Old 10-07-2011, 01:22 PM   #55201
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by Rumlover View Post
I would think the reduction in lift is pretty small compared to the gain made at the needle and overall performance, especially when talking about shims of .05" or less (which seems to be about average for those that have done it).
How do you figure?
I would like to hear what the consequences of cutting the spring would be also? Would lift be the same, just dampened?
Cutting the spring increases the spring rate, but reduces the preload. The general trend will be sightly less force required to get the slide to move off of the stop, but more force required to get it to open all the way. The spring rate and preload do not affect damping in any way. Damping is controlled by slide lift hole number and size.
One thing I forgot to mention before is that the additional preload from shimming the needle will make the slide come off the stop at a later point in terms of rpm and throttle position (i.e. more velocity will be required to get it to come up off of the stop).
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-07-2011, 01:27 PM   #55202
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,174
Originally Posted by Adv Grifter View Post
...Many aren't doing the ride to "integrate" with local culture, and just yell louder in English to be understood. For them, it's all about them and furthering their Adventure career (film, book, website) ... and collecting stickers on the panniers and stamps in passport are of paramount importance. These are the "achievers"...
That is probably the single most salient point ever made on advider! Thank you!
What's travel if you don't immerse yourself in your surroundings and the local culture!
On a week-long ride through British Columbia last year, my wife said, "I never want to travel by car again! On a bike, you're in the environment, experiencing it. In a car, you're just a tourist."
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak is online now   Reply With Quote
Old 10-07-2011, 01:37 PM   #55203
Rumlover
Ed
Oddometer: 707
Originally Posted by motolab View Post
How do you figure?
Regards,
Derek
Not very well. Like I said I could be wrong. My thought is/was that even though the slide is rising less for any given air velocity, the needle is still higher in relation to the needle jet for any given slide height (because of the shim -- same as changing a clip position on a needle that has more then one). The end result is a richer mixture in the midrange.
I retain the right to be wrong
Rumlover is offline   Reply With Quote
Old 10-07-2011, 01:44 PM   #55204
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by vintagespeed View Post
it does if the shim is above the spring seat and inside the spring thus not affecting spring preload, the stock needle doesn't have a clip.
edit:
i'll have to check mine to be sure, but i wouldn't have put the shim UNDER the spring seat as it'd just fall off and that would be silly. lol
If the shim is above the spring seat, it can't raise the needle, unless you say you installed the clip above the spring seat as well (a stock needle does come with and is supposed to have clip installed). If you installed the needle with the clip above the spring seat the needle will be free to bounce, as the seat bearing on the clip is supposed to hold it captive. Once again, the shim must go under the clip (which is under the spring seat). This should help:
Regards,
Derek
Old 10-07-2011, 01:52 PM   #55205
motolab
motolab's Avatar
Oddometer: 2,584
Think of it this way: Lowering the clip position raises the needle relative to the emulsion tube (without lowering the slide), whereas shimming the needle clip lowers the slide relative to the emulsion tube (without raising the needle). Now, there is an exception to this, and that is when the slide is against the stop. During that condition, a shim does raise the needle in relationship to the emulsion tube.
Regards,
Derek
motolab screwed with this post 10-07-2011 at 03:22 PM
Old 10-07-2011, 01:58 PM   #55206
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,942
Originally Posted by newone View Post
Thanks. I think it would be difficult to find. DR is not the most popular motorcycle in Russia. :)
Sorry, Bro. I didn't even look to see where it is you are located. Maybe you can find some on ebay or something. Good luck!
"I go where the voices in my head tell me to!"
2012 KTM 990 ADV- "Annika"
2007 KTM 250XCF- " Viktoria"
Grizz Adams is offline   Reply With Quote
Old 10-07-2011, 02:09 PM   #55207
Rumlover
Ed
Oddometer: 707
Think of it this way: Changing the clip position raises the needle relative to the emulsion tube (without lowering the slide), whereas shimming the needle clip lowers the slide relative to the emulsion tube (without raising the needle). Now, there is an exception to this, and that is when the slide is against the stop. During that condition, a shim does raise the needle in relationship to the emulsion tube.
