Old 09-29-2011, 11:36 PM   #54976
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,396
if you soak it use the Pine Sol soak method.
it's safe on rubber.
Originally Posted by Aerocycle View Post
I never experienced the engine stalling from bumps or uneven terrain, but I did have an issue for a while when I pulled the clutch in from highway speeds the engine would die. I messed with it for a while, and adjusted the throttle stop screw to adjust idle rpm, only do this when the engine is thoroughly warm though. Since then I've installed a jet kit which helped it run a bit better.
You may consider removing/disassembling the carb and cleaning it in carb cleaner (soaking it), then while your at it install a extended fuel screw so you can adjust idle mixture, and even a step further you could shim up the needle a bit. That's what i would do, but always start with the simple.
edit: checking the float height and float needle for it's condition is another thought... to help you tear one apart get a service manual, and use this link: http://www.advrider.com/forums/showthread.php?t=347184
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-30-2011, 07:12 AM   #54977
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
another vote for inspection of side stand switch.
grab a pipe clamp that will make it around the stand and frame. head out to your favorite bumpy trail. install pipe clamp to make sure stand cannot move. See if stalling problem goes away or not.
my DR runs laying on it's side. The carb is pretty tolerant of running at different angles (bumps, jumps, etc). Carb is logical next place to look but as a betting man I'd put my money on the side switch.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 09-30-2011, 08:36 AM   #54978
Harpua
formerly josdavlar
Harpua's Avatar
Oddometer: 166
right! side stand switch! duh...
i'll totally start there and check back with ya'll. thanks so much.
Harpua is offline   Reply With Quote
Old 09-30-2011, 08:56 AM   #54979
SprintST
SprintST's Avatar
Oddometer: 208
Need help with some electrical questions
I'm so electrically challenged it's almost embarrassing so please be patient.
What I want to do is hook up a bunch of gizmos to my 2010 DR650. I've already (successfully it seems ) changed out the stock headlight for a HID unit from Procycle. Nice difference. Other things that I now have running directly from the battery posts are a plug-in for Gerbings heated clothing, a plug-in for a battery tender, and the positive lead for the HID light. It's getting a little crowded on those two battery terminals, not the mention the mass of wiring and fuses collecting under the seat.
Other stuff I want to add on are a Garmin GPS, USB charger port for an Ipod, a Steibel horn, a 12V powerlet for an air pump, and a Trail Tech Voyager dash (not sure yet if that requires 12V power).
Any recommendations for auxiliary fuse blocks or alternate solutions. What are you all doing for your electrical needs? I think I'd like to have it all set up so that power only runs to the accessories when the bike is running. That way I'll never wake up to a dead battery because I forget to turn something off.
Suggestions? All will be appreciated.
"Let us never forget those who can't remember" [author unknown]
SprintST is offline   Reply With Quote
Old 09-30-2011, 09:56 AM   #54980
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
shameless plug: i have an unmounted HDB setup for DR that I'm not going to use if someone wants to save a buck or 10.
just haven't gotten around to shooting pictures and putting in flea market.
has the upgraded longer/fatter guards, 7/8" bars
Build Your Own Handguards 7/8" Bars
Choose Your Top Clamp Bolt Pattern: 100x33/35mm Bolt Pattern.
Upgrade Your Top Clamp: SXdx Top Clamp
Upgrade to our Ultimate Hanguards: Ultimate Handguards
Add Black Anodize: None
Add a Mirror: None
Originally Posted by thumpididump View Post
Interesting.... earlier when I was posting the measurements, I went digging through my old PayPal receipt from when I placed my order with HDB... that's where I got the figures... and I remember when I placed my order in January, I didn't go by what the website said, rather, I used my digital capliper to take an acurate measurement.
For the record, I have 2007 RMZ250 forks and triples.
Now I'm going to measure again.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 09-30-2011, 10:22 AM   #54981
vintagespeed
fNg
Oddometer: 1,855
Originally Posted by hmmwv15 View Post
The procycle kit I got was marked as 6000K, supposed to be bright white, (has just a hint of blue). If I can find a 4500K bulb I'll see how I like it.
get the 4800K, you'll be much happier with the light pattern. the 6000k is blue, especially at night you notice all the signs and anything white is blue. it's not a huge deal because i bought mine to make me more visible on the freeway in traffic, but it's still blue.
