rocks and debris as a rule.
I use fork skins...
http://www.motorcycle-superstore.com...ork-Skins.aspx
NordieBoy is offline   Reply With Quote
Times are GMT -7.   It's 06:18 AM.
