11-10-2011, 05:10 AM
#56701 |
Oddometer: 289
Never use those fiber wheels around an open engine. The material, aluminum oxide? , which flies off the wheel is extremely small and impossible to remove from your engine. Major automotive manufacturers have bulletins explaing the problem. They also are too abrasive. You will not have a flat surface when your done. I know it's not alot of metal removed but the time saved is not worth it.
11-10-2011, 05:41 AM
#56702 |
Faccia Brutta
Oddometer: 461
520 Conversion
I did a search but either I suck at using the search tool or the search tool sucks.
Two questions First, how do you search for a specific term? I've seen where you use quotes to indicate a specific term. Second question, with the 520 conversion, are there additional spacers needed and if I'm going to a 46 tooth rear, should I get rid of the top roller. The rear shock has been resprung and revalved so the sag is dead on for off road set up.
pin it! |
11-10-2011, 07:19 AM
#56703 |
Oddometer: 1,607
Don't even consider it. I've seen dozens of cylinders and other parts ruined because some "mechanic" user an abrasive wheel to remove a gasket.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
11-10-2011, 08:34 AM
#56704 | |
Oddometer: 2,070
I've found the best way to search this site is through google. go to "Advanced search" and enter www.advrider.com as the the domain. Then you can be as specific as you want to and use less than five characters. 2 cents. Aslo I have a 520 chain and it was plug and play. No extra spacers. And yes get rid of the top roller. It's useless.
My Blogs: Higher Resolution Photo Album Motorcycle Photo of the Day 2-Stroke-Biker-Blog |
11-10-2011, 08:35 AM
#56705 | |
Oddometer: 1,126
Search on here?
No you do not need additional spacers for the 520 conversion. Evidence points to there being no downside to removing the upper roller. As recently pointed out not all fail if left on but if the one that does is yours ...... A look back through just the last few days will let you see the evidence and decide for yourself. Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
11-10-2011, 08:39 AM
#56706 | ||
Big Bearded Boy
Oddometer: 1,071
The low speed surging is when i'm in a low gear around, i'd guess, 1/4 throttle, like if you're trying to maintain 25mph down a hill with a cop behind you without applying brake. The suggestion to mark off the 1/16, 1/8, 1/4, 1/2, 3/4 and WOT is a good one, I may go ahead and do that. Quote:
What's the typical method to set that fuel screw? Listen for some specific behavior at idle while adjusting? I think it's so awesome you're out here on the boards helping us.
Current: '07 B1250. ![]() Former Steeds: '99 DR650, '02 DR650, '09 DL650 First Trip on 2 Wheels. 10,000 miles. 21 years old. |
11-10-2011, 08:41 AM
#56707 | |
Big Bearded Boy
Oddometer: 1,071
Easy thing to do is type "site:advrider.com" then a space and your search term. For example you can type "site:advrider.com dr650 520 conversion"
11-10-2011, 08:51 AM
#56708 | |
Butler Maps
Oddometer: 14,445
normal pilot jet tuning methods w/ the BST result in mixture that produces bog. you need to ignore what you know from other bikes as the BST carb oerforms better w/ a lean pilot jet circuit from off idle throttle. it is what it is.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
11-10-2011, 08:55 AM
#56709 | |
fNg
Oddometer: 779
your dyno chart is impressive but it only demonstrates that you MAIN JET is fine. not sure what that has to do with the needle?
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
11-10-2011, 08:59 AM
#56710 | |
Big Bearded Boy
Oddometer: 1,071
Not applying what I know from other bikes, lol. My first bike was a Bandit 1250 which was FI. Then I bought a DR. I'm 22, and my Dad couldn't even teach me to change the oil in a car growing up. Thanks to forums i'm able to get some of that wise-old-man mechanical advice instead of always having to learn the hard way (like with my cam chain tensioner incident)
11-10-2011, 09:11 AM
#56711 | ||
Oddometer: 2,564
I'll edit my post.
11-10-2011, 09:35 AM
#56712 |
"I think we can make it"
Oddometer: 49
For sale
I haven't signed on this forum in a while, last time I was up to speed there was just over a 1000 post now you guys are climbing to 4000!
I have a 2007 DR650SE with just over 10K miles on it. Extras include Renzaco Racing custom made seat, Renthal bars, Acerbis hand guards, skid plate, rear brake guard, SW Motto Tech luggage rack, Dyno Jet kit and K&N air filter. Kelly Blue Book says 3300. I say 3500 takes her away with all the extras I mentioned. Located in North Eastern Connecticut e-mail me if your serious at mdcxlc@yahoo.com and I'll send pics. Bike is blue. I bought a house and enough said.
Famous last words after approaching a hero section that contains water "Oh yea...we can make it" |
11-10-2011, 10:25 AM
#56713 | ||
Oddometer: 1,126
Regards, Derek |
11-10-2011, 10:34 AM
#56714 | |
Oddometer: 1,126
If it was known that the chart was for WOT, and if the carb in question was a slide type, you would be correct. Regards, Derek |
11-10-2011, 10:44 AM
#56715 | |
Big Bearded Boy
Oddometer: 1,071
