Old 10-07-2011, 06:46 PM   #55231
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by acap650 View Post
It's a trials tire. Even though DOT approved probably not good for pavement - trials bikes run near single digit pressure in the tires and rarely exceed 40 mph. Also note the square profile would make leaning on pavement a challenge.
Trials bikes do run extremely low pressures but these bikes aren't trials bikes.
The Pirelli MT43 is rated to 280kg @ 33psi cold.
Leaning on pavement is only an issue if aired down to 12psi or lower.
Then you allow for it.
NordieBoy is offline   Reply With Quote
Old 10-07-2011, 06:48 PM   #55232
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,901
Originally Posted by Rusty Rocket View Post
What are you planning to use it for. Offroad?
Skidplate first. Then handguards & better handlebars. Then tires. DynoJet kit in the carb is fine, cut the airbox and drill thr second hole in the slide.
14 tooth sprkt. You're up to about $400 now.
On road? I'll let someone else speak to that.
SEAT!!!!!!!!! That stocker is beyond a torture rack! Hunt down a better one on ebay or put on a Seat Concepts kit.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 10-07-2011, 06:49 PM   #55233
Rumlover
Ed
Oddometer: 707
Originally Posted by tobbik View Post
Just to say thanks, TravelGuy was spot on it was the kill switch. Now I just don't know what pisses me of more, that someone pushed i my killswitch while being parked down town, or that they actually got me with that stupid prank. Oh well, I guess I learnt my lesson ...
-t
Just be happy
Rumlover is offline   Reply With Quote
Old 10-07-2011, 06:52 PM   #55234
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by rockydrxrvr View Post
Well, if 36 mpg. is okay, down from 50 mpg,...then jet kit knock yourself out.
Any rejetted DR650 that is only getting 36 mpg is not set up correctly. When jetted right the fuel economy won't take more than a 2-3 mpg hit.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-07-2011, 06:52 PM   #55235
Foot dragger
singletracker
Oddometer: 12,901
I upped my dirt tracking corner speed so much with a MT43 it was borderline dangerous,stop quicker coming in,hook up harder coming out of the corner with no rear end waggling all over the place.
The scary thing is I could have gone faster. This on my DRZe,its been an over sliding sort of bike no matter what back tire I put on it,not anymore. Ive only ran it down to 13 lbs so far,friends get away with 11,Im a little paranoid about flats still,they sure smooth the ride out though.
Old 10-07-2011, 07:11 PM   #55236
Trbig67
Oddometer: 108
I left a ride report about my trip in the Colorado mountains on my DR650...
http://www.advrider.com/forums/showt...9#post17026939
Trbig67 is offline   Reply With Quote
Old 10-07-2011, 07:30 PM   #55237
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Originally Posted by EBMOTT View Post
MY seat measures 11 3/4 inches at it widest seating area. Now having both seats a corban on my 97 dr560 i do have to say i like the sargent better. it fits on any tank combo out there. it fits perfectly on my safari tank with no problem.
hope this helps
chears mott
Thank you much, i think that way the last bit i needed to be pushed to the sargent. Its cheaper and just as wide. My problem is that i ride 2 up, and i dont want to be uncomfortable on the front of the seat. I see the corbin is wider near the front, is the sargent just as good?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-07-2011, 07:55 PM   #55238
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
There are some good pics of both the Corbin and Sargent on this thread.
Here is an above shot of my Corbin. The Corbin takes ages to break in and get comfortable. At least 2 or 3000 miles of seat time. Mine is now up to 40,000 ... the Corbin is not bad for multiple 400 mile days if you're head is in it.
You may see Corbins for sale used from time to time ... Sargent's too.
Old 10-07-2011, 07:56 PM   #55239
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
If you're running 520 sprockets, go for DR750 ones over pre96 DR650 ones...
DR650 Wiki
Old 10-07-2011, 07:56 PM   #55240
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,446
I've owned Corbin's on BMW's, TravelCade's on the Gold Wing, and I have a Sargeant on the DR.
Anything is better than the stock pine rail ... uh, saddle that comes on the DR650.
FWIW, to my thinking the average rider who just needs a bit more comfort for all-day rides or longer tours would find comfort a toss-up between Corbin and Sargeant.
The primary tipping point for me on buying the Sargeant for the DR was because it will fit any aftermarket tank.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 10-07-2011, 08:16 PM   #55241
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
The Corbin also weights as much as a small child fed on McDonalds.
Old 10-07-2011, 08:52 PM   #55242
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by dogjaw View Post
I have a stock 06 DR650, recently sold some goodies to finance a jet kit, airbox mod, exhaust... when I called to order, was recommended that I go the TM40 route, opening up a whole new set of issues. If you had a 500.00 budget, what would you do and where would you start?
Don't spend money you don't have to. A carb-tuning kit might be perfectly fine for you until you have other areas of the bike set up for you and you still have some money to burn. THEN get a flatslide pumper carb...and a 780 kit with a cam. IMO, if you're near sea-level, you NEED to richen the carbing to get it running right.