Regards,
Derek
I will try to clarify my point. I understand that increasing preload makes the slide require more air velocity to achieve a given height. I equate that as also more air volume entering the engine. So the question in my mind is shimming the needle going to allow enough more gas into the airstream to not only compensate for the increase volume but also slightly richen it. I think it does, and I don't think the slight amount of preload is enough to really make a hill of beans difference in reality.
Anyways that is my theory and for the sake of the thread (and not to get bogged down) I will defer to your expertise.
Old 10-07-2011, 02:38 PM   #55208
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,135
Originally Posted by Foot dragger View Post
Its automatic,no need to fool with it
DR650 cam chains dont wear out any quicker then any other bike.
So has anyone needed to replace a camchain because of wear? What mileage does this occur?
My buddies TE610 needed a camchain at 10,000 mi. Those were problem chains I know, but the lack of discussion here makes me think, "it'll last longer than bike"
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-07-2011, 02:40 PM   #55209
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,752
If the shim is above the spring seat, it can't raise the needle.........Derek
well man, i guess you just dont understand what i'm saying or maybe there's a difference in YOUR model?
the shim above the spring seat on the needle raises the needle in the seat, thus raising the needle in the slide.
as long as the shim fits inside the spring on top of the seat, it wont affect the spring rate in any way. and i'm pretty sure that's how i installed it, i'm not new to carbs.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-07-2011, 02:41 PM   #55210
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,307
The only reason people put a shim under the clip is because the needle only has one clip position in some countries.
Lower the clip or shim under the clip is the same thing,the needle taper is raised in the needle jet.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 10-07-2011, 03:18 PM   #55211
motolab
motolab's Avatar
Oddometer: 2,584
Did you have a look at the diagram?
Regards,
Derek
Old 10-07-2011, 03:20 PM   #55212
motolab
motolab's Avatar
Oddometer: 2,584
Correct!
Incorrect! As already explained, it is not the same thing.
Regards,
Derek
Old 10-07-2011, 03:23 PM   #55213
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,156
Hey Phil,
Not sure how securely you've mounted the Aux fuel can ... but on rough Morocco wash board I could see the mounting hardware work hardening and snapping off in a couple days of off road hammering.
I would make sure the fuel can is strapped on with bungee cords or Roc straps (STRONG!) to add security off road. 5 liters isn't much but better than nothing. Best to have 19 liters (5 US gallons ... like IMS tank)
Check out Colebatch's latest Morocco ride report. He documents some great places to explore there:
http://www.advrider.com/forums/showthread.php?t=727119
Cheers AdvG for the input
I've give it a couple of HARD test runs and seems to be holding up fine , but as you say i will be Roc strapping it aswell. The stock tank hold 13 lts plus 5lts in the can is only slightly less than the IMS !!! Also been taking an account of Kms per Lt and the worst i've got is 22 km / ltr = 286 per tank + 110 Aux !!!! thick end of 400 klicks and if all fails i'll find a camel
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 10-07-2011, 04:09 PM   #55214
vintagespeed
fNg
Oddometer: 1,752
Eek
Regards,
Derek
yes i did. i do not have an e-clip on my needle. the spacer fits over the needle from the pointed tip up and sits on a shelf on the needle itself. i installed the shim between this shelf and the spacer, then the spring sits on top of the spacer inside the slide.
edit:
the spacer i refer to being item #22 on the diagram.
vintagespeed screwed with this post 10-07-2011 at 04:12 PM Reason: clarification
Old 10-07-2011, 04:19 PM   #55215
jon_l
jon_l's Avatar
Oddometer: 3,138
I wont soon put another knobby on my plated DRZe,trials tire hooks up so good its like cheating!
They only come in 18" so a no go on a DR.
And 21" of course. Have you used the front?
I see quite a few serious enduro guys off-road racing on trials tires (rear only, as best I recall) these days, so I expect them to work well off-road. My concern is more how the front works on and off pavement.
I know the D606 is good, but it is noisy on the road, and the trials tire is both cheaper and according to most people, very good off-road.
CBF1000 & PCX150
jon_l screwed with this post 10-07-2011 at 04:28 PM
jon_l is offline   Reply With Quote
Times are GMT -7.   It's 01:42 PM.
