10-05-2011, 01:47 AM
#55156 | |
I can pass this guy.....
Oddometer: 2,737
2012 Triumph Bonneville 2006 Suzuki Vstrom ![]() Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
10-05-2011, 03:24 AM
#55157 |
Oddometer: 532
Tried putting on my supermoto wheels last night, is there a trick of getting the darn front caliper inside the wheel!?? I'm using the EBC 320mm rotor kit with adapter which is mounted on the fork, but it's almost like I can't fit the caliper between the rim and rotor when I try to put the wheel on.
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 83 Yamaha XT550 www.drriders.com |
10-05-2011, 03:27 AM
#55158 |
Taumarunui..Darwin..
Oddometer: 2,110
IIRC I ended up filing a small bevel onto the offending part of the caliper.
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780. |
10-05-2011, 03:30 AM
#55159 | |
PUI Offender
Oddometer: 8,308
Southeast Weather Map "I might as well keep going, there's no 'effing way I'm going back the way I came" Moran Nation 21 Club. |
10-05-2011, 03:52 AM
#55160 | |
Oddometer: 2,110
A small bevel makes it easy.
10-05-2011, 05:07 AM
#55161 | |
Oddometer: 76
What the he'll?
13' KTM 500 exc 06' Suzuki DR 650 09' Genuine Blackjack 08' KTM 300 xcw |
10-05-2011, 05:19 AM
#55162 | |
PUI Offender
Oddometer: 8,308
10-05-2011, 05:39 AM
#55163 |
Oddometer: 76
Tires mounted and balanced by Cycle Gear out West here.
Not sure if they use an actual high speed balancer or not........but that makes sense to me although the tire looks perfect around the bead. No visual clues.
10-05-2011, 06:05 AM
#55164 | |
PUI Offender
Oddometer: 8,308
![]() They never use anything but Fred Flintstone balancing. Talk to Wilma and smile...
10-05-2011, 07:41 AM
#55165 | |
Rabies Cure ????
Oddometer: 1,877
Ya that's weird. I think trying a different tire might be the only option. Problem is you now have spacers that are messed up. Gonna have to replace them if they are too bad. Procycle in Eugene Oregon can get all that crap. The spacers aren't cheap though. $23 bucks for number 19.
Staring straight into the shining sun.... Just cause I'm wrong, don't make you right / Needtobreathe Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724 Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500 |
10-05-2011, 08:40 AM
#55166 | |
fNg
Oddometer: 779
![]() OP, unbolt the rotor from the wheel and fit it up. that's what i had to do to mount the KX wheel.
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
10-05-2011, 09:19 AM
#55167 |
Oddometer: 632
TCI Products Skid plate
Has anyone used TCI Products skid plate? I like the side engine guards.
https://tciproductsusa.com/index.php...roducts_id=569 Has it held up good? Is it easy to R&R? Worth the money?
2011 Victory Cross Country 2006 Suzuki DR 650 |
10-05-2011, 09:22 AM
#55168 | |
Rabies Cure ????
Oddometer: 1,877
10-05-2011, 10:09 AM
#55169 |
Oddometer: 739
Corbin or Sargent for on-road only?
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
10-05-2011, 10:14 AM
#55170 | |
fNg
Oddometer: 779
that TCI might have saved my shift lever this weekend...
