11-06-2011, 03:02 PM
#56536 | |
Southern Ontario
Oddometer: 1,982
http://www.thumpertalk.com/forum/sho....php?t=1000929 There seem to be quite a few alternatives to the D606 being discussed in that thread. D606s for the DR650 are $87 rear, $84 front, with free shipping from Motorcycle Superstore: http://www.motorcycle-superstore.com...res-Tires.aspx |
11-06-2011, 03:03 PM
#56537 | |
Oddometer: 1,170
Lonewolf97
11-06-2011, 03:07 PM
#56538 |
Southern Ontario
Oddometer: 1,982
nice DR for sale in Toronto
warningCanadian folks, I have posted a FOR SALE ad here: http://www.advrider.com/forums/showp...9&postcount=33 US folks, no need to look really, since everything here is ~25% more expensive. I love the bike, but after doing a trail bike school with the whole family last Summer, the mission profile is dirtier that it was when I bought the bike, and while a GREAT 50/50 dual-sport bike, the DR is too heavy for what I want right now. Jon jon_l screwed with this post 11-06-2011 at 05:15 PM |
11-06-2011, 03:10 PM
#56539 | |
I can pass this guy.....
Oddometer: 2,737
2012 Triumph Bonneville 2006 Suzuki Vstrom ![]() Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
11-06-2011, 03:18 PM
#56540 | ||
Nobody Home
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
11-06-2011, 04:07 PM
#56541 | |
Oddometer: 338
All's well!
My next PC order I am going to pull the trigger on the shop repair manual it would be nice to have it next to the bike. |
11-06-2011, 05:00 PM
#56542 | |
Grandpa Adventurer
Oddometer: 1,175
Bike onto Center Stand
Yes, I also have the center stand from Procycle (been on for several years). Love it too for chain maintenance and flats, but the tire is just skimming the ground. Have found a small rock, stick or scrap of 2"x4" under each foot will raise the tire off the ground. Sometimes, the saddle bags need removed and hung on the handle bars to get the front tire down and the rear tire up. Putting the loaded bike on the center stand: 1. Stand on the left side of the bike 2. Put center stand down with your right foot and hold it down. I just step on the pad part. 3. Grab tank at front edge with left hand, palm down 4. Grab passenger hand grip with right hand 5. Pull the bike backwards with left hand and lift with right hand at same time 6 Grunt and maybe push back on saddle bag with right knee. 7. Continue about your business This procedure has developed by trial and error. Dave
Smilin Jack Western Oregon USA 2006 DR650SE CB250 1991 Adventure bike "dual-sport" http://www.advrider.com/forums/showthread.php?t=441736 http://www.advrider.com/forums/showthread.php?t=469125 http://www.advrider.com/forums/showt...e#post11612867 http://www.facebook.com/album.php?ai...8&l=3d8dcb2743 |
11-06-2011, 06:03 PM
#56543 |
Oddometer: 290
11-06-2011, 06:31 PM
#56544 |
Oddometer: 53
Bog off idle
When I installed my dj kit from keintech along with the gsxr muffler mod and airbox cut, I had a just off idle bog if I whacked the throttle quickly. I cured it by dropping the needle from the 4th slot from the top (the recommended slot) to the 3rd slot from the top. Off idle bog is gone and bike runs WAY better than stock.
Chris in Topeka |
11-06-2011, 06:57 PM
#56545 | |
Oddometer: 1,166
http://www.rockymountainatvmc.com/pr...&sizeAttr=1491 http://www.jakewilson.com/productDet...dFamilyId=4399 save $7 - yahoo! ![]() doug s. |
11-06-2011, 08:29 PM
#56546 | |
Oddometer: 1,110
As I'm sure you are aware, needle clip position is responsible for operation at 1/4 throttle opening. Pilot jet size is responsible for 1/16 to 1/8 throttle openings. I would consider 1/16 to 1/8 throttle opening to be off idle, whereas I would consider 1/4 throttle opening to be too far away from idle to be considered off idle. I guess there are a few possibilities: Perhaps you consider 1/4 throttle opening to be off idle. Perhaps the problem spanned all the way from 1/16 to 1/4 opening, and the overlap between circuits was enough to cure 1/16 to 1/8 while having the greatest effect on 1/4 opening. Perhaps the problem was in the 1/16 to 1/8 area and lowering the needle helped because the overlap between circuits had enough of an effect. If the last possibility fits most accurately, then perhaps it might be better to consider a smaller pilot jet instead of lowering the needle. All of that said, it's quite rare for a late model bike to come with a pilot jet that is too rich. I would therefore check the float height as well as inspect the slide guide and emulsion tube for wear. How many miles are on the carb? Regards, Derek |
11-06-2011, 09:03 PM
#56547 | |
Oddometer: 77
Same issue!
dr650..te510 Falling's like fly'n....for a lil while ! |
11-06-2011, 09:20 PM
#56548 |
not normal
Oddometer: 493
just picked one of these up today for $700. needs a killswitch, and some small stuff, but not in terrible shape. I'Z BACK!
Where does this road go? screw your maps! we're gonna find out the FUN way! error 404: common sense not found. |
11-06-2011, 09:35 PM
#56549 | |
Oddometer: 1,643
Steve |
11-06-2011, 09:52 PM
#56550 |
Oddometer: 233
Oil filter inspection
Hey guys, I just posted a new thread describing how to inspect your oil filter for signs if abnormal wear. I did it showing a dr650 oil filter, and it's simple to do. I was going to post the info in this thread but didn't want to add it to an already overwhelmed thread. Check it out and let me know what you think. I think it's a pretty handy thing to do, especially on a rainy day.
Here's the link: http://www.advrider.com/forums/showthread.php?t=739876
2006 DR650 Oregon Tag-O-Rama ![]() http://www.advrider.com/forums/showt...=752387&page=3 |