Forget Dynojet and the other kits that just have jets. Get the Procycle kit with the main jets, the adjustable needle, the extended mixture screw, the slide-drilling drillbit, and instructions/support. While a pumper carb would be awesome, you can get the DR running pretty nicely with a properly-tuned stock carb. I have stock sprockets and mine gets around 50MPG. Throttle response is ridiculous compared to stock now. It pulls the front wheel with just a blip of the throttle in 1st. 2nd takes a purposeful decel-blip at some revs, but it still comes up without me pulling or clutching. A 14T CS would be silly. I also have an FMF Q2 muffler and a Uni filter, but I haven't ground the header weld yet. It hauls us 2-up with luggage down the slab faster than any legal speed limit in this country, and it pulls higher gears at lower speeds smoothly now. I can shift to 5th at 45MPH (indicated), and it'll still pull it. It also runs cooler, starts easier, and comes off choke quicker.
If you're not getting close to 45-55MPG (hwy), riding somewhat sedately with a DR650SE, something isn't adjusted right. Common tune culprits are the needle position, the mixture screw adjustment, the pilot jet, and the main jet. If the main jet is the recommended one and it test-rides well per Procycle's instructions, I'd start with going leaner on the needle and then adjusting the mixture screw per instructions. If there isn't enough adjustment in the needle and the mixture screw, try a 1-size smaller pilot jet and start testing needle/screw settings again.
You don't even really have to remove the carb to do the Procycle kit. Just drain the bowl into a paper cup and pour that back into the tank, pull the lines and cables, remove the plastics, seat, and tank, then loosen the carb boot clamps, and rotate the carb to access the top or bottom. Use a good #2 Phillips bit, and a cordless drill with the clutch set fairly soft (I used "5" on my drill), to break the OEM screws loose. I had to go up one slot leaner on the needle from Procycle's instructions though, as my idle mix was too rich to adjust with the range the mixture screw affords. The kit is do-able with a stock exhaust too, so you don't have to spend your money there just yet. I WOULD recommend getting a filter better than the OEM or a K&N. Uni or Twinair come to mind.
- Get a decent service manual.
- Get a flat-repair kit and the tools to do it (BeadBuddy, EnduroStar trail-stand, combo 24mm/19mm/12-13mm wrench/levers for axle nuts, spokes and tire beads). Get the tools to check your intake/exhaust valves too.
- Get a skid and case protection if you're riding any dirt...or carry a lot of Quiksteel and spare quarts of oil. Armor is more responsible though.
- Do the DR fixes. Swap the upper chain-roller for a Loc-tited setscrew ($0.90 @ Ace Hardware), Loc-tite and torque the NSU screws and the primary nut, grease the steering and swingarm bearings, and torque all reachable fasteners to spec.
- A lot of people like to get oil filter magnets and magnetic crankcase plugs.
- Loosen the barclamps on your clutch and front brake levers slightly, so they can rotate if hit. Drill the levers near the balls. Tusk handguards are also super affordable and pretty strong.
- ATV Logic tank panniers and tankbag are extremely inexpensive and fit stock or aftermarket DR tanks with just a different adjustable rear strap for the tankbag. Some people also stitch straps to the bottom front of the tank panniers for better retention than the supplied velcro provides. The bags give you a place to carry your registration, maps, GPS, beverages, extra layers, etc., and they weigh almost nothing...for a fraction of the cost of something like Wolfman or Giant Loop tank luggage.
- Set up the suspension for your weight with cargo. You'll likely need heavier springs, fork oil, and shock oil...minimum.
- Ride the snot out of it and decide what else you want to do. Your butt may toughen up enough for the stock seat to be a non-issue. You may prefer no windscreen. You may want even more power.
Kommando screwed with this post 10-07-2011 at 09:18 PM
Kommando is offline   Reply With Quote
Old 10-07-2011, 09:32 PM   #55243
drsmiley
drsmiley's Avatar
Oddometer: 276
I've jetted my carb with a DJ Kit, cut my air box open, put on a twin air filter, and a GSXR exhaust and on the open road I can get 53 or better MPG! I did 160 miles of paved and FS roads and trails last weekend with a 14T sprocket and got almost 50 MPG!
drsmiley is offline   Reply With Quote
Old 10-07-2011, 09:34 PM   #55244
doug s.
Oddometer: 1,354
+1 on that sentiment - if i had a bone stock dr650 and could do only one mod, it would be the seat. because the bike is absolutely not ride-able w/the stock seat, imo. mine would never get ridden w/the stock seat, so other mods would be a waste.
doug s.
doug s. is offline   Reply With Quote
Old 10-07-2011, 09:37 PM   #55245
vintagespeed
fNg
Oddometer: 1,855
Thumbs down
Originally Posted by motolab View Post
....there is no complete separate parts listing for California vs. other US markets, and Suzuki makes no distinction between California and other US markets on the carb diagram.....
i'll just paste this post from earlier in the DR650 thread. we're all here to learn, but please if you dont know what you're talking about please keep your ignorance to yourself and try to learn from the cumulative knowledge of others.
thanks. i think it's funny that it's almost the same exact ignorant argument as before.
http://www.advrider.com/forums/showp...ostcount=34842
the factory service manual i have lists the following jet needles: 6F19-3rd, 6F21-4th and mine 6F23
6F23 - is the single position jet needle and according to the manual is for E-03 (USA) and E-33 (California, USA) locations only.
you must have either the 6F19 or 6F21 jet needle in your carb, non-US model. or someone has monkey'd with your carburator.
vintagespeed is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
