Old 10-23-2011, 10:06 AM   #55936
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,993
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-23-2011, 10:40 AM   #55937
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Originally Posted by Mercenary View Post
Any examples Kommando? I know for a fact that the stocker isn't going to do it for me so a new more comfortable seat is a must for me...
And I think going with a well built WIDER seat is the way to go for me as well....I'm pretty big boned if you catch my drift
As another "big boned" DR pilot, I'm very pleased with my Corbin. They start out a little stiff, but they do break-in and get much more comfortable. That, taller bars, an IMS tank and a Parabellum screen make 10 hour days very doable...
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 10-23-2011, 12:44 PM   #55938
Stringer99
Oddometer: 183
Cry
What would cause a dr650 to turn its oil into what looks exactly like chocolate milk after only 100-200 miles? I just got this bike 600 miles ago and have to change the oil for the 4th time :( previous owner says he ran bel-ray 90wt gearsaver, oil looked new when bought. been running bel-ray thumper syn blend 10-40 but thats too expensive now so just picked up some rotella t 15-40. also bike had only 3600 miles when i got it, and just noticed the cylinder looks like its been removed before all filters are new.
Stringer99 is offline   Reply With Quote
Old 10-23-2011, 01:01 PM   #55939
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,843
water or condensation , or milk chocolate
just change the oil
www.manracks.com
jungleplant is offline   Reply With Quote
Old 10-23-2011, 01:06 PM   #55940
ER70S-2
ER70S-2's Avatar
Oddometer: 6,121
How long are your rides? Short hops don't allow the engine to get up to operating temps and moisture will condense inside the engine, causing chocolate oil. I rode 170 miles Friday, and the oil temp was under 200* most of the time. Moisture won't burn off until 212*, (think steam). I have an aftermarket oil temp gauge, sender in the front of the engine case. An infrared thermometer will work for oil temp.
Check the oil window frequently, as soon as the chocolate appears, take a long ride. This will be when there is the least moisture in the oil and it will burn off quickly. If you wait too long after the milky appearance, there may be enough moisture in the oil to cause damage.
2004 DR650: 62,402 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 10-23-2011 at 01:12 PM
ER70S-2 is online now   Reply With Quote
Old 10-23-2011, 01:19 PM   #55941
Stringer99
Oddometer: 183
rides have been 100 miles on interstate so i can only imagine it got hot enough to burn off.
Old 10-23-2011, 01:56 PM   #55942
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
I modded both my 97 seat and my 02 and it worked out so well I don't even think about the seat anymore... that's the best testimony. Flatter, wider in the sitting portion, and 'float' attached.. the bolts pin the seat to the frame so that the frame vibration etc transmits harshly to the pan. remove the bolts and just tie those tabs with wire so the upward [fly-off] motion is constrained a tad, but otherwise it gets to take advantage of the rubber bumpers suzi thoughtfully added
I think I paid 65 for the job - i drew it out and got a boat upholsterer to do the cutting/whacking and very fine middle-firm foam. recovered with the stock cover.
Originally Posted by jon_l View Post
If I were buying a DR, I wouldn't worry about the seat, yet.
I have only had mine a couple months, so I need more seat-time before I even think about options. Longest day on it so far isn't epic, just 2 hours each way, same day, to spectate at an enduro. I can say it is better than my DR350 seat.
My '06 came with the gel seat mounted + the stock. I rode briefly with the gel, switched to the stock just for comparison, and have never bothered to put the gel back on. Not sure the gel isn't better, it may be, but frankly, the stock seat just doesn't bother me that much.
Anyway, just saying I wouldn't decide to spend $350 for a seat based on other people's opinions of the stocker.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 10-23-2011, 03:49 PM   #55943
macrae85
Oddometer: 391
Originally Posted by doug s. View Post
hey, glad you got the ebay thing down. but, your saying you stayed up half the night watching an auction made me think otherwise; it amazes me that there's still folks out there who actually try to manually snipe auctions, or proxy bid.
thanks for the honda fmx650 idea; i will have to check it out...
doug s.
