Old 09-14-2011, 11:50 PM   #54451
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,255
The postie just dropped off the HID kit from
http://canadiancruisercustomizing.co...kvri9sgb7fb8t2
Looks OK for the princely sum of $44.99
ADV8 is offline   Reply With Quote
Old 09-14-2011, 11:54 PM   #54452
ADV8
ADV8's Avatar
Oddometer: 2,255
Originally Posted by NordieBoy View Post
Dirt riding = dust and dirt = quicker wearing seals.
Street bikes don't get out in the rocks and debris as a rule.
The TL1000 was the original V - Strom.
Old 09-15-2011, 05:04 AM   #54453
mercenario27
mercenario27's Avatar
Oddometer: 61
Originally Posted by smilin jack View Post
asrvivor, I've had good luck using the Shinko 244 knobbies on my DR650.
This tire picture shows the rear 244 that was put on 7/1/2011 (3312 miles ago) and has LOTS of highway miles commuting to work 40 miles per day, and lots of weekend rides to the woods.
You can see by the chicken strips that it handles the corners pretty well, and can't beat the price (around $50 for rear and about 1/2 that for the front). I've been getting about 10K on the front and 6K to 9K on the rear, depending on throttle use (heavy or light).
Dave
If been using the Kenda 270 and already have almost 4k on them and they have 50% thread left on them. I beat the snot out of these tires on and off road, I'm always on the throttle hard. At first I thought they weren't going to last the whole season, but the season is just about over and they have penty on thread life left. I ride 50/50, I would love to ride offroad more! Lack of local trails and my fellow thumpers work schedules prevents that.
On road they are pretty decent and they don't wear as fast as you would think. Off road they are better, in the mud/sand only a true MX tire would be better. They work great on the hill climbs.
I would diffently recommend the Shinko 270s and the Kenda 270s as a true 50/50 tire
Current
1997 Suzuki DR650 & 2006 Honda CB900F 919 Hornet
Gone
1996 Suzuki GSF750 Kan.of.tuna & 1986 Honda VF700 Intercepter
mercenario27 is offline   Reply With Quote
Old 09-15-2011, 05:40 AM   #54454
mercenario27
Oddometer: 61
Has anyone replaced their clutch/brake levers/perches on their pig? Post some pictures of them mounted.
Current
Gone
Old 09-15-2011, 08:35 AM   #54455
Porrick
Going nowhere fast
Porrick's Avatar
Oddometer: 102
HDB top plate/guards for DR650
Hey,
I am about to buy the HDB fat bar / top plate / hand guard setup and can't get them (him?) to answer an e-mail about the proper top plate bolt pattern. So I'll ask here:
I have 7/8" bars (TAG X5) and my current bolt pattern is 98mm x 35mm. If I want to go to the Protaper fat bars, do I just need to choose the 98mm x 38/40mm option from the drop-down menu on the HDB site?? It is the only 98mm choice in the menu, but I wanna be sure....
Hope he's more responsive after I've ordered and payed.
Thanks for any help.
Porrick
Porrick is offline   Reply With Quote
Old 09-15-2011, 08:46 AM   #54456
YnotJP?
Oddometer: 2,353
Originally Posted by Porrick View Post
Hey,
Porrick
I have the same set-up. I have the 100X38/40 and it works. The two bolts for the lower half of the mount that came with my order were too short, but, I just got some longer ones at a locale bolt shop for about $4.00.
You will like the bars and guards.
YnotJP? is online now   Reply With Quote
Old 09-15-2011, 09:00 AM   #54457
xKLR_John
xKLR_John's Avatar
Oddometer: 877
The Kenda 270s have their advocates but I prefer the Shinko 244. The 270 had a strange feeling of losing traction on the rear, on the road, when initiating turns. I sort of got used to the feeling because I never did go skidding off into the ditch but it wasn't a nice smooth transition into the turn. The first few turns I swear the rear was stepping out 6" before the side knobs gripped. I reckon it's a mind over matter thing, if you can get past the spooky transition the 270 will grip just fine.