Originally Posted by SprintST View Post
....Any recommendations for auxiliary fuse blocks or alternate solutions.....
run 2 wires up from the battery (hot & ground) to a fused 30A relay behind the cowl, triggered by the unused ignition switch plug (brown plug behind cowl), to a small 8 wire distribution block. plug all your goodies into that. use one side of the distribution block for HOT +, the other side for ground - make sure the ground connects to the battery ground wire on the relay.
vintagespeed is offline   Reply With Quote
Old 09-30-2011, 12:22 PM   #54982
SprintST
SprintST's Avatar
Oddometer: 208
Thanks for the input vintagspeed. I've read that the hot wire running from the battery to the fuse block should be as short as possible in order for a fuse to catch any overload as soon as possible. Make any sense? Like I said in my OP, I'm electrically challenged.
Old 09-30-2011, 01:05 PM   #54983
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,396
updated wolfman side racks w/ hard bag mount option.
rack pics:
http://www.advrider.com/forums/showp...ostcount=55102
info thread:
http://www.advrider.com/forums/showthread.php?t=729632
Alaska
Old 09-30-2011, 01:47 PM   #54984
drsmiley
drsmiley's Avatar
Oddometer: 273
Wolfman Rocks!!! Really good stuff and keeps on trying to make it BETTER! PLUS it's MADE IN THE USA!!!
drsmiley is offline   Reply With Quote
Old 09-30-2011, 01:47 PM   #54985
vintagespeed
fNg
Oddometer: 1,855
...I've read that the hot wire running from the battery to the fuse block should be as short as possible in order for a fuse to catch any overload as soon as possible.....
yes, good point, place the fuse as close to the battery as you can. and use a fairly substantial gauge of wire since you're only going to run 2 wires to power all that stuff. something like 8-10ga should be good enough.
Old 09-30-2011, 01:55 PM   #54986
maynard911
Oddometer: 142
Well, let's see now............. electricity in a wire travels at the speed of light in a vacuum (186,000 miles per second) so......... if I make this wire a foot shorter the fuse will blow how much sooner.....hmmmm
Having a short wire between the battery and the fuse does make sense because until the fuse the wire itself is unprotected and if it should short out 'things get messy' (that's a technical electrical term). The purpose of the fuse is to protect the wire.
maynard911 is offline   Reply With Quote
Old 09-30-2011, 02:03 PM   #54987
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,730
"my basically stock '03 dies a lot when i'm on very bumpy or rocky terrain"
A perfectly logical suggestion for the reason you site.
As to the dying when you pull in the clutch, my choke cable was broken at the carb (the threaded plastic body) and it would open the choke slightly and it would die at idle at stops.
Another culprit could be the tiny filter in the inlet barb, You have to take the fuel line off the carb to pull it out.
I took my kickstand switch off the bike because it was doing exactly what you say is happening on bumpy/rocky terrain.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 09-30-2011, 02:06 PM   #54988
weerider
weerider's Avatar
Oddometer: 32
stickers
can anyone help me determine if I can take my stickers off the gas tank without wrecking the paint
the large vstrom stickers they are a bit too much
thanks
weerider is offline   Reply With Quote
Old 09-30-2011, 02:17 PM   #54989
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,396
thanks
you are wrong thread.
this is dr not dl650
and the strom is a beast so wrong area too.
i had a strom...if they are from older bike they tend to remove paint at the same time.
use a hair dryer to lossen the glue.
Alaska
Old 09-30-2011, 03:04 PM   #54990
maynard911
Oddometer: 142
Google 'wire ampacities chart' This tells you how large a wire is needed to carry a given load without overheating. The DR only has about 80w of spare capacity to play with so 10 gauge wire is overkill. 10 gauge is good for 33amps, or around 450w assuming 14volts (Volts x Amps = Watts. Even if you were willing to pull 10A, which would kill your battery in short order, 18 gauge is good to go.
Times are GMT -7.   It's 02:46 PM.