Meant to say.....i was on eBay.co.uk......the British one,hence the time difference!
macrae85 is offline   Reply With Quote
Old 10-23-2011, 05:20 PM   #55944
doug s.
Oddometer: 1,314
i understand that - i figured you were on ebay-uk if you were bidding on lime parts. i was yust thinking you were manually bidding, and that's why you were up late; if it were me, i'd have been sleeping, and simply checking the auction the next a.m, to see if i had won or not...
doug s.
doug s. is offline   Reply With Quote
Old 10-23-2011, 07:01 PM   #55945
Harpua
formerly josdavlar
Harpua's Avatar
Oddometer: 166
help pwease
hey ya'll
i've done searches but can't quite find out... i'm doing a home job mod to the choke cable and mine never worked to begin with.
when the choke is ON is the little brass piston BACKED OUT of its little cylinder? or is it the other way around?
one more thing while i got the bike torn apart...
the header weld everyone talks about, is it located INSIDE the pipe?
thanks a lot!
Harpua is offline   Reply With Quote
Old 10-23-2011, 07:33 PM   #55946
Paddle007
Oddometer: 312
does anyone know where to buy stock carb mainjets individually? i have a 145 installed, but now the carb is modified, header weld grinded, modded airbox, and a new DG exhaust on the way. Does a 155 sound about right? where to buy individually? i already have the slide drilled and adjustable needle jet. thanks.
Jets R Us seems to have a decent selection. They offer OEM or aftermarket choices. They have been prompt with shipping.
Paddle007 is offline   Reply With Quote
Old 10-23-2011, 08:48 PM   #55947
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 419
Originally Posted by josdavlar View Post
hey ya'll
thanks a lot!
Yes.
-- alonzo
alonzo is offline   Reply With Quote
Old 10-23-2011, 10:11 PM   #55948
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,260
When the choke is ON is the little brass piston BACKED OUT of its little cylinder? or is it the other way around?
The choke is not like a old school butterfly in the carb inlet tract.
On the BST and TM 40 it is more of a controlled leak.
It is as you say.
The brass plunger has a seal on the end which covers a fuel passage,when you pull the choke lever on the plunger uncovers the passage allowing fuel to flow to another passage that exits into the carburetor inlet tract creating a rich mixture.
When the choke lever is returned to the off position,the cable allows the plunger to move inward again via the small return spring,covering the passage.
One reason to make sure it is in good working order to avoid the plunger not seating properly and the resulting poor mileage.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 10-24-2011, 05:26 AM   #55949
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Originally Posted by ungeheuer View Post
Alright. Educate me .
My Corbin seat fits my stock tank.
My stock DR seat fits my stock tank.
My stock DR seat fits an IMS tank.
How come my Corbin seat which fits my stock tank wont fit an IMS tank then?
I guess what I'm asking is whats the actual diff between the Corbin seatpan for stock and the Corbin seatpan for IMS?
And can I make Corbin-for-stock fit an IMS? I mean how different can they be?
Cheers .
IMS has seen fit in their wisdom to make the angle on the back of their tank different...
A bit like Clarke bringing out a tank for the TT350 Yammy that's exactly the same capacity as stock but 10 times more expensive.
NordieBoy is online now   Reply With Quote
Old 10-24-2011, 06:03 AM   #55950
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
shameless plug
Gang the turnsignal relocator is selling well. would like to get enough of these out there to fund the "Type 2" which will be 4-bolt size with knockouts for switches and Accessory socket
http://www.ebay.com/itm/110753607721#ht_1261wt_1185
despite whats in the ebay listing, we do have some units in Australia and Canada if you'd prefer to buy from those inmates, and I can arrange ship wherever and just pass through the incremental cost... the worst part is that I have to get a human at the USPS to stamp the customs forms, and I don't live close to any of them... Just another excuse to kick the tires and light the fires
Zapp
Times are GMT -7.   It's 11:00 PM.