I like the Shinko 244 a lot better. YMMV
xKLR_John is offline   Reply With Quote
Old 09-15-2011, 09:09 AM   #54458
wfo600
Oddometer: 192
[QUOTE=ADV8;16859356]The TL1000 was the original V - Strom.
[IMG]
How funny, I had a tl1000s too. The US model didn't have the ti coated fork sliders though... Sold it after it tried to kill me for about the 65th time. That thing was a head shaing, tank slapping mess.
wfo600 is offline   Reply With Quote
Old 09-15-2011, 09:28 AM   #54459
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,924
The reason those feel like they are stepping out is that the lugs are so squared off and soft that the side lugs flex when cornering. I had good luck with those tires, but they did feel a little sketchy in hard corners. I never had them let loose on me though.
"I go where the voices in my head tell me to!"
KTM 990 ADV- "Annika"
Grizz Adams is offline   Reply With Quote
Old 09-15-2011, 10:28 AM   #54460
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Dirt riding = dust and dirt = quicker wearing seals. Street bikes don't get out in the rocks and debris as a rule.
I use fork skins...
http://www.motorcycle-superstore.com...ork-Skins.aspx
In heavy dirt use, dirt, mud and water, can get inside the stock accordion fork gaiters. Good idea to clean in there once in a while. If you don't, eventually you may damage a fork seal.
Street riding is actually a good place to nick a fork tube. Little stones kicked up at high speed can ding the tubes if unprotected. A nicked fork tube can tear a fork seal.
The Fork Skins are an excellent solution ... and work better with a fork brace.
Old 09-15-2011, 10:32 AM   #54461
Adv Grifter
Oddometer: 6,128
Dave
I have a set of 244's. I ran the front (the 244 Golden Boy) Pretty scary front tire for street use, IMO. But it wears like iron. I have not yet mounted the rear ... but it's here waiting for the right ride to use it. Good to know your 244 rear is holding up so well! (3312 miles since July 1st! Wow ... you've been riding! ) Thanks for the feed back!
Old 09-15-2011, 10:34 AM   #54462
Adv Grifter
Oddometer: 6,128
Nice! That kit is exactly the same as the DDM tuning kit we get here in USA. Does yours have the Lo Beam/High Beam option? Mine ($27) is low beam only ... but is so bright I left it alone.
Old 09-15-2011, 10:38 AM   #54463
Adv Grifter
Oddometer: 6,128
Your reaction is pretty typical of the K270's from the KLR gang. Many KLR riders love them ... but won't be doing aggressive cornering with them. They last really well ... even on a fully loaded KLR. That says a lot, IMO ... but use caution in sporty riding at serious lean angles.
Old 09-15-2011, 10:47 AM   #54464
ct-ktm
Oddometer: 3,176
I been using the k270 and loved them...after a flat front doing 50 or so I might look for something a little tougher in the sidewall..Looking at the tire last night and it has a huge gash in it..
ct-ktm is offline   Reply With Quote
Old 09-15-2011, 11:01 AM   #54465
shu
Oddometer: 996
Originally Posted by wfo600 View Post
I'm in the process of rebuilding the front forks. New seals, emulators, springs, bushings, blah blah blah. Can anyone give me two good reasons to reinstall those ghey fork gaiters? I've got a fork brace on there now and that squishes them all up and makes them look even more low budget than they already are... I know the first reason will be to keep rocks and debris from dinging the fork tubes. I've ridden plenty of street bikes with exposed tubes so I don't really buy that. Looking online though, I don't find many pictures of dr's without them. Enlighten me, please...
I put gaiters on my street bikes. On my K100RS I went through 2 sets of seals in 6,000 miles. After the gaiters: over 100,000 miles and the seals were still good. I put a Fork skin type protector on my F800ST and now have 30,000 miles on my fork seals. On my DR I now have 40,000 miles on my fork seals- lots of dirt and rocks.
My opinion: it's a mistake to take them off any bike and the reason street bikes don't have them is for looks. They're highly functional.
............shu
shu is online now   Reply With Quote
Times are GMT -7.   It's 08:59 PM.
