Old 10-10-2011, 06:28 AM   #55351
doug s.
Oddometer: 1,348
Originally Posted by sander View Post
Try sucking through a long drinking straw and then cut a short piece of and suck through that. It's harder for the motor to suck air through the snorkel so it needs a bigger pressure differential, so there has to be a lower pressure in the air box. So although the volume of the air box remains the same, there is less air in it.
thank you!
doug s.
doug s. is offline   Reply With Quote
Old 10-10-2011, 06:55 AM   #55352
shu
Oddometer: 1,010
Originally Posted by fishbulb View Post
hi guys... where do you get the stick on side cover (case) protectors?
Perry, at AMP, makes them. He's got a nice little small business going and has been making them for few years now.
http://www.motorcycleproducts.org/En...n-frameset.htm
...........shu
shu is offline   Reply With Quote
Old 10-10-2011, 10:19 AM   #55353
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,752
Originally Posted by 955616846 View Post
....the heaviest spring specific to this shock is 6.3kg/mm from Eibach. Beyond that you'd be looking at adaptor rings (easy for a competent machinist) to mount anything heavier.
http://www.cannonracecraft.com/
YEAR MODEL FK SPRG RATES SHK SPRG RATES
2001-2005 DRZ 400 43510 .36,.38,.40,.42,.44, .46.48,.50,.52, .54 SHOWA 3.6-7.4
1999-2000 DRZ 400 44510 SPECIAL ORDER ONLY SHOWA 3.6-7.4
2000-2005 DRZ 400E 43510 .36,.38,.40,.42,.44, .46.48,.50,.52, .54 SHOWA 3.6-7.4
2000-2004 DRZ 400S 43520 SPECIAL ORDER ONLY SHOWA 3.6-7.4
takes them 5days to build custom springs, if needed.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-10-2011, 11:23 AM   #55354
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by PHILinFRANCE View Post
This thread SUCKS
... on your bicycle now mate! Better get working on your Morocco report. We're all "ears" here!
I trust you've been following Colebatch's report ... best Maroc report I've ever seen. His hand built $$$$$ BMW had shite-loads of problems ... I hope your DR is well prepped so you can fly the DR flag high! NO BREAKDOWNS! (flats are OK)
Adv Grifter screwed with this post 10-10-2011 at 01:26 PM
Old 10-10-2011, 12:08 PM   #55355
DRinda505
I'm right behind you.
DRinda505's Avatar
Oddometer: 407
Intermittent Starter Issues
I have a problem with electric start not always working, I'm suspecting the neutral start switch.
Here are the details.
I have bypassed and removed the kickstand safety switch and the clutch safety switch.
When the starter doesn't crank...
I turn on the key, and all electronics (lights on...) work.
The starter does not turn over the engine, no clicks or dimming of the headlight.
I can pull the plastic cover on the starter relay, and jumper the high current relay contacts to crank the engine, but it seems like no ignition spark.
After a couple of times doing this, the starter switch will start to work, and the bike fires right up.
It will continue to work normal for a few days, then reverts to the no crank condition, and I can then repeat the process.
I have a new starter relay here, but have not swapped it yet.
My suspicion is something loose inside the cover on the neutral switch?
Do these symptoms makes sense for this?
I know I'm being trouble shooting lazy here, but I'm hoping to use this wealth of experience to solve my problem.
Thanks for the suggestions.
DRinda505
DRZ front forks
DRZ rear shock with home made lower shock mount & dogbone linkage
IMS tank
skid plate
lowered foot pegs
open airbox w/ FCRMX carb
FMF power bomb header & Q4 silencer
Self made bar risers, seat, & panniers
wanting the procycle big valve cylinder head this winter.
05 DR650....Yea I know.... but it was cheap, Couldn't afford the Trail 90 I wanted.
DRinda505 is offline   Reply With Quote
Old 10-10-2011, 12:14 PM   #55356
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,775
you eliminated the kickstand switch, so disregard the neutral switch.
check your kill switch, could be dirty
plugeye is offline   Reply With Quote
Old 10-10-2011, 01:16 PM   #55357
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,445
Does the flange on the front sprocket go in or out?
The future is bright, fruitful, and positive.
Old 10-10-2011, 01:23 PM   #55358
Adv Grifter
Oddometer: 6,128
Couple things to check:
1. Double Check you wiring on the side stand and clutch safety switch mods you did. Make sure nothing is shorting or grounding out causing a no start.
2. Spray some WD40 into Kill switch and Start button. Work it in there and operate the switches. Sometimes can help ... can't hurt.
3. If it won't start ... put the bike in 2nd gear and just push it forward a bit, just turning the engine a few degrees. Does it start after that?
If this is what's happening and a slight rotation allows it to start then the starter motor brushes may need dressing up and lubed ... or new brushes.
Water gets in there and can screw things up.
Could be the relay ... not sure how to check it.
Good luck.
Old 10-10-2011, 02:14 PM   #55359
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,518
Changes 2002 to New
Buying a 2002 DR650. Can remain without one for no longer. Is there somewhere I can find a list of up dates/differences between that and a new one? Just stuff that "matters". Thanks.
skysailor is offline   Reply With Quote
Old 10-10-2011, 02:24 PM   #55360
Dyno
Conquistador
Dyno's Avatar
Oddometer: 1,832
The color changed, and they added "bold new graphics".
Dyno is offline   Reply With Quote
Old 10-10-2011, 02:27 PM   #55361
vintagespeed
fNg
Oddometer: 1,752
second gear was changed in '06 to stop them blowing up...
Old 10-10-2011, 02:35 PM   #55362
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,341
Paper base gasket.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is online now   Reply With Quote
Old 10-10-2011, 02:44 PM   #55363
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,188
Boy, can't anyone use a nice seat cover and foam?
http://www.advrider.com/forums/showthread.php?t=731585
Not one reply!
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak is offline   Reply With Quote
Old 10-10-2011, 02:51 PM   #55364
BergDonk
BergDonk's Avatar
Oddometer: 3,580
For a 520 chain it goes to the outside.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-10-2011, 03:14 PM   #55365
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,902
Originally Posted by Rumlover View Post
First, Congrats on the new bike!
I won't even attempt explaining carb theory (probabaly better for all), But I will tell you that opening up the air box and exhaust will result in a lean condition. You may get away with pulling the snorkel, depending on your altitude, but anything much more will result in a lean conditon. In fact on the DR the change can be rather dramatic. My own experience with jetting and opening up the air box hole resulted in some pretty wild swings until I got the jetting and new hole size to match up.
But feel free to experiment away, the simplicity of the DR kind of encourages it. Good luck!
Funny, everyone has a theory but I haven't seen one person actually put an air/fuel meter on the bike and try diffrent things. Soooo.....
I am in the process on installing an air/fuel meter on my DR. Waiting on my welder to install the bung in the mid pipe. I wont be able to give air/fuel for the stock muffler just because it seemed stupid to go through the trouble to weld a bung in the stock muffler then take it off to replace it.... I put a Yoshimura midpipe and R3 silencer. Plan on getting readings from the stock carb settings...re-jetting (if needed) and I will pull the snorkle just for shits and grins to see if it makes a change. I will be using an Innovate LM1 wide band air/fuel meter. Nice thing is it records rpm/ air fuel, manifold pressure, and other stuff if I want. Record then go back and look so I will be able to give a little run down of what I saw.
Mongle is online now   Reply With Quote
Times are GMT -7.   It's 12:38 PM.
